Hello,
I’ve started playing around with aconfmgr
on my laptop (manjaro KDE) and wanted to ask:
Can the resulting data be used to configure manjaro on a completely different hardware?
Is it possible to configure using the resulting data a different arch-based distro (native arch, EndeavourOS etc.)?
TIA
Anything is possible. I don’t know about the specific script you mention.
If the configuration is a backup of your personal settings - they are applicable to any Linux system which provides the theming packages used when you saved the configs.
I created something similar some time ago to be able to transfer common configs and package list to other Manjaro systems.
Specifically for Plasma there is konsave in AUR
Hi @ForeverNoob ,
I’ve seen it and played with it before. I, personally, think it’s cool.
As long as you stick with Arch(-based) distros, I don’t think you’ll have a problem.
The best way to find out, the really fail-safe way, is to test it and see what happens.
Hope this means something!
It must however be set up first, because the AUR version comes with a blank config. I’ve written a HowTo about it.
As many of you have in the meantime painfully come to experience, KDE Plasma, for all the greatness that it offers, does tend to blow up in your face every once in a while, necessitating that you delete all of your Plasma configuration files and start setting up things to your liking from scratch all over again.
(Yes, been there, done that, have the T-shirt and the bumper sticker. )
Well, there is a way you can protect yourself against this calamity, and as a bonus, i…
