Hi, after changing my 1440x900 monitor to a 1080p one (using my hdmi port) the scaling is very large despite being set at only 100%.
Any ideas on how to fix it?
Thanks
Edit: Also the “move to monitor” option isn’t there any more when right clicking the icon in the task bar.
Edit 2: Also when click the “start” menu it appears on the wrong monitor.
provide formated output of:
inxi --admin --verbosity=7 --filter --width
is this a fresh install?
if no, did it started to happen after the recent update?
try switching kernels to 5.15 and 5.10 and try with them
set your monitor into normal scale, then change it to 1080 and check logs in ksystemlogs and post the formated output here
Here’s the output of the first command.
Kernel: 5.16.18-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
root=UUID=3a0f8b3a-d085-4c2b-993a-e302bc16fc74 rw quiet apparmor=1
Desktop: KDE Plasma v: 5.24.4 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: MSI product: MS-7845 v: 1.0
serial: <superuser required>
Mobo: MSI model: Z87-GD65 GAMING (MS-7845) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 1.12
date: 05/19/2015
Device-1: hidpp_battery_0 model: Logitech Wireless Gaming Mouse
status: discharging
RAM: total: 15.57 GiB used: 4.6 GiB (29.5%)
RAM Report:
Info: model: Intel Core i7-4770K bits: 64 type: MT MCP arch: Haswell
family: 6 model-id: 0x3C (60) stepping: 3 microcode: 0x28
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3499 high: 3500 min/max: 800/3500 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 3500 2: 3500 3: 3500
4: 3499 5: 3500 6: 3500 7: 3500 8: 3500 bogomips: 56021
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
fsgsbase fxsr ht ibpb ibrs invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdtscp rep_good sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid xsave xsaveopt xtopology xtpr
Type: l1tf
Device-1: NVIDIA GM107 [GeForce GTX 750 Ti] vendor: eVga.com. driver: nvidia
v: 510.60.02 alternate: nouveau,nvidia_drm pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1380 class-ID: 0300
Display: x11 server: X.Org v: 1.21.1.3 with: Xwayland v: 22.1.1
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
screens: 1
Screen-1: 0 s-res: 5760x2160 s-dpi: 304 s-size: 481x180mm (18.94x7.09")
s-diag: 514mm (20.22")
Monitor-1: DP-1 pos: primary,left res: 3840x2160 hz: 30 dpi: 52
size: 1872x1053mm (73.7x41.46") diag: 2148mm (84.56") modes: N/A
Monitor-2: HDMI-0 pos: primary,right res: 1920x1080 hz: 60 dpi: 305
size: 160x90mm (6.3x3.54") diag: 184mm (7.23") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 750 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 510.60.02 direct render: Yes
Device-1: Intel 8 Series/C220 Series High Definition Audio
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:8c20 class-ID: 0403
Device-2: NVIDIA GM107 High Definition Audio [GeForce 940MX]
vendor: eVga.com. driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0fbc class-ID: 0403
Sound Server-1: ALSA v: k5.16.18-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.49 running: yes
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:095a class-ID: 0280
IF: wlp3s0 state: down mac: <filter>
Device-2: Qualcomm Atheros Killer E220x Gigabit Ethernet
vendor: Micro-Star MSI driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 04:00.0 chip-ID: 1969:e091 class-ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
bus-ID: 3-13:5 chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 4.31 TiB used: 1.12 TiB (26.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 1103 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 840 EVO 500GB
type: SSD serial: <filter> rev: DB6Q scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST2000DL003-9VT166
type: HDD rpm: 5900 serial: <filter> rev: CC45 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 vendor: Toshiba model: DT01ACA200
type: HDD rpm: 7200 serial: <filter> rev: ABB0 scheme: MBR
ID-1: / raw-size: 223.27 GiB size: 218.71 GiB (97.96%)
used: 23.46 GiB (10.7%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 3a0f8b3a-d085-4c2b-993a-e302bc16fc74
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 8F98-9096
ID-3: /home raw-size: 420.12 GiB size: 412.46 GiB (98.18%)
used: 88.95 GiB (21.6%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: Home
uuid: 9606105b-f284-455c-813e-e80914cad9fa
ID-4: /run/media/calvin/2TB Storage raw-size: 1.82 TiB
size: 1.82 TiB (100.00%) used: 1.01 TiB (55.6%) fs: ntfs dev: /dev/sdc1
maj-min: 8:33 label: 2TB Storage uuid: B658DA5A58DA1947
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:8008 class-ID: 0900
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 14 rev: 2.0
Device-1: 3-3:2 info: Holtek Mechanical Keyboard type: Keyboard,HID
power: 100mA chip-ID: 04d9:1830 class-ID: 0300
Device-2: 3-4:3 info: Logitech Cordless Mouse Receiver type: Mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c537 class-ID: 0300
Device-3: 3-11:4 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-4: 3-13:5 info: Intel Bluetooth wireless interface type: Bluetooth
Hub-6: 4-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 57.0 C mobo: 27.8 C gpu: nvidia temp: 44 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 41%
Processes: 297 Uptime: 1h 2m wakeups: 6 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1384 pacman: 1370 lib: 401
flatpak: 8 snap: 6 Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16
running-in: yakuake inxi: 3.3.15
This install is like a month old if that, this was caused when I removed my old monitor and plugged in this 1080p one, it happened immediately after I rebooted after plugging in the new monitor.
My monitor is already set to normal scale and 1080p, should I change them, then change them back or just post the ksystemlog output?
I just had a look at ksystemlog and I don’t know how to provide it’s output.
I’ll try changing kernels (after googling how to do that) and get back to you.
i misunderstod you, i thought you changed your resolution, but you replace your monitors… you can change kernels from system settings/ kernel, install the 5.17 and the 5.15, reboot and in the grub menu (taping esc during boot) in advanced options select the desired kernel
ydar
20 April 2022 20:36
5
I see Wayland and you’re using nvidia. Probably best to log out and log back in but use Session Plasma X11
I also have a 750Ti and as far as I’m concerned, Wayland with Nvidia isn’t ready for prime-time use.
Can i have a look at the /etc/X11/mhwd.d/nvidia.conf file ?
I tried the other kernels and it’s still the same.
Here’s the nvidia.conf file
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 510.54
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
Option "NoLogo" "1"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section "Extensions"
Option "COMPOSITE" "Enable"
EndSection
Section "InputClass"
Identifier "Keyboard Defaults"
MatchIsKeyboard "yes"
Option "XkbOptions" "terminate:ctrl_alt_bksp"
EndSection
As far as using x11 I think I already am, I use auto login so I’ve never actually seen what option is being used by default but if I log out and try to log in using wayland I get an error about an sddm greeter file not being writable so I assume I’ve been using x11 this whole time.
Oh and just in case it’s important I have two monitors.
check system settings/ display and monitor/ display configuration, and check the ‘resolution’ and ‘scale’ options… try different one, and then return to defaults, and see… if it doesnt work, go to compositor and uncheck ‘enable on startup’ then reboot and check the screen… youll have to enable again the compositor by pressing alt + shift + f12
None of that worked I’m afraid, I imagine starting fresh and reinstalling manjaro would work. I’m thinking about doing that.
yes maybe as a last option… post the output of these:
mhwd -l
mhwd -li
mhwd -l output
> 0000:01:00.0 (0300:10de:1380) Display controller nVidia Corporation:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2021.12.18 false PCI
video-nvidia-470xx 2021.12.18 false PCI
video-nvidia-390xx 2021.12.18 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
mhwd -li output
Installed PCI configs:
try installing free drivers:
sudo mhwd -a pci free 0300
if everything went well, reboot
The driver installed fine but after rebooting the scaling is still huge
post again output of:
mhwd -li
and screenshot of system settings/ manjaro/ hardware configuration section
mhwd -li output
so lets try uninstalling the nvidia drivers:
sudo mhwd -r pci video-nvidia
if everyhing went well, reboot
Wow, I didn’t think this was gonna be solved but the scaling is normal now
Thank you!
wait were not done yet… now go to system settings/ hardware configuration and click on the auto install proprietary drivers button, if everything went well, reboot … we will see if with installed nvidia drivers the issue remains solved
Hmm, the install failed giving this output:
Starting
> Using config 'video-nvidia' for device: 0000:01:00.0 (0300:10de:1380) Display controller nVidia Corporation GM107 [GeForce GTX 750 Ti]
> Installing video-nvidia...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/nvidia/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
Processing classid: 0302
core downloading...
extra downloading...
community downloading...
multilib downloading...
resolving dependencies...
warning: dependency cycle detected:
warning: eglexternalplatform will be installed before its nvidia-utils dependency
Packages (9) egl-wayland-2:1.1.9+r3+g582b2d3-1 eglexternalplatform-1.1-2 lib32-nvidia-utils-510.60.02-1 libxnvctrl-510.60.02-1 linux510-nvidia-510.60.02-2 linux515-nvidia-510.60.02-3 linux516-nvidia-510.60.02-2 linux517-nvidia-510.60.02-4 nvidia-utils-510.60.02-1
Total Installed Size: 742.58 MiB
:: Retrieving packages...
nvidia-utils-510.60.02-1-x86_64 downloading...
linux515-nvidia-510.60.02-3-x86_64 downloading...
linux516-nvidia-510.60.02-2-x86_64 downloading...
lib32-nvidia-utils-510.60.02-1-x86_64 downloading...
libxnvctrl-510.60.02-1-x86_64 downloading...
egl-wayland-2:1.1.9+r3+g582b2d3-1-x86_64 downloading...
eglexternalplatform-1.1-2-any downloading...
checking keyring...
checking package integrity...
error: libxnvctrl: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/libxnvctrl-510.60.02-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] error: nvidia-utils: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/nvidia-utils-510.60.02-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] error: lib32-nvidia-utils: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/lib32-nvidia-utils-510.60.02-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] error: failed to commit transaction (invalid or corrupted package)
Error: pacman failed!
Error: script failed!
Done ...
run this command:
sudo pacman-key --refresh-keys
it could take some minutes, and ignore the possible errors, when its done refreshing, install again the nvidia drivers, and reboot
