pgtipz
22 February 2025 10:34
1
Thank you for reading my post. I’m grateful for your help. I’m not experienced in such matters - yet!
After a serious car accident, and things going in storage while I recovered for over a year, I upgraded my system as follows: CPU [AMD Rizen 5 5500], ASUS Motherboard, RAM 32mb, and GPU Nvidia RX5030.
However, I cannot load the desktop, [plasma]. I think the most recent kernel on my system is: version 5.4.210-1-MANJARO
Error messages follow:
“Proc: Bad Value for hidepid”
“(EE) No devices detected.
Fatal server error:
no screens found”
I looked for appropriate graphics drivers, and tried searching with mhwd:
$ sudo nvidia-settings
$ command not found
I tried updating the system also.
The following steps were tried but I’m still flummoxed.
https://www.x.org/wiki/FAQErrorMessages/#index8h2
Dear Manjaro-Users,
This will be my first post! I really like to help the community!
I’am new to Manjaro/Arch, but I’am Linux Expert (since 1996). Here a short Fixed-Howto from me:
By using mhwd for installing AMDGPU Drivers, I discovered a link problem, when I’am using
mhwd-gpu --status
for checking the status of my Radeon RX 6500 XT Graphic Card.
:: status
warning: could not find '/etc/X11/xorg.conf.d/90-mhwd.conf'!
To explain this:
Here is the following problem, that there is no stand…
Please advise. Much appreciated.
pgtipz
https://bbs.archlinux.org/viewtopic.php?id=223581
can you please report
sudo mhwd-kernel -li
sudo mhwd -li
inxi -Fza
pgtipz
22 February 2025 12:06
3
Thank you!
Here are the results of those 3 commands - the last one was too long to get every detail on screen.
Please see this howto:
[HowTo] Use public command-line pastebin services without installing anything!
for example:
inxi -zv8 | curl -F 'file=@-' https://0x0.st
then post the link that comes back
instead of pictures
pgtipz
22 February 2025 12:33
7
Thanks again! I don’t know how to uninstall [these kernels] from CLI. Sorry!
I’ll try booting into 5.4 and let you know how that goes. Cheers!
First install a supported one - or more than just one.
Boot (reboot) so that you are now running this kernel.
Then you can remove the old one.
mhwd-kernel -h
gives you instructions if you can’t use the GUI
Your video drivers
mhwd -li
look pretty old to me:
video-linux from 2018.05.04
do these commands again and direct the output to a pastebin service as shown above
the pictures are … not good enough
You can also remove kernel with the Manjaro settings manager.
And then install kernel 6.1 and 6.6.
Can you post the output of
inxi -Fza
instead of the picture ?
pgtipz
26 February 2025 17:27
12
Dear experts,
Sorry for my ineptitude but I have failed to work out how to use the paste bin services, and resorted to using character recognition from the images of the terminal data, i.e. results of > inxi -Fza
Please note, I have to login to windows 11 on my second HDD to send messages and I copy down any troubleshooting tips.
Perhaps it would be best to reinstall Manjaro, although all data will be lost? Also, I hope the new GPU and WM [Plasma] will be detected and start to work?
Thank you for any help you can offer. Data follows,
Screen/Page one of data:
[pytest2@LinuxMan ~]$ inxi -Fza
Kernel: 5.4.210-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID=<redacted> ro quiet console=tty3
Desktop: N/A
Type: Desktop
Mobo: ASUSTeK model: PRIME B450M-A Rev X.0x
UEFI: American Megatrends v: 3002 date: 06/17/2022
Info: 6-Core AMD Ryzen 5 5600X [MT MCP]
arch: Zen 3 family: 19 (0x19) model: 21 (0x15) stepping: 0 microcode: 0xa201205
Speed (MHz): avg: 3600 min/max: 2200/3700 boost: enabled
Core speeds (MHz): 1: 3600 2: 3599 3: 3600 4: 3598 5: 3599 6: 3597 7: 3600 8: 3599 9: 3600 10: 3599 11: 3599 12: 3599
Type: spectre_v2 mitigation: Retpolines, IBPB conditional, STIBP always-on, RSB filling
Type: srbds Not affected
Type: tsx_async_abort Not affected
Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: ASUSTeK
driver: nvidia v: 510.85.02
alternate: nouveau,nvidia_drm bus-ID: 09:00.0 chip-ID: 10de:2484
Display: server: X.org 1.20.13 driver: loaded: nvidia
OpenGL: renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2
v: 4.6.0 NVIDIA 510.85.02
direct render: Yes
Device-1: NVIDIA GA104 High Definition Audio
driver: snd_hda_intel bus-ID: 09:00.1 chip-ID: 10de:228b
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
driver: snd_hda_intel bus-ID: 0b:00.4 chip-ID: 1022:1487
Sound Server-1: ALSA v: k5.4.210-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: no
vendor: ASUSTeK driver: r8169 v: kernel
port: e000 bus-ID: 08:00.0 chip-ID: 10ec:8168
IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 3.64 TiB used: 462.14 GiB (12.4%)
ID-1: /dev/sda model: ST2000LX001-1RG174 family: FireCuda 2.5
size: 1.82 TiB block-size: physical: 512 B logical: 512 B sata: 3.1
speed: 6.0 Gb/s type: HDD rpm: 5400
ID-2: /dev/sdb model: ST1000DM010-2EP102 family: BarraCuda 3.5
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B sata: 3.0
speed: 6.0 Gb/s type: HDD rpm: 7200
ID-3: /dev/sdc model: WDC WD10EZEX-08WN4A0 family: Blue
size: 931.51 GiB block-size: physical: 512 B logical: 512 B
ID-1: / size: 906.86 GiB used: 462.11 GiB (50.9%) fs: ext4 dev: /dev/sdc2
ID-2: /boot/efi size: 511 MiB used: 31.5 MiB (6.2%) fs: vfat dev: /dev/sdc1
Swap: Alert: No swap data was found.
System Temperatures: cpu: 47.2 C mobo: N/A gpu: nvidia temp: 56 C
1: https://mirror.fcix.net/manjaro/stable/$repo/$arch
2: https://mirror.dacentec.com/manjaro/stable/$repo/$arch
3: https://mirror.clarkson.edu/manjaro/stable/$repo/$arch
4: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
5: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
Processes: 214 Uptime: 2m
Memory: 31.34 GiB used: 2.63 GiB (8.4%)
Init: systemd v: 251
Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: 1768
Shell: Bash v: 5.1.16
inxi: 3.3.22
page two
Sound Server-1: ALSA v: K5.10.136-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 16.1 running: no
Sound Server-4: PipeWire v: 0.3.56 running: yes
Device-1: Broadcom BCM43217 802.11b/g/n driver: bcma-pci-bridge
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 07:00.0 chip-ID: 14e4:43a9
vendor: ASUSTek PRIME B450M-A
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
SMART: yes state: enabled health: PASSED
written: 39.63 TiB Pre-Fail: attribute: Spin_Retry_Count value: 100
threshold: 97
written: 4.33 TiB Pre-Fail: attribute: Spin_Retry_Count value: 100
threshold: 97
ID-3: /dev/sdc model: WDC WD10EZEX-08WN4A0 family: Caviar Blue
speed: 6.0 Gb/s type: HDD scheme: MBR
ID-1: / raw-size: 922.42 GiB size: 906.86 GiB (98.31%) used: 462.11 GiB (51.0%) fs: ext4
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB used: 31.5 MiB (10.5%) fs: vfat
ID-1: swap-1 type: partition size: 8.0 GiB used: 0 KiB (0.0%)
No sensor data found, is lm-sensors configured?
Processes: 213 Uptime: 1m wakeups: 1
Memory: 91.21 GiB used: 5.53 GiB (6.1%)
Packages: 1761 (pacman), 3 (flatpak)
Shell: Bash 5.1.16
Page three
Device-1: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK driver: snd_hda_intel
bus-ID: 1002:1637 class-ID: 0403 gen: 4 speed: 8 GT/s lanes: 16 link-max: 16 chip-ID: 1022:15e3
Device-2: AMD Family 17h(19h) HD Audio vendor: ASUSTeK PRIME B450M-A driver: snd_hda_intel
bus-ID: 0a:00.4 chip-ID: 1022:15e3 gen: 4 speed: 16 GT/s lanes: 16
Sound Server-2: Camera type: USB driver: snd-usb-audio,uvcvideo
Sound Server-3: JACK v: 1.9.21 running: no
Sound Server-4: PulseAudio v: 16.1 running: no
Sound Server-5: PipeWire v: 0.3.56 running: yes
Device-1: Broadcom BCM43217 802.11b/g/n driver: bcma-pci-bridge v: N/A modules: bcma
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 08:00.0
chip-ID: 10ec:8168
IF: enp8s0 state: down mac: <filter>
Local Storage: total: 3.64 TiB used: 462.14 GiB (12.7%)
size: 1.82 TiB block-size: physical: 512 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s
type: HDD rpm: 5400
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B sata: 3.0 speed: 6.0 Gb/s
type: HDD rpm: 7200
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: HDD
type: HDD rpm: 5400
type: HDD rpm: 7200
That is quite a feat - and an, to me, almost incredible accomplishment
and massive overcomplification as well.
inxi -Fza
gives output
you want to make it available to others:
This does not tell you how to do it?
My take away from this would be:
inxi -Fza | curl -F 'file=@-' https://0x0.st
I get this link back:
https://0x0.st/8Anl.txt
and there you go … post that link
… visit that link - and see your output …
or mine, in this case
You don’t need AI - just employ your own I
ntelligence … your own not artificial intelligence, but hopefully your very own …
ps:
format the output to something readable - please!
this symbol in the editor here: → </>
I have (crudely) done the editing for you.
… much of the output is missing - was apparently missed by your AI
Can you post inxi -Fza
in one single logfile (output) ?
I tried and failed. I had no way to save the data and forward it from within Manjaro. I also tried install linux54-nvidia but all I got was a blinking curser at the terminal. I will have another attempt or start from scratch. Thanks!
Thanks again, Stephane, et al. I put the lastest version of Manjaro on USB stick and booted into the live system. However, the wifi did not work, so I was unable to find or install a compatible driver. My router is downstairs and I cannot connect to it by ethernet, so I’m still stuck.
omano
14 March 2025 12:14
19
Move the PC to the router and plug it then.
Thanks, folks! I used a spare network cable to connect the PC and reinstalled Manjaro, updated everything, and got my wifi working.
I never resolved the nvidia drivers problem but this is a solution that worked. I’m grateful for the help and advice so far. I’m glad to part of the Manjaro sphere.
