A error on running systemctl --failed
when i run ‘sudo systemctl --failed’ :
Please, next time share the output error as text, not screenshots!
You can mask the service:
sudo systemctl mask systemd-backlight@leds\:dell\:\:kbd_backlight.service
or maybe you need to use this kernel boot parameter:
acpi_osi='!Windows 2012'
I dont know where to include `acpi_osi=’!Windows 2012’
plese help me how to do it.
Is a kernel boot parameter that you add inside /etc/default/grub in the GRUB_CMDLINE_LINUX_DEFAULT line … right after quiet
You have to run from terminal:
sudo update-grub
after you modify it
More about ACPI kernel parameters here:
I have tried but no progress sir :
I have edited /etc/default/grub :
GRUB_DEFAULT=saved
GRUB_TIMEOUT=4
GRUB_TIMEOUT_STYLE=menu
GRUB_DISTRIBUTOR=“Manjaro”
GRUB_CMDLINE_LINUX_DEFAULT=“acpi_osi=‘Windows 2015’ acpi_rev_override=2 quiet apparmor=1 security=apparmor udev.log_priority=3 bootsplash.bootfile=bootsplash-themes/manjaro/bootsplash nvme_core.default_ps_max_latency_us=5500”
GRUB_CMDLINE_LINUX=""
and with acpi_rev_override= # (#1 to 5)
That is why i mentioned to mask the service … i don’t think you will get the keyboard light working anyway … What dell laptop model you have, maybe share?
inxi -Fazy
inxi -Fazy :
  Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
  root=UUID=2ec2d427-7779-48cc-8f87-e89b124d5f4a ro "acpi_osi=Windows 2015"
  Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
  Distro: Manjaro Linux
  Type: Laptop System: Dell product: Inspiron 15-3567 v: N/A serial: <filter>
  Chassis: type: 9 serial: <filter>
  Mobo: Dell model: 0D53F5 v: A00 serial: <filter> UEFI: Dell v: 2.13.0
  date: 08/13/2020
  ID-1: BAT0 charge: 14.7 Wh condition: 14.7/41.4 Wh (36%) volts: 16.8/14.8
  model: SMP DELL VN3N047 type: Li-ion serial: <filter> status: Full
  Info: Dual Core model: Intel Core i5-7200U bits: 64 type: MT MCP
  arch: Amber/Kaby Lake note: check family: 6 model-id: 8E (142) stepping: 9
  microcode: DE L2 cache: 3 MiB
  bogomips: 21607
  Speed: 800 MHz min/max: 400/3100 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
  4: 800
  Type: l1tf
  Device-1: Intel HD Graphics 620 vendor: Dell driver: i915 v: kernel
  bus ID: 00:02.0 chip ID: 8086:5916
  Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 / Radeon
  520 Mobile]
  vendor: Dell driver: radeon v: kernel alternate: amdgpu bus ID: 01:00.0
  chip ID: 1002:6660
  Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
  bus ID: 1-5:3 chip ID: 0bda:5769 serial: <filter>
  Display: x11 server: X.Org 1.20.10 compositor: kwin_x11
  driver: ati,intel,radeon unloaded: modesetting alternate: fbdev,vesa
  display ID: :0 screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
  s-diag: 414mm (16.3")
  Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5")
  diag: 389mm (15.3")
  OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.3.1
  direct render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
  v: kernel alternate: snd_soc_skl bus ID: 00:1f.3 chip ID: 8086:9d71
  Sound Server: ALSA v: k5.9.16-1-MANJARO
  Device-1: Intel Wireless 3165 driver: iwlwifi v: kernel port: e000
  bus ID: 02:00.0 chip ID: 8086:3165
  Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
  driver: r8169 v: kernel port: d000 bus ID: 03:00.0 chip ID: 10ec:8136
  Local Storage: total: 931.51 GiB used: 255.36 GiB (27.4%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
  size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
  serial: <filter> rev: SDM3
  ID-1: / raw size: 130 GiB size: 126.96 GiB (97.66%) used: 10 GiB (7.9%)
  fs: ext4 dev: /dev/sda1 maj-min: 8:1
  ID-2: /boot/efi raw size: 512 MiB size: 511 MiB (99.80%)
  used: 312 KiB (0.1%) fs: vfat dev: /dev/sda2 maj-min: 8:2
  ID-3: /home raw size: 801.01 GiB size: 787.44 GiB (98.31%)
  used: 245.37 GiB (31.2%) fs: ext4 dev: /dev/sda3 maj-min: 8:3
  System Temperatures: cpu: 49.0 C mobo: 47.0 C gpu: radeon temp: 45.0 C
  Fan Speeds (RPM): cpu: 0
  Processes: 204 Uptime: 4m wakeups: 1 Memory: 7.64 GiB used: 2.34 GiB (30.6%)
  Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages: pacman: 1270 lib: 380
  flatpak: 0 Shell: Bash v: 5.1.0 running in: konsole inxi: 3.2.01
Right, so, by default that model has no keyboard backlight unless you custom update it. Only thing left is for you to
thank you very much sir
