718 Pending updates. Cannot update system
This is a list of the files that seem to be stopping my update: It looks like a lot of them are from the AUR
Ocamlnet
Ocaml-lov
Ocaml-ocplib-endian
Ocaml-ppx
Ocaml-xmlm
Ocaml-yojson
Ocaml-react build files
Ocaml-ppxlib
Ocaml-seq
Ocaml-lwt
Gapi-ocaml
Libkipi
Normcap
Yacreader
Parsec-bin
Python-dataparser
Libpdfium-nojs
Electron16
Auto-cpufreq
Python-pep517
ocaml-compiler-libs'
Ocaml-ounit build
Transcode
Komikku
Python-jarowinkler
zoom
Ocaml-extlib
Google Chrome Build files
Google-Docs-bin
Tesseract-data-best-jpn
Libunnar
Python-rarfile
Python-tesserocr
Anki Build file
Zoom
jre-openjdk and jre-openjdk-headless are in conflict
I dont know about the myriad of third party packages.
But as to the last part …
As always, check the update announcement thread…
It didn’t work when I ran it
 core is up to date
 extra is up to date
 community is up to date
 multilib is up to date
:: Some packages should be upgraded first...
resolving dependencies...
Packages (1) archlinux-keyring-20231207-1
Total Download Size:   1.15 MiB
Total Installed Size:  1.64 MiB
Net Upgrade Size:      0.02 MiB
:: Proceed with installation? [Y/n] Y
:: Retrieving packages...
 archlinux-keyring-20231207-1-any                                 1180.2 KiB   323 KiB/s 00:04 [#######################################################] 100%
(1/1) checking keys in keyring        [#######################################################] 100%
(1/1) checking package integrity                                                               [#######################################################] 100%
(1/1) loading package files        [#######################################################] 100%
(1/1) checking for file conflicts                                                              [#######################################################] 100%
(1/1) checking available disk space                                                            [#######################################################] 100%
(1/1) Creating Timeshift snapshot before upgrade...
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
(1/1) upgrading archlinux-keyring                                                              [#######################################################] 100%
==> Appending keys from archlinux.gpg...
==> Disabling revoked keys in keyring...
  -> Disabled 3 keys.
==> Updating trust database...
gpg: key 786C63F330D7CB92: no user ID for key signature packet of class 10
gpg: key 1EB2638FF56C0C53: no user ID for key signature packet of class 10
gpg: marginals needed: 3  completes needed: 1  trust model: pgp
gpg: depth: 0  valid:   1  signed:  25  trust: 0-, 0q, 0n, 0m, 0f, 1u
gpg: depth: 1  valid:  25  signed: 101  trust: 0-, 0q, 0n, 25m, 0f, 0u
gpg: depth: 2  valid:  73  signed:  28  trust: 73-, 0q, 0n, 0m, 0f, 0u
gpg: next trustdb check due at 2024-01-21
(1/3) Reloading system manager configuration...
(2/3) Arming ConditionNeedsUpdate...
(3/3) Refreshing PackageKit...
:: jdk-openjdk and jre-openjdk are in conflict. Remove jre-openjdk? [y/N] y
:: jdk-openjdk and jre-openjdk-headless are in conflict. Remove jre-openjdk-headless? [y/N] y
:: removing jre-openjdk breaks dependency 'jre-openjdk>=17' required by tachidesk-jui
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
You didnt include what you actually ran.
If you need jre … then thats what you should pick.
sudo pacman -Syuu jre-openjdk
This is also because you have some other unsupported package tachidesk-jui installed (which is also orphaned by the way).
My more full suggestion is to remove that package.
I ran:
After running what you told me
 sudo pamac remove tachidesk-jui         1 ✘  43s 
[sudo] password for sham:
Preparing...
Checking dependencies...
To remove (1):
  tachidesk-jui  1.3.2-1
Total removed size: 321.1 MB
Apply transaction ? [y/N] y
Removing tachidesk-jui (1.3.2-1)...        [1/1]
Arming ConditionNeedsUpdate...        [1/3]
Refreshing PackageKit...        [2/3]
Updating the desktop file MIME type cache...        [3/3]
    ~  pacman -Syuu jre-openjdk         ✔  9s 
error: you cannot perform this operation unless you are root.
    ~  sudo sudo pacman -Syuu jre-openjdk         1 ✘
 core is up to date
 extra is up to date
:: Replace appstream-qt with extra/appstream-qt5? [Y/n] Y
:: Replace grub-update with core/update-grub? [Y/n] Y
:: Replace kdsoap with extra/kdsoap-qt5? [Y/n] Y
:: Replace kgamma5 with extra/kgamma? [Y/n] Y
warning: kpeoplevcard: downgrading from version 0.1+r38.32d50a9-1 to version 0.1-2
:: Replace kuserfeedback with extra/kuserfeedback5? [Y/n] Y
:: Replace libkdcraw with extra/libkdcraw5? [Y/n] Y
:: Replace libqaccessibilityclient with extra/libqaccessibilityclient-qt5? [Y/n] Y
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
:: jre-openjdk and jre-openjdk-headless are in conflict
I dont know why it wouldnt do the replace …
but if you dont need that tachidesk package … then you probably dont need jre and we are back to the original suggestion;
sudo pacman -Sy jdk-openjdk && sudo pacman -Suu
In the past the JDK part of Java was depending on the JRE package, which only shipped the runtime environment. With resent changes upstream the JDK is now shipping the runtime environment as it should be, hence the conflict with JRE. So if you are not in coding a JDK is normally not needed but would also work if you might do coding later. More info here: Arch Linux - News: Incoming changes in JDK / JRE 21 packages may require manual intervention
As for the other packages, it was said many times aur is unsupported, for advanced users and unstable branch. You can start with removing orphans, and then if needed anything else stopping the update. And when you update you can reinstall / rebuild what you need.
I ran that and got this
sudo pacman -Sy jdk-openjdk && sudo pacman -Suu         1 ✘  12m 59s 
 core is up to date
 extra                                                               8.6 MiB   380 KiB/s 00:23 [#######################################################] 100%
warning: jdk-openjdk-21.u35-8 is up to date -- reinstalling
Packages (1) jdk-openjdk-21.u35-8
Total Installed Size:  1136.47 MiB
Net Upgrade Size:         0.00 MiB
(1/1) reinstalling jdk-openjdk        [#######################################################] 100%
(1/4) Arming ConditionNeedsUpdate...
(2/4) Refreshing PackageKit...
(3/4) Updating icon theme caches...
(4/4) Updating the desktop file MIME type cache...
:: installing kxmlgui5 (5.113.0-1) breaks dependency 'kxmlgui' required by libkipi
:: installing kservice5 (5.113.0-1) breaks dependency 'kservice' required by libkipi
Further complications from other unsupported packages. *kipi* has been deprecated for a bit.
Remove any *kipi* packages.
I haven’t found any packages that say kipi
…not libkipi ?
(the other one commonly found would be kipi-plugins, but I did not see it mentioned here [yet] … though it begs the question why libkipi was installed. But I think it would be a tireless and fruitless endeavor to ask ‘why’ about any packages at this point.)
I don’t see that libkipi is installed.
pacman -Qs kipi
If it is there remove it
sudo pacman -Rns libkipi
Thanks, I removed it.
Great. You should be able to continue now.
And since you did the install already … its probably fine to just do
sudo pacman -Syuu
Thank you! sudo pacman -Syuu worked.
But now it says I have 33 updates available
And now you are finally synced, and from now on regular updates should do.
sudo pacman -Syu
But remember to pay attention and check update announcements if needed.
Thanks will do!
