This issue, which was falsely flagged as a power supply issue (because it started occurring when the desktop wasn’t suspended) returned, but only when I use my PCI USB hub: After Suspending, I I Can't Detect my XBONE Controller?
The Issue: Wired (via USB ) 2015 Microsoft Xbox One (XBONE) controller vibrates when plugged in, indicating that it is charging, but the light doesn’t stay solid, indicating no data connection. It also does not appear on lsusb, nor is it accessable my my XBONE mapper.
At first (per the previous problem) I thought that this was an issue with the PCI module not recieving enough power, but I gave it a dedicated line from my 1000W power supply (of which I only use a maximum of 700W MAX, and the system is more typically in the 400W range.
Here is the PCI card (which I have wired to the power supply using their MOLEX connector): ORICO SuperSpeed 7 Ports USB3.0 PCI-E Expansion Card Adapter PCI-E USB 3.0 HUB Controller Adapter Add on Card for Windows Vista PC Laptop (No Additional Power Connection Needed) - Newegg.com
I honestly can’t tell if this is a system issue, or a hardware issue with the card itself as it seems to work fine every reboot (and has a high probability of failure after a suspend).
What is wrong with the system, hardware or something about the OS’s PCI-data-system?
lsusb Before Suspend):
sarah@MidnightStarSign:~$ lsusb | grep Micro
Bus 007 Device 003: ID 0c45:6367 Microdia USB 2.0 Camera
Bus 006 Device 004: ID 152d:1561 JMicron Technology Corp. / JMicron USA Technology Corp. JMS561U two ports SATA 6Gb/s bridge
Bus 005 Device 005: ID 045e:02dd Microsoft Corp. Xbox One Controller (Firmware 2015)
Bus 003 Device 013: ID 0781:5151 SanDisk Corp. Cruzer Micro Flash Drive
Bus 003 Device 010: ID 0c45:652f Microdia Backlit Gaming Keyboard
lsusb (After suspend) :
System Specs:
Kernel: 5.10.61-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.10-x86_64
root=UUID=6ce26050-4dcc-47b7-a937-45467d8b8d61 rw rootflags=subvol=@ quiet
cryptdevice=UUID=466d5812-64c7-4a28-bcc4-a1a5adfa9450:luks-466d5812-64c7-4a28-bcc4-a1a5adfa9450
root=/dev/mapper/luks-466d5812-64c7-4a28-bcc4-a1a5adfa9450 apparmor=1
security=apparmor
resume=/dev/mapper/luks-81b2dc57-06f5-4471-b484-77c3a516f307
udev.log_priority=3
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: PRIME X570-PRO v: Rev X.0x
serial: <filter> UEFI: American Megatrends v: 3001 date: 12/04/2020
RAM: total: 62.78 GiB used: 25.17 GiB (40.1%)
Info: 16-Core model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3
family: 19 (25) model-id: 21 (33) stepping: 0 microcode: A201009 cache:
L2: 8 MiB bogomips: 217676
Speed: 4096 MHz min/max: 2200/3400 MHz boost: enabled Core speeds (MHz):
1: 4096 2: 3928 3: 4578 4: 3902 5: 4578 6: 4527 7: 3975 8: 4177 9: 4264
10: 4298 11: 4445 12: 4408 13: 4417 14: 4202 15: 4087 16: 4349 17: 4107
18: 4491 19: 4398 20: 4554 21: 3875 22: 4560 23: 4448 24: 4431 25: 3965
26: 4454 27: 3848 28: 4407 29: 4398 30: 4446 31: 4536 32: 4339
cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt pse pse36 rdpid rdpru
rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall
vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
STIBP: always-on, RSB filling
Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: ASUSTeK driver: nvidia
v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 0b:00.0
chip-ID: 10de:2484 class-ID: 0300
Device-2: Microdia USB 2.0 Camera type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 7-2:3 chip-ID: 0c45:6367 class-ID: 0102 serial: <filter>
Screen-1: 0 s-res: 5760x1080 s-dpi: 92 s-size: 1590x301mm (62.6x11.9")
s-diag: 1618mm (63.7")
Monitor-1: DP-1 res: 1920x1080 hz: 60 dpi: 93 size: 527x296mm (20.7x11.7")
diag: 604mm (23.8")
Monitor-2: HDMI-0 res: 1920x1080 dpi: 93 size: 527x296mm (20.7x11.7")
diag: 604mm (23.8")
Monitor-3: DP-3 res: 1920x1080 dpi: 93 size: 527x296mm (20.7x11.7")
diag: 604mm (23.8")
OpenGL: renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2
v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0b:00.1 chip-ID: 10de:228b
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0d:00.4 chip-ID: 1022:1487
class-ID: 0403
Device-3: JMTek LLC. Plugable USB Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1:2 chip-ID: 0c76:120b
class-ID: 0300 serial: <filter>
Device-4: ASUSTek ASUS AI Noise-Cancelling Mic Adapter type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-5:4 chip-ID: 0b05:194e
Device-5: Schiit Audio Schiit Modi 3+ type: USB driver: snd-usb-audio
bus-ID: 7-1:2 chip-ID: 30be:1014 class-ID: 0102
Device-6: Microdia USB 2.0 Camera type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.10.61-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.34 running: yes
Device-1: Realtek RTL8125 2.5GbE driver: r8169 v: kernel port: e000
bus-ID: 05:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
port: d000 bus-ID: 07:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp7s0 state: down mac: <filter>
driver: btusb v: 0.8 bus-ID: 3-5.3:7 chip-ID: 0a12:0001 class-ID: e001
Device-1: luks-c847cf9f-c6b5-4624-a25e-4531e318851a maj-min: 254:2
type: LUKS dm: dm-2 size: 3.64 TiB
Components:
p-1: sda1 maj-min: 8:1 size: 3.64 TiB
Device-2: TEMP maj-min: 254:3 type: LUKS dm: dm-3 size: 1.82 TiB
Components:
p-1: sdc1 maj-min: 8:33 size: 1.82 TiB
Device-3: luks-466d5812-64c7-4a28-bcc4-a1a5adfa9450 maj-min: 254:0
type: LUKS dm: dm-0 size: 864.75 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 864.75 GiB
Device-4: luks-81b2dc57-06f5-4471-b484-77c3a516f307 maj-min: 254:1
type: LUKS dm: dm-1 size: 66.26 GiB
Components:
p-1: nvme0n1p3 maj-min: 259:3 size: 66.26 GiB
Local Storage: total: 10.94 TiB used: 3.52 TiB (32.2%)
model: WDS100T3X0C-00SJG0 size: 931.51 GiB block-size: physical: 512 B
rev: 111110WD temp: 46.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Western Digital
model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
rev: 211070WD temp: 41.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD4005FZBX-00K5WB0 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A01 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Western Digital
ID-5: /dev/sdc maj-min: 8:32 type: USB vendor: Sabrent model: SABRENT
size: 1.82 TiB block-size: physical: 4096 B logical: 512 B type: N/A
serial: <filter> rev: 0204 scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 type: USB vendor: Toshiba model: TransMemory
size: 14.92 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.00 scheme: MBR
ID-7: /dev/sde maj-min: 8:64 type: USB vendor: SanDisk
model: Gaming Xbox 360 size: 7.48 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 8.02 scheme: MBR
ID-1: / raw-size: 864.75 GiB size: 767 GiB (88.70%) used: 583.67 GiB (76.1%)
fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-466d5812-64c7-4a28-bcc4-a1a5adfa9450 label: N/A
uuid: 6ce26050-4dcc-47b7-a937-45467d8b8d61
used: 26.1 MiB (5.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 4B3B-683F
ID-3: /home raw-size: 864.75 GiB size: 767 GiB (88.70%)
used: 583.67 GiB (76.1%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
ID-4: /run/media/sarah/Convergent Refuge raw-size: 1.82 TiB
size: 1.82 TiB (100.00%) used: 1.33 TiB (73.1%) fs: btrfs dev: /dev/dm-3
maj-min: 254:3 mapped: TEMP label: N/A uuid: N/A
ID-5: /run/media/sarah/ConvergentRefuge raw-size: 3.64 TiB
size: 3.64 TiB (100.00%) used: 1.29 TiB (35.4%) fs: btrfs dev: /dev/dm-2
maj-min: 254:2 mapped: luks-c847cf9f-c6b5-4624-a25e-4531e318851a
label: ConvergentRefuge uuid: 7d295e73-4143-4eb1-9d22-75a06b1d2984
ID-6: /run/media/sarah/MSS_EXtended raw-size: 731.51 GiB
size: 731.16 GiB (99.95%) used: 344 GiB (47.0%) fs: xfs dev: /dev/nvme1n1p1
maj-min: 259:5 label: MSS EXtended
uuid: 20339e0b-8343-433e-9209-ac67e31d9d73
ID-1: swap-1 type: partition size: 64 GiB used: 51 MiB (0.1%) priority: -2
dev: /dev/dm-1 maj-min: 254:1
mapped: luks-81b2dc57-06f5-4471-b484-77c3a516f307 label: N/A
uuid: c5112526-26fb-473c-b7ab-bb9ef049aa38
ID-1: /dev/nvme1n1p2 maj-min: 259:6 size: 16 MiB fs: <superuser required>
ID-2: /dev/nvme1n1p3 maj-min: 259:7 size: 199.98 GiB fs: ntfs label: N/A
uuid: E658FD3258FD025B
ID-3: /dev/sdb1 maj-min: 8:17 size: 3.64 TiB fs: ntfs label: JerichoVariance
uuid: 1AB22D5664889CBD
ID-4: /dev/sdd1 maj-min: 8:49 size: 2.97 GiB fs: iso9660
ID-5: /dev/sdd2 maj-min: 8:50 size: 4 MiB fs: vfat label: MISO_EFI
uuid: 97EE-3EF6
ID-6: /dev/sde1 maj-min: 8:65 size: 2.83 GiB fs: iso9660
ID-7: /dev/sde2 maj-min: 8:66 size: 4 MiB fs: vfat label: MISO_EFI
uuid: B299-34C4
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Device-1: 3-1:2 info: JMTek LLC. Plugable USB Audio Device type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0c76:120b class-ID: 0300
serial: <filter>
Hub-4: 3-2:3 info: Terminus FE 2.1 7-port Hub ports: 7 rev: 2.0
speed: 480 Mb/s power: 100mA chip-ID: 1a40:0201 class-ID: 0900
Device-1: 3-2.1:15 info: Sunplus Innovation Gaming mouse [Philips SPK9304]
type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0
speed: 1.5 Mb/s power: 98mA chip-ID: 1bcf:08a0 class-ID: 0301
Device-2: 3-2.3:8 info: Future Devices FT232 Serial (UART) IC
type: <vendor specific> driver: ftdi_sio interfaces: 1 rev: 2.0
speed: 12 Mb/s power: 90mA chip-ID: 0403:6001 class-ID: 0000
serial: <filter>
Device-3: 3-2.4:9
info: Toshiba TransMemory-Mini / Kingston DataTraveler 2.0 Stick
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
speed: 480 Mb/s power: 100mA chip-ID: 0930:6544 class-ID: 0806
serial: <filter>
Device-4: 3-2.5:10 info: Microdia Backlit Gaming Keyboard
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 400mA chip-ID: 0c45:652f class-ID: 0301
Device-5: 3-2.6:11 info: HUION H420 type: Mouse,HID driver: uclogic,usbhid
interfaces: 3 rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 256c:006e
class-ID: 0300
Hub-5: 3-2.7:12 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 3-2.7.2:13 info: SanDisk Cruzer Micro Flash Drive
speed: 480 Mb/s power: 200mA chip-ID: 0781:5151 class-ID: 0806
serial: <filter>
Device-2: 3-2.7.4:14 info: Texas Instruments TI-Nspire Calculator
type: <vendor specific> driver: usbfs interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 0451:e012 class-ID: 0000
Hub-6: 3-5:4 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 3-5.3:7 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0a12:0001 class-ID: e001
Hub-7: 3-6:6 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-8: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-9: 5-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Device-1: 5-2:2 info: W. H. Freeman IOLab USB Dongle
type: Abstract (modem),CDC-Data driver: cdc_acm interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 50mA chip-ID: 1881:0400 class-ID: 0a00
serial: <filter>
Device-2: 5-4:3 info: ASUSTek AURA LED Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
chip-ID: 0b05:18f3 class-ID: 0300 serial: <filter>
Device-3: 5-5:4 info: ASUSTek ASUS AI Noise-Cancelling Mic Adapter
type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 0b05:194e class-ID: 0300
serial: <filter>
Hub-10: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Device-1: 6-1:4
info: JMicron / JMicron USA JMS561U two ports SATA 6Gb/s bridge
type: Mass Storage driver: uas interfaces: 1 rev: 3.0 speed: 5 Gb/s
power: 896mA chip-ID: 152d:1561 class-ID: 0806 serial: <filter>
Hub-11: 7-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 7-1:2 info: Schiit Audio Schiit Modi 3+ type: Audio
driver: snd-usb-audio interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-2: 7-2:3 info: Microdia USB 2.0 Camera type: Video,Audio
power: 500mA chip-ID: 0c45:6367 class-ID: 0102 serial: <filter>
Hub-12: 8-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1
System Temperatures: cpu: 66.6 C mobo: N/A gpu: nvidia temp: 38 C
Processes: 862 Uptime: 20h 53m wakeups: 6 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 alt: 10 clang: 12.0.1 Packages: 2061
pacman: 2044 lib: 488 flatpak: 3 snap: 14 Shell: Bash v: 5.1.8
running-in: yakuake inxi: 3.3.06
