After start my manjaro kde desktop, screen getting fridged; mouse and keyboard can’t move.
How can I solve this please?
System Info:
Manjaro version (Can’t remember, but latest stable version)
DE: KDE
System Info:
DE: KDE
Provide the information as described here:
Sorry, I can’t follow this. Screen getting fridged & mouse and keyboard didn’t response.
If your user description is still correct, then you should switch the 5.13 kernel that is EOL = end of life, and install a supported kernel.
If you still have access to TTY, run this commends:
sudo pacman-mirrors -f5 && sudo pacman -Syyu
sudo mhwd-kernel -i linux515
Reboot in the newly installed kernel and see if the issue persists.
Ok, you will have to do this i guess
https://wiki.archlinux.org/title/intel_graphics#Troubleshooting
If the file mentioned in the wiki dosn’t exist, create it and add those details …
Didn’t solved
Ok, so your system is fully updated, you boot in linux5.15 kernel, no graphics troubleshoot helps from the wiki … Is the issue also present on a new user?
And/Or on live media?
Didn’t check it. I can’t check
Can fresh new installation of manjaro can solve this problem??
Thanks, After a long time and huge try, this methods solve the problem.
