Advanced Radio Player
Good day. I am glad to present a widget for the plasma 5.This is an internet radio streaming player.
Main functions:
  1. You can add / delete / edit stations in the list.
  2. Display album art (if possible)
  3. New feature: search for radio stations (using api radio-browser.info)
If you want to suggest improvements or corrections, write to me to dr@i-glu4it.ru or add comment on store.kde.org
And do not forget to rate the widget)
Been using it for some time and i prefer it over all alternatives, but was not ready yet for a nice review :slight_smile:
With the version 0.8, you brought it to another level.
Edit:
I thought to share an idea regarding the icon when placed in the Panel. By default in ~/.local/share/plasma/plasmoids/org.kde.plasma.advancedradio/contents/ui/main.qml from line 209:
        PlasmaCore.IconItem {
            anchors.fill: parent
            source: plasmoid.configuration.icon
            width: parent.width
            height: parent.height
            opacity: isPlaying() ? 0.5 : 1
            source: 'media-playback-start'
            visible: isPlaying()
            anchors.horizontalCenter: parent.horizontalCenter
            anchors.verticalCenter: parent.verticalCenter
            height: parent.height * 0.5
What i did was to change it to:
            width: parent.width
            opacity: isPlaying() ? 1 : 0.5
            //source: 'media-playback-start'
            height: parent.height * 1
because i use the Papirus icons, but not only that, is because the small icon from source: 'media-playback-start' is not helping visually much (just a personal opinion), and by reversing the stop/play state transparency, it helps visually to identify if the player is
OFF
or if the player is ON
In Papirus icons there are 3 icons for "radio player state" (used by radiotray) when connecting or is off or is on
I don't think the connecting part is important because it starts almost instant regardless the station, but maybe have a slight better visual identification of the player state would be nice. Even as is now is super neat, so don't bother if requires too much coding :wink:
Breeze has only one radio icon, the one used by default, and i think is the necessary and sufficient icon, so once again is justified not to complicate things, but i thought is worth mentioning this.
Cheers and thanks for such wonderful widget. I have to change the vote from 9 to 10 anyway :smiley:
