Reason ; Non solved Confict between
the pamac-gtk - 11.7.2-1 (useful for th last issue of Manjaro KDE)
against
pamac-gtk3 - 10.7.0-1 (still mounted into the last Manjaro packages)
So
1/ unmount pamac-gtk3
and
2/ mount pamac gtk11.2.1
In the KONSOLE
“sudo pacman -Syu pamac-gtk”
But I’m not sure that the new GUI is so clearly presented …
It certainly looks that way. You failed to mention which pamac GUI is crashing…
non solved Conflict between... is clearly not a valid error message, perhaps ‘non resolved’. Then again, you should not have pamac-gtk with pamac-gtk3… it should not be possible to have both installed because they are conflicted and when you install one, the other should be removed:
In Konsole, launching pamac-manager:
Summary
❯ pamac-manager
(pamac-manager:62663): Gtk-WARNING **: 08:45:17.750: Unknown key gtk-modules in /home/ben/.config/gtk-4.0/settings.ini
(pamac-manager:62663): Adwaita-WARNING **: 08:45:17.858: Using GtkSettings:gtk-application-prefer-dark-theme with libadwaita is unsupported. Please use AdwStyleManager:color-scheme instead.
pamac-gtk and pamac-gtk3 are never ‘mounted’.
In Konsole - depending on what desktop you have, you might remove ONE of those pamac-gtk entries.
Only one version of pamac-gtk can be installed.
Which one is installed?
pamac-gtk3 10.7.0-1 extra
A Package Manager based on libalpm with AUR and Appstream support (GTK3)
pamac-gtk 11.7.2-1 [Installed] extra
A Package Manager based on libalpm with AUR and Appstream support (GTK4)
Try to install another one:
pamac install pamac-gtk3
Resolving dependencies...
Checking inter-conflicts...
To install (1):
pamac-gtk3 10.7.0-1 extra 190.7 kB
To remove (1):
pamac-gtk 11.7.2-1 (Conflicts With: pamac-gtk3) extra
You only end up with ONE, because they conflict. If you have both, then remove one.
Many folks use pamac-gtk3, I’m doing okay with pamac-gtk on plasma.
HI
This post was written in the Plasma KDE section.
I always run on a stable, updated MANJARO configuration.
Pamac - Gtk and pamac - gtk3 have been in conflict since the last release on January… This has never happened before. Yet MANJARO is a robust distribution that I have been using for more than 10 years.
Thanks a lot - Sincerly
Philline00 - Newbie forever.
pamac-gtk3 and pamac-gtk have always been marked as conflicting packages since the packages were split in 2023
$ pamac info pamac-gtk
Version : 11.7.2-1
Description : A Package Manager based on libalpm with AUR and Appstream support (GTK4)
Conflicts With : pamac-gtk3
$ pamac info pamac-gtk3
Version : 10.7.0-1
Description : A Package Manager based on libalpm with AUR and Appstream support (GTK3)
I replaced pamac-gtk with pamac-gtk3.
Confirm that pamac-gtk3 well installed and well run under Plasma KDE.
The GUI presentation of pamac-gtk3 is more smart.
