After Startup sometimes the Desktop is not fully loading
Hi,
sometimes i have a problem after starting manjaro with KDE Plasma.
Normally you see the desktop with the Controllbar after Manajro is up.
In my case, i turn on the PC and after booting i see a Desktop without Controllbar and i cannot click on the two icons on the Desktop. Without Controllbar ist impossible for me to turn off Manjaro or to restart it. The Right Click on my mouse does also not work in this case. So i have to turn off the PC the hard way.
Does anyone have an idea, what i can look for?
Thanks
Hi,
First, in such cases please try to use one of the following:
Meta+T, Ctrl+Alt+T to hopefully pull up Konsole Terminal
-or-
Ctrl+Alt+F5 (Or F2,F3,F4,Fx…) to switch to TTY
-in either case-
Then you could perform systemctl reboot or systemctl poweroff to reboot or shutdown.
Also please see this and return system information:
Thanx so far. I will try it next time.
I have the exactly same problem as yours. However, this only occurs when I switched from dual boot Ubuntu 18.04 to Manjaro. In other words, if i shot down with Manjaro and reboot manjaro, this problem won’t happen.
My solution is rebooting again by pressing the power button for 5s.
Thanks BrandonMoo.
I will test it on my system. I also have dual boot together with win.
@cscs: STRG-ALT-F5 works. So i can reboot the machine.
[joerg@BueroPC ~]$ inxi --admin --verbosity=7 --filter --width
  Kernel: 5.15.19-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
    root=UUID=25c84d32-6a5e-4edb-9dd2-9c80609a1121 rw quiet apparmor=1
    security=apparmor resume=UUID=76088f3e-730f-404e-bab3-ae5ed01e39a5
    udev.log_priority=3
  Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop System: Gigabyte product: X570 AORUS MASTER v: -CF
    serial: <superuser required>
  Mobo: Gigabyte model: X570 AORUS MASTER serial: <superuser required>
    UEFI: American Megatrends LLC. v: F35e date: 10/13/2021
  RAM: total: 31.33 GiB used: 3.67 GiB (11.7%)
  RAM Report:
  Info: model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2
    family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
  Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
    L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
    L3: 64 MiB desc: 4x16 MiB
  Speed (MHz): avg: 2295 high: 3600 min/max: 2200/4672 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3600 2: 2049
    3: 2051 4: 2199 5: 2198 6: 2199 7: 2198 8: 2200 9: 2199 10: 2201 11: 2200
    12: 2200 13: 3596 14: 2057 15: 2138 16: 2197 17: 2200 18: 2198 19: 2197
    20: 2200 21: 2203 22: 2199 23: 2202 24: 2200 bogomips: 182484
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse
    sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
    topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
    vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
    conditional, RSB filling
  Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] driver: amdgpu
    v: kernel bus-ID: 0d:00.0 chip-ID: 1002:73bf class-ID: 0300
  Display: x11 server: X.Org 1.21.1.3 compositor: kwin_x11 driver:
    loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.7x15.0")
    s-diag: 777mm (30.6")
  Monitor-1: DisplayPort-0 res: 2560x1440 hz: 60 dpi: 109
    size: 597x336mm (23.5x13.2") diag: 685mm (27")
  Device-1: AMD Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT]
    driver: snd_hda_intel v: kernel bus-ID: 0d:00.1 chip-ID: 1002:ab28
    class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
    driver: snd_hda_intel v: kernel bus-ID: 0f:00.4 chip-ID: 1022:1487
    class-ID: 0403
  Sound Server-1: ALSA v: k5.15.19-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.45 running: yes
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 05:00.0
    chip-ID: 8086:2723 class-ID: 0280
  IF: wlp5s0 state: down mac: <filter>
  Device-2: Intel I211 Gigabit Network vendor: Gigabyte driver: igb
    v: kernel port: e000 bus-ID: 06:00.0 chip-ID: 8086:1539 class-ID: 0200
  IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-3: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
    port: d000 bus-ID: 07:00.0 chip-ID: 10ec:8125 class-ID: 0200
  IF: enp7s0 state: down mac: <filter>
  Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-5:2
  Local Storage: total: 1.36 TiB used: 389.23 GiB (27.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Samsung
    model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
    rev: 2B2QEXM7 temp: 55.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
    model: SSD 970 EVO Plus 500GB size: 465.76 GiB block-size: physical: 512 B
    rev: 2B2QEXM7 temp: 38.9 C scheme: GPT
  Optical-1: /dev/sr0 vendor: PIONEER model: BD-RW BDR-S12U rev: 1.01
    dev-links: cdrom
  Features: speed: 125 multisession: yes audio: yes dvd: yes
  ID-1: / raw-size: 48.83 GiB size: 47.76 GiB (97.81%) used: 21.23 GiB (44.4%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:8 label: N/A
    uuid: 25c84d32-6a5e-4edb-9dd2-9c80609a1121
    used: 27.3 MiB (28.5%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:2
    label: N/A uuid: FA70-A083
  ID-3: /home raw-size: 848.5 GiB size: 834.11 GiB (98.30%)
    used: 252.15 GiB (30.2%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:9
    label: N/A uuid: 099741f6-d58b-4198-a82b-5dcbbb78f3c6
  ID-4: /run/media/joerg/606C8FAD6C8F7C92 raw-size: 269.82 GiB
    size: 269.82 GiB (100.00%) used: 89.65 GiB (33.2%) fs: ntfs
    dev: /dev/nvme1n1p3 maj-min: 259:4 label: N/A uuid: 606C8FAD6C8F7C92
  ID-5: /run/media/joerg/Daten raw-size: 195.31 GiB
    size: 195.31 GiB (100.00%) used: 26.19 GiB (13.4%) fs: exfat
    dev: /dev/nvme1n1p4 maj-min: 259:5 label: Daten uuid: 5683-E9ED
  ID-1: swap-1 type: partition size: 34.18 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p1 maj-min: 259:7 label: N/A
    uuid: 76088f3e-730f-404e-bab3-ae5ed01e39a5
  ID-1: /dev/nvme1n1p2 maj-min: 259:3 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme1n1p5 maj-min: 259:6 size: 524 MiB fs: ntfs label: N/A
    uuid: 5E16B36916B34137
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 1-1:2 info: Integrated Express IT8297 RGB LED Controller
    type: Keyboard driver: hid-generic,usbhid interfaces: 1 rev: 2.0
    speed: 12 Mb/s power: 100mA chip-ID: 048d:8297 class-ID: 0301
  Hub-2: 1-6:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 3-5:2 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
    class-ID: e001
  Hub-5: 3-6:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Device-1: 3-6.1:4 info: Olympus Optical Foot Switch RS-28 type: HID
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
    power: 100mA chip-ID: 07b4:0218 class-ID: 0300 serial: <filter>
  Device-2: 3-6.2:5 info: Razer USA Mamba 2018 (Wireless)
    type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 3 rev: 2.0
    speed: 12 Mb/s power: 500mA chip-ID: 1532:0072 class-ID: 0300
  Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-7: 5-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  Device-1: 5-2:2 info: Cooler Master ARES type: Keyboard,HID
    driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
    power: 100mA chip-ID: 2516:014d class-ID: 0300
  Hub-8: 6-0:1 info: Super-speed hub ports: 1 rev: 3.1 speed: 10 Gb/s
  Hub-9: 7-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 7-1:2 info: Cherry CHERRY Corded Device type: Keyboard,HID
    driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s
    power: 100mA chip-ID: 046a:c098 class-ID: 0300
  Hub-10: 7-3:3 info: Realtek RTS5411 Hub ports: 5 rev: 2.1 speed: 480 Mb/s
    chip-ID: 0bda:5411 class-ID: 0900
  Device-1: 7-3.4:4 info: Future Devices USB <-> Serial Cable
    type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s
    power: 100mA chip-ID: 0403:7a58 class-ID: 0000
  Hub-11: 8-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-12: 8-3:2 info: Realtek Hub ports: 3 rev: 3.2 speed: 5 Gb/s
    chip-ID: 0bda:0411 class-ID: 0900
  Device-1: 8-3.3:3 info: Genesys Logic SD Card Reader and Writer
    type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.2 speed: 5 Gb/s
    power: 896mA chip-ID: 05e3:0749 class-ID: 0806 serial: <filter>
  System Temperatures: cpu: 39.0 C mobo: N/A gpu: amdgpu temp: 57.0 C
    mem: 56.0 C
  Fan Speeds (RPM): cpu: 4041 fan-2: 0 fan-3: 0 gpu: amdgpu fan: 0
  Power: 12v: N/A 5v: N/A 3.3v: 1.68 vbat: 1.62 gpu: amdgpu watts: 28.00
  Processes: 455 Uptime: 17m wakeups: 1 Init: systemd v: 250 tool: systemctl
  Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1454 pacman: 1450 lib: 382
  flatpak: 0 snap: 4 Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.12
