Fresh install of Manjaro Gnome on Thinkpad P15 gen 2. Suspending looks ok, logs show that kernel is entering deep sleep. Waking up looks like power off. Kernel panic on wake up?
inxi -Fazy ✔ 14s
Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=6609fa01-edfc-4f19-ba31-2bbbf429b330 rw quiet splash apparmor=1
Desktop: GNOME 41.2 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.0
Type: Laptop System: LENOVO product: 20YQ004JUS v: ThinkPad P15 Gen 2i
Mobo: LENOVO model: 20YQ004JUS v: SDK0J40697 WIN
serial: <superuser required> UEFI: LENOVO v: N37ET34W (1.15 )
date: 09/01/2021
ID-1: BAT0 charge: 84.6 Wh (88.7%) condition: 95.4/94.0 Wh (101.5%)
volts: 13.1 min: 11.5 model: Celxpert 5B10W13959 type: Li-poly
serial: <filter> status: Charging cycles: 1
Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
arch: Tiger Lake family: 6 model-id: 0x8D (141) stepping: 1 microcode: 0x3C
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 10 MiB desc: 8x1.2 MiB
L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 905 high: 1039 min/max: 800/4600 scaling:
driver: intel_pstate governor: powersave cores: 1: 894 2: 801 3: 982 4: 907
5: 989 6: 979 7: 801 8: 1039 9: 943 10: 809 11: 980 12: 801 13: 963
14: 1024 15: 775 16: 801 bogomips: 73744
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Lenovo driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:9a60 class-ID: 0300
Device-2: NVIDIA vendor: Lenovo driver: nvidia v: 495.44
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1fbc
class-ID: 0300
Device-3: Acer Integrated Camera type: USB driver: uvcvideo bus-ID: 3-4:3
chip-ID: 5986:212b class-ID: 0e02
Display: x11 server: X.org 1.21.1.2 compositor: gnome-shell driver:
loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
Device-1: Intel Tiger Lake-H HD Audio vendor: Lenovo
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:43c8 class-ID: 0401
Device-2: NVIDIA vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.42 running: yes
Device-1: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel
bus-ID: 09:00.0 chip-ID: 8086:2725 class-ID: 0280
IF: wlp9s0 state: up mac: <filter>
Device-2: Intel Ethernet I225-V vendor: Lenovo driver: igc v: kernel
port: N/A bus-ID: 0b:00.0 chip-ID: 8086:15f3 class-ID: 0200
IF: enp11s0 state: down mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 3-14:4 chip-ID: 8087:0032 class-ID: e001
Local Storage: total: 953.87 GiB used: 16.44 GiB (1.7%)
model: MZVL21T0HCLR-00BL7 size: 953.87 GiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
rev: AL2QGXA7 temp: 43.9 C scheme: GPT
ID-1: / raw-size: 67.38 GiB size: 65.82 GiB (97.69%) used: 14.11 GiB (21.4%)
fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
ID-2: /boot/efi raw-size: 1000 MiB size: 998 MiB (99.80%)
used: 288 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p8 maj-min: 259:8
ID-3: /home raw-size: 771.48 GiB size: 758.31 GiB (98.29%)
used: 2.33 GiB (0.3%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
ID-1: swap-1 type: partition size: 39.06 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p6 maj-min: 259:6
System Temperatures: cpu: 43.0 C mobo: N/A
Fan Speeds (RPM): fan-1: 0
Processes: 359 Uptime: 17m wakeups: 4 Memory: 31.08 GiB
used: 2.78 GiB (8.9%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1174 lib: 301 flatpak: 0 Shell: Zsh v: 5.8
running-in: gnome-terminal inxi: 3.3.11
tried 5.10 - same behavior on wake up, also loses wifi adapter.
tried 5.4 - could not boot
