After sleep mode system cannot resume
my screen turns black with only mouse cursor visible after the system turns itself into sleep mode after a few hours of inactivity and after I log in
but such thing does not happen if I induce the sleep mode myself and return to activity after a few minutes
not sure what to do , could someone help ?
There are examples of this mentioned under Known Issues and Solutions in recent Update Announcement topics.
I’d suggest you look through those until you find the item(s) that might explain your issue, and follow the suggested advice given.
It’s generally requested that you read Update Announcement topics before creating a Support thread. Searching the forum for anything related can also be helpful.
Welcome to the Manjaro community.
As a new forum user, please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
Required Reading:
Resources:
Update Announcements:
The Update Announcements contain update related information and a Known Issues and Solutions section that should generally be checked before posting a request for support.
System Information:
Output of the following command (formatted according to forum requirements) may be useful for those wishing to help:
inxi --admin --verbosity=8 --filter --no-host --width
Be prepared to provide more information and outputs from other commands when asked.
sounds very similar to an issue I came across using the default linux612 on a fresh install. To fix this I went to Power Options and then I selected Power Off as the main Power Button behavior.
Also, you could swap to linuxLTS and test if the issue persists. Whenever possible try providing more details, like it was asked above.
Thanks , soundofthunder, i will search for that then
Thanks , Eruantien, i will try it
