Since mid january I’ve had issues with hibernate. Looking at the logs I find that I upgraded from kernel 5.10.2 to 5.10.7 on January 23rd. It might have been at that day the issue started. I tried 5.10.12 and 5.10.15, having the same problem. I downgraded to 5.9.16 for two weeks, and the problem was gone. So I tried 5.10.18 for a few days now, and the problem is back.
The problem is that one out of 20ish times, hibernate fails with the error [quote]Image allocation is 228143 pages short[/quote]
The number is different every time.
I’m using swap partition for hibernate data. At first I thought there was not enough free space in the swap partition, but that is ruled out.
# free -h
total used free shared buff/cache available
Mem: 23Gi 10Gi 12Gi 243Mi 591Mi 12Gi
Swap: 30Gi 2,8Gi 27Gi
As this seems to be fixed by downgrading kernel, I guess config issues can be ruled out. (I have not made changes to kernel config.)
Googling this makes me feel alone with this issue. Is there any logging options that can be turned on to get more information on whats happening?
Relevant log:
mars 06 21:25:09 pl140 systemd-sleep[818812]: Suspending system...
mars 06 21:25:09 pl140 kernel: PM: hibernation: hibernation entry
mars 06 21:25:16 pl140 kernel: Filesystems sync: 0.001 seconds
mars 06 21:25:16 pl140 kernel: Freezing user space processes ... (elapsed 0.002 seconds) done.
mars 06 21:25:16 pl140 kernel: OOM killer disabled.
mars 06 21:25:16 pl140 kernel: PM: hibernation: Marking nosave pages: [mem 0x00000000-0x00000fff]
mars 06 21:25:17 pl140 kernel: PM: hibernation: Marking nosave pages: [mem 0x0009f000-0x000fffff]
mars 06 21:25:17 pl140 kernel: PM: hibernation: Marking nosave pages: [mem 0x56559000-0x56e58fff]
mars 06 21:25:17 pl140 kernel: PM: hibernation: Marking nosave pages: [mem 0x5ca1d000-0x5cad3fff]
mars 06 21:25:17 pl140 kernel: PM: hibernation: Marking nosave pages: [mem 0x6d06f000-0x6fc4efff]
mars 06 21:25:17 pl140 kernel: PM: hibernation: Marking nosave pages: [mem 0x6fc50000-0xffffffff]
mars 06 21:25:17 pl140 kernel: PM: hibernation: Basic memory bitmaps created
mars 06 21:25:17 pl140 kernel: PM: hibernation: Preallocating image memory
mars 06 21:25:17 pl140 kernel: PM: hibernation: Image allocation is 228143 pages short
mars 06 21:25:17 pl140 kernel: acpi LNXPOWER:05: Turning OFF
mars 06 21:25:17 pl140 kernel: acpi LNXPOWER:00: Turning OFF
mars 06 21:25:17 pl140 kernel: PM: hibernation: Basic memory bitmaps freed
mars 06 21:25:17 pl140 kernel: OOM killer enabled.
mars 06 21:25:17 pl140 kernel: Restarting tasks ... done.
mars 06 21:25:17 pl140 kernel: PM: hibernation: hibernation exit
mars 06 21:25:16 pl140 systemd-sleep[818812]: Failed to suspend system. System resumed again: Cannot allocate memory
mars 06 21:25:17 pl140 systemd[1]: systemd-hibernate.service: Main process exited, code=exited, status=1/FAILURE
can you add
sudo mhwd-kernel -i linux54
sudo mhwd-kernel -i linux511
and retry with others ( press Esc to see Grub on restart /boot )
Shouldn’t it be,
And also, you made a spelling mistake:
Should be “see”, as in:
“( Esc to see Grub on restart /boot )”
As the problem does not exist in 5.9.16, whats the point of installing 5.4?
I’ll try 5.11 from next reboot
5.9 is EOL (End Of Life) so not supported any more. Neither does it get any more updates or security updates.
Both 5.4 and 5.10 are LTS (Long Term Support) versions, so would be supported for longer.
I’ll try 5.11 first. The only thing usage of 5.4 will possibly tell is if the change (what ever it was) that broke hibernate from 5.10.2 to 5.10.7 is also applied to 5.4. That could be useful knowledge if updates to current kernels are applied to old LTS kernels as well. I don’t know if that is how updates to the old LTS kernels are updated though.
Is there any way to get a hold of the manjaro default kernel config files? I’d like to compare the manjaro configs for 5.9.16, 5.10.2 and 5.10.7. As I seem to be alone with this issue, I doubt this is a general kernel bug.
I have absolutely NO idea.
I will tell you, however, sometimes patches to problems get backported from never to older versions of the kernels. So that’s something to keep in mind as well.
Yeah. So if the same issue exists with 5.4, the cause is probably one of those that were backported. That probably reduces the number of possible causes. But I’m leaning towards the cause to be kernel config related, which is special for manjaro.
… not sure if that is what you wanted to see:
zcat /proc/config.gz
will show the configuration of the running kernel
dump the output into a file for each kernel and then compare the files with diff or something else
zcat /proc/config.gz > kernelconfig_xyz
Thanks. That’s exactly what I wanted. I now have the configs for the currently available kernels - 5.11.1, 5.10.18 and 5.9.16. But the most important ones, 5.10.2 and 5.10.7 are not available. They are important because I know the change causing this issue happened between these two.
perhaps you can still find them in the pacman cache
/var/cache/pacman/pkg
and can temporarily install them that way
just out of curiosity:
Did you find any changes in between the versions that you could compare so far?
They are not in my cache.
There are quite a few changes between the 5.9.16 and 5.10.18. The config for 5.9 is about 10% more lines than 5.10. 5.9 has a lot of stuff compiled as modules. 5.10 doesn’t have that much enabled, but what it has is mostly compiled into the kernel. Just a few things (mostly within crypto have gone from built in (in 5.9) to modules (in 5.10).
What might look most relevant is
< CONFIG_MICROCODE_OLD_INTERFACE=y
< CONFIG_ARCH_MEMORY_PROBE=y
# Memory Management options
< # CONFIG_CMA is not set
> CONFIG_CMA=y
> # CONFIG_CMA_DEBUG is not set
> CONFIG_CMA_DEBUGFS=y
> CONFIG_CMA_AREAS=7
# User Modules And Translation Layers
< CONFIG_MTD_SWAP=m
> # CONFIG_MTD_SWAP is not set
< CONFIG_PSTORE_RAM=y
> CONFIG_PSTORE_RAM=m
A cleaned up full diff
comparing 5.9.16 to 5.10.18
> CONFIG_LLD_VERSION=0
## General setup
# IRQ subsystem
> CONFIG_GENERIC_IRQ_INJECTION=y
## General setup
# RCU Subsystem
> CONFIG_TASKS_TRACE_RCU=y
# General setup
> CONFIG_LD_ORPHAN_WARN=y
< CONFIG_EXPERT=y
> # CONFIG_EXPERT is not set
< # CONFIG_UID16 is not set
> CONFIG_UID16=y
< # CONFIG_SYSFS_SYSCALL is not set
> CONFIG_SYSFS_SYSCALL=y
< CONFIG_PROCESSOR_SELECT=y
< CONFIG_GART_IOMMU=y
> # CONFIG_GART_IOMMU is not set
> # CONFIG_MICROCODE_OLD_INTERFACE is not set
< CONFIG_X86_MSR=m
> CONFIG_X86_MSR=y
< CONFIG_X86_CPUID=m
> CONFIG_X86_CPUID=y
< # CONFIG_X86_CPA_STATISTICS is not set
> CONFIG_X86_CPA_STATISTICS=y
> # CONFIG_ARCH_MEMORY_PROBE is not set
< CONFIG_SECCOMP=y
< CONFIG_RANDOMIZE_MEMORY_PHYSICAL_PADDING=0x1
> CONFIG_RANDOMIZE_MEMORY_PHYSICAL_PADDING=0xa
# Power management and ACPI options
< # CONFIG_SUSPEND_SKIP_SYNC is not set
< CONFIG_PM_AUTOSLEEP=y
> # CONFIG_PM_AUTOSLEEP is not set
< CONFIG_PM_WAKELOCKS=y
> # CONFIG_PM_WAKELOCKS is not set
< CONFIG_PM_WAKELOCKS_LIMIT=100
< CONFIG_PM_WAKELOCKS_GC=y
< CONFIG_PM_ADVANCED_DEBUG=y
> # CONFIG_PM_ADVANCED_DEBUG is not set
< # CONFIG_DPM_WATCHDOG is not set
< CONFIG_PM_GENERIC_DOMAINS_OF=y
< CONFIG_ACPI_EC_DEBUGFS=y
> CONFIG_ACPI_EC_DEBUGFS=m
< CONFIG_ACPI_AC=m
> CONFIG_ACPI_AC=y
< CONFIG_ACPI_BATTERY=m
> CONFIG_ACPI_BATTERY=y
< CONFIG_ACPI_VIDEO=y
> CONFIG_ACPI_VIDEO=m
< CONFIG_ACPI_PROCESSOR_AGGREGATOR=y
> CONFIG_ACPI_PROCESSOR_AGGREGATOR=m
< # CONFIG_ACPI_REDUCED_HARDWARE_ONLY is not set
> CONFIG_ACPI_DPTF=y
> CONFIG_DPTF_PCH_FIVR=m
> CONFIG_ACPI_CONFIGFS=m
< CONFIG_SFI=y
> # CONFIG_SFI is not set
< CONFIG_CPU_FREQ_GOV_POWERSAVE=m
> CONFIG_CPU_FREQ_GOV_POWERSAVE=y
< CONFIG_CPU_FREQ_GOV_USERSPACE=m
> CONFIG_CPU_FREQ_GOV_USERSPACE=y
< CONFIG_CPU_FREQ_GOV_CONSERVATIVE=m
> CONFIG_CPU_FREQ_GOV_ONDEMAND=y
< CONFIG_CPU_FREQ_GOV_ONDEMAND=m
> CONFIG_CPU_FREQ_GOV_CONSERVATIVE=y
< CONFIG_CPUFREQ_DT=m
> CONFIG_CPUFREQ_DT_PLATDEV=y
< # CONFIG_PCI_CNB20LE_QUIRK is not set
< # CONFIG_ISA_BUS is not set
< CONFIG_DMI_SYSFS=m
> CONFIG_DMI_SYSFS=y
< CONFIG_KVM_WERROR=y
# EFI (Extensible Firmware Interface) Support
> CONFIG_EFI_VARS_PSTORE=y
> # CONFIG_EFI_VARS_PSTORE_DEFAULT_DISABLE is not set
> CONFIG_EFI_BOOTLOADER_CONTROL=m
> CONFIG_EFI_CUSTOM_SSDT_OVERLAYS=y
# General architecture-dependent options
> # CONFIG_STATIC_CALL_SELFTEST is not set
> CONFIG_HAVE_ARCH_SECCOMP=y
> CONFIG_SECCOMP=y
> CONFIG_HAVE_STATIC_CALL=y
> CONFIG_HAVE_STATIC_CALL_INLINE=y
> CONFIG_ARCH_WANT_LD_ORPHAN_WARN=y
> # CONFIG_GCC_PLUGIN_CYC_COMPLEXITY is not set
< CONFIG_MODVERSIONS=y
> # CONFIG_MODVERSIONS is not set
< CONFIG_ASM_MODVERSIONS=y
> CONFIG_CMA=y
> CONFIG_CMA_AREAS=7
> CONFIG_VMAP_PFN=y
# Networking options
< CONFIG_PACKET_DIAG=y
> CONFIG_PACKET_DIAG=m
< CONFIG_UNIX_DIAG=y
> CONFIG_UNIX_DIAG=m
< CONFIG_XFRM_ALGO=m
> CONFIG_XFRM_ALGO=y
< CONFIG_XFRM_USER=m
> CONFIG_XFRM_USER=y
> # CONFIG_XFRM_USER_COMPAT is not set
# Packet Radio protocols
> CONFIG_CAN_ISOTP=m
# CAN Device Drivers
> CONFIG_CAN_FLEXCAN=m
> CONFIG_CAN_GRCAN=m
< # CONFIG_CFG80211_CERTIFICATION_ONUS is not set
< CONFIG_CAIF=m
< # CONFIG_CAIF_DEBUG is not set
< CONFIG_CAIF_NETDEV=m
< CONFIG_CAIF_USB=m
> # CONFIG_CAIF is not set
# CAN SPI interfaces
> CONFIG_CAN_MCP251XFD=m
> # CONFIG_CAN_MCP251XFD_SANITY is not set
# Device Drivers
< # CONFIG_PCIEAER_INJECT is not set
> CONFIG_PCIEAER_INJECT=m
< CONFIG_PCI_REALLOC_ENABLE_AUTO=y
> # CONFIG_PCI_REALLOC_ENABLE_AUTO is not set
> CONFIG_PCI_ECAM=y
# PCI controller drivers
< CONFIG_PCI_FTPCI100=y
< CONFIG_PCI_HOST_COMMON=y
< CONFIG_PCI_HOST_GENERIC=y
< CONFIG_PCIE_XILINX=y
# DesignWare PCI Core Support
< CONFIG_PCIE_DW_EP=y
< CONFIG_PCIE_DW_PLAT_EP=y
< CONFIG_PCIE_INTEL_GW=y
# Cadence PCIe controllers support
< CONFIG_PCIE_CADENCE=y
< CONFIG_PCIE_CADENCE_HOST=y
< CONFIG_PCIE_CADENCE_EP=y
< CONFIG_PCIE_CADENCE_PLAT=y
< CONFIG_PCIE_CADENCE_PLAT_HOST=y
< CONFIG_PCIE_CADENCE_PLAT_EP=y
< CONFIG_PCI_J721E=y
< CONFIG_PCI_J721E_HOST=y
< CONFIG_PCI_J721E_EP=y
# PCI Endpoint
< CONFIG_PCI_ENDPOINT=y
> # CONFIG_PCI_ENDPOINT is not set
< CONFIG_PCI_ENDPOINT_CONFIGFS=y
< # CONFIG_PCI_EPF_TEST is not set
# PC-card bridges
< CONFIG_RAPIDIO=m
> # CONFIG_RAPIDIO is not set
< CONFIG_RAPIDIO_TSI721=m
< CONFIG_RAPIDIO_DISC_TIMEOUT=30
< CONFIG_RAPIDIO_ENABLE_RX_TX_PORTS=y
< CONFIG_RAPIDIO_DMA_ENGINE=y
< # CONFIG_RAPIDIO_DEBUG is not set
< CONFIG_RAPIDIO_ENUM_BASIC=m
< CONFIG_RAPIDIO_CHMAN=m
< CONFIG_RAPIDIO_MPORT_CDEV=m
# RapidIO Switch drivers
< CONFIG_RAPIDIO_TSI57X=m
< CONFIG_RAPIDIO_CPS_XX=m
< CONFIG_RAPIDIO_TSI568=m
< CONFIG_RAPIDIO_CPS_GEN2=m
< CONFIG_RAPIDIO_RXS_GEN3=m
< CONFIG_REGMAP_SPMI=m
< CONFIG_REGMAP_I3C=m
> CONFIG_REGMAP_SPI_AVMM=m
# Bus devices
< CONFIG_MOXTET=m
< CONFIG_SIMPLE_PM_BUS=y
> # CONFIG_MHI_BUS_DEBUG is not set
< CONFIG_MTD_TESTS=m
> # CONFIG_MTD_TESTS is not set
# Partition parsers
< CONFIG_MTD_AR7_PARTS=m
> # CONFIG_MTD_AR7_PARTS is not set
< CONFIG_MTD_CMDLINE_PARTS=m
> # CONFIG_MTD_CMDLINE_PARTS is not set
< CONFIG_MTD_OF_PARTS=m
< CONFIG_MTD_REDBOOT_PARTS=m
> # CONFIG_MTD_REDBOOT_PARTS is not set
< CONFIG_MTD_REDBOOT_DIRECTORY_BLOCK=-1
< # CONFIG_MTD_REDBOOT_PARTS_UNALLOCATED is not set
< # CONFIG_MTD_REDBOOT_PARTS_READONLY is not set
< CONFIG_MTD_BLOCK_RO=m
> # CONFIG_MTD_BLOCK_RO is not set
< CONFIG_FTL=m
> # CONFIG_FTL is not set
< CONFIG_NFTL=m
> # CONFIG_NFTL is not set
< CONFIG_NFTL_RW=y
< CONFIG_INFTL=m
> # CONFIG_INFTL is not set
< CONFIG_RFD_FTL=m
> # CONFIG_RFD_FTL is not set
< CONFIG_SSFDC=m
> # CONFIG_SSFDC is not set
< CONFIG_SM_FTL=m
> # CONFIG_SM_FTL is not set
< CONFIG_MTD_OOPS=m
> # CONFIG_MTD_OOPS is not set
< CONFIG_MTD_SWAP=m
< CONFIG_MTD_PARTITIONED_MASTER=y
> # CONFIG_MTD_PARTITIONED_MASTER is not set
# RAM/ROM/Flash chip drivers
< CONFIG_MTD_CFI=m
> # CONFIG_MTD_CFI is not set
< CONFIG_MTD_GEN_PROBE=m
> # CONFIG_MTD_JEDECPROBE is not set< CONFIG_MTD_JEDECPROBE=m
< # CONFIG_MTD_CFI_ADV_OPTIONS is not set
< CONFIG_MTD_CFI_INTELEXT=m
< CONFIG_MTD_CFI_AMDSTD=m
< CONFIG_MTD_CFI_STAA=m
< CONFIG_MTD_CFI_UTIL=m
< CONFIG_MTD_RAM=m
> # CONFIG_MTD_RAM is not set
< CONFIG_MTD_ROM=m
> # CONFIG_MTD_ROM is not set
< CONFIG_MTD_ABSENT=m
> # CONFIG_MTD_ABSENT is not set
# Mapping drivers for chip access
< CONFIG_MTD_COMPLEX_MAPPINGS=y
> # CONFIG_MTD_COMPLEX_MAPPINGS is not set
< CONFIG_MTD_PHYSMAP=m
< # CONFIG_MTD_PHYSMAP_COMPAT is not set
< CONFIG_MTD_PHYSMAP_OF=y
< CONFIG_MTD_PHYSMAP_VERSATILE=y
< CONFIG_MTD_PHYSMAP_GEMINI=y
< CONFIG_MTD_PHYSMAP_GPIO_ADDR=y
< CONFIG_MTD_SBC_GXX=m
< CONFIG_MTD_AMD76XROM=m
< CONFIG_MTD_ICHXROM=m
< CONFIG_MTD_ESB2ROM=m
< CONFIG_MTD_CK804XROM=m
< CONFIG_MTD_SCB2_FLASH=m
< CONFIG_MTD_NETtel=m
< CONFIG_MTD_L440GX=m
< CONFIG_MTD_PCI=m
< CONFIG_MTD_PCMCIA=m
< # CONFIG_MTD_PCMCIA_ANONYMOUS is not set
< CONFIG_MTD_INTEL_VR_NOR=m
> # CONFIG_MTD_INTEL_VR_NOR is not set
< CONFIG_MTD_PLATRAM=m
> # CONFIG_MTD_PLATRAM is not set
# Self-contained MTD device drivers
< CONFIG_MTD_PMC551=m
> # CONFIG_MTD_PMC551 is not set
< # CONFIG_MTD_PMC551_BUGFIX is not set
< # CONFIG_MTD_PMC551_DEBUG is not set
< CONFIG_MTD_DATAFLASH=m
> # CONFIG_MTD_DATAFLASH is not set
< # CONFIG_MTD_DATAFLASH_WRITE_VERIFY is not set
< CONFIG_MTD_DATAFLASH_OTP=y
< CONFIG_MTD_MCHP23K256=m
> # CONFIG_MTD_MCHP23K256 is not set
< CONFIG_MTD_SST25L=m
> # CONFIG_MTD_SST25L is not set
< CONFIG_MTD_SLRAM=m
> # CONFIG_MTD_SLRAM is not set
< CONFIG_MTD_MTDRAM=m
> # CONFIG_MTD_MTDRAM is not set
< CONFIG_MTDRAM_TOTAL_SIZE=4096
< CONFIG_MTDRAM_ERASE_SIZE=128
# Disk-On-Chip Device Drivers
< CONFIG_MTD_DOCG3=m
> # CONFIG_MTD_DOCG3 is not set
< CONFIG_BCH_CONST_M=14
< CONFIG_BCH_CONST_T=4
# NAND
< CONFIG_MTD_ONENAND=m
> # CONFIG_MTD_ONENAND is not set
< # CONFIG_MTD_ONENAND_VERIFY_WRITE is not set
< CONFIG_MTD_ONENAND_GENERIC=m
< CONFIG_MTD_ONENAND_OTP=y
< CONFIG_MTD_ONENAND_2X_PROGRAM=y
< CONFIG_MTD_NAND_ECC_SW_BCH=y
> # CONFIG_MTD_NAND_ECC_SW_BCH is not set
# Raw/parallel NAND flash controllers
< CONFIG_MTD_NAND_DENALI=m
> # CONFIG_MTD_NAND_DENALI_PCI is not set
< CONFIG_MTD_NAND_DENALI_PCI=m
< CONFIG_MTD_NAND_DENALI_DT=m
< CONFIG_MTD_NAND_CAFE=m
> # CONFIG_MTD_NAND_CAFE is not set
< CONFIG_MTD_NAND_MXIC=m
> # CONFIG_MTD_NAND_MXIC is not set
< CONFIG_MTD_NAND_GPIO=m
> # CONFIG_MTD_NAND_GPIO is not set
< CONFIG_MTD_NAND_PLATFORM=m
> # CONFIG_MTD_NAND_PLATFORM is not set
< CONFIG_MTD_NAND_CADENCE=m
< CONFIG_MTD_NAND_ARASAN=m
> # CONFIG_MTD_NAND_ARASAN is not set
# Misc
< CONFIG_MTD_SM_COMMON=m
< CONFIG_MTD_NAND_RICOH=m
< CONFIG_MTD_NAND_DISKONCHIP=m
< # CONFIG_MTD_NAND_DISKONCHIP_PROBE_ADVANCED is not set
< CONFIG_MTD_NAND_DISKONCHIP_PROBE_ADDRESS=0
< CONFIG_MTD_NAND_DISKONCHIP_BBTWRITE=y
< CONFIG_MTD_SPI_NAND=m
> CONFIG_MTD_NAND_ECC=y
# LPDDR & LPDDR2 PCM memory drivers
< CONFIG_MTD_LPDDR=m
> # CONFIG_MTD_LPDDR is not set
< CONFIG_MTD_QINFO_PROBE=m
< CONFIG_MTD_SPI_NOR=m
> # CONFIG_MTD_SPI_NOR is not set
< CONFIG_MTD_SPI_NOR_USE_4K_SECTORS=y
< CONFIG_SPI_INTEL_SPI=m
< CONFIG_SPI_INTEL_SPI_PCI=m
< CONFIG_SPI_INTEL_SPI_PLATFORM=m
< CONFIG_MTD_UBI_FASTMAP=y
> # CONFIG_MTD_UBI_FASTMAP is not set
< CONFIG_MTD_UBI_GLUEBI=m
> # CONFIG_MTD_UBI_GLUEBI is not set
< CONFIG_MTD_UBI_BLOCK=y
> # CONFIG_MTD_UBI_BLOCK is not set
< CONFIG_MTD_HYPERBUS=m
> # CONFIG_MTD_HYPERBUS is not set
< CONFIG_DTC=y
< CONFIG_OF=y
> # CONFIG_OF is not set
< # CONFIG_OF_UNITTEST is not set
< CONFIG_OF_FLATTREE=y
< CONFIG_OF_EARLY_FLATTREE=y
< CONFIG_OF_KOBJ=y
< CONFIG_OF_DYNAMIC=y
< CONFIG_OF_ADDRESS=y
< CONFIG_OF_IRQ=y
< CONFIG_OF_NET=y
< CONFIG_OF_MDIO=m
< CONFIG_OF_RESERVED_MEM=y
< CONFIG_OF_RESOLVE=y
< CONFIG_OF_OVERLAY=y
# Protocols
< # CONFIG_BLK_DEV_NULL_BLK is not set
> CONFIG_BLK_DEV_NULL_BLK=m
< CONFIG_BLK_DEV_LOOP_MIN_COUNT=8
> CONFIG_BLK_DEV_LOOP_MIN_COUNT=0
# Intel MIC & related support
< CONFIG_INTEL_MIC_BUS=m
< CONFIG_SCIF_BUS=m
< CONFIG_VOP_BUS=m
< CONFIG_INTEL_MIC_HOST=m
< CONFIG_INTEL_MIC_CARD=m
< CONFIG_SCIF=m
< CONFIG_MIC_COSM=m
< CONFIG_VOP=m
# Controllers with non-SFF native interface
< CONFIG_AHCI_CEVA=m
< CONFIG_AHCI_QORIQ=m
# Generic fallback / legacy drivers
< # CONFIG_DM_DEBUG_BLOCK_MANAGER_LOCKING is not set
> CONFIG_DM_DEBUG_BLOCK_MANAGER_LOCKING=y
> # CONFIG_DM_DEBUG_BLOCK_STACK_TRACING is not set
< CONFIG_RIONET=m
< CONFIG_RIONET_TX_SIZE=128
< CONFIG_RIONET_RX_SIZE=128
< CONFIG_CAIF_DRIVERS=y
< CONFIG_CAIF_TTY=m
< CONFIG_CAIF_SPI_SLAVE=m
< CONFIG_CAIF_SPI_SYNC=y
< CONFIG_CAIF_HSI=m
< CONFIG_CAIF_VIRTIO=m
# Distributed Switch Architecture drivers
< # CONFIG_B53_SPI_DRIVER is not set
> CONFIG_B53_SPI_DRIVER=m
< CONFIG_NET_DSA_LANTIQ_GSWIP=m
> # CONFIG_NET_DSA_LANTIQ_GSWIP is not set
> CONFIG_NET_DSA_MSCC_SEVILLE=m
> CONFIG_CHELSIO_INLINE_CRYPTO=y
> CONFIG_CHELSIO_IPSEC_INLINE=m
> CONFIG_CHELSIO_TLS_DEVICE=m
< CONFIG_GEMINI_ETHERNET=m
< CONFIG_EZCHIP_NPS_MANAGEMENT_ENET=m
> CONFIG_PRESTERA=m
> CONFIG_PRESTERA_PCI=m
< CONFIG_MSCC_OCELOT_SWITCH=m
< CONFIG_QCA7000=m
< CONFIG_QCA7000_SPI=m
< CONFIG_QCA7000_UART=m
< CONFIG_DWMAC_DWC_QOS_ETH=m
< CONFIG_MDIO_DEVICE=m
< CONFIG_MDIO_BUS=m
< CONFIG_MDIO_DEVRES=m
< CONFIG_MDIO_BCM_UNIMAC=m
< CONFIG_MDIO_BITBANG=m
< CONFIG_MDIO_BUS_MUX=m
< CONFIG_MDIO_BUS_MUX_GPIO=m
< CONFIG_MDIO_BUS_MUX_MMIOREG=m
< CONFIG_MDIO_BUS_MUX_MULTIPLEXER=m
< CONFIG_MDIO_CAVIUM=m
< CONFIG_MDIO_GPIO=m
< CONFIG_MDIO_HISI_FEMAC=m
< CONFIG_MDIO_I2C=m
< CONFIG_MDIO_IPQ4019=m
< CONFIG_MDIO_IPQ8064=m
< CONFIG_MDIO_MSCC_MIIM=m
< CONFIG_MDIO_MVUSB=m
< CONFIG_MDIO_OCTEON=m
< CONFIG_MDIO_THUNDER=m
< CONFIG_MDIO_XPCS=m
> CONFIG_FIXED_PHY=m
> CONFIG_SFP=m
# MII PHY device drivers
< CONFIG_FIXED_PHY=m
< CONFIG_ROCKCHIP_PHY=m
> # CONFIG_ROCKCHIP_PHY is not set
> CONFIG_MDIO_BUS=m
> CONFIG_MDIO_GPIO=m
> CONFIG_MDIO_I2C=m
> CONFIG_MDIO_MVUSB=m
# PCS device drivers
> CONFIG_PCS_XPCS=m
> CONFIG_PCS_LYNX=m
< # CONFIG_WIRELESS_WDS is not set
< CONFIG_ATH10K_AHB=y
> CONFIG_ATH11K=m
> CONFIG_ATH11K_AHB=m
> CONFIG_ATH11K_PCI=m
> CONFIG_ATH11K_DEBUG=y
> CONFIG_ATH11K_DEBUGFS=y
> # CONFIG_ATH11K_TRACING is not set
> CONFIG_ATH11K_SPECTRAL=y
< CONFIG_WLCORE_SPI=m
# Input device support
< CONFIG_INPUT_LEDS=m
> CONFIG_INPUT_LEDS=y
< CONFIG_INPUT_EVDEV=m
> CONFIG_INPUT_EVDEV=y
< CONFIG_KEYBOARD_ATKBD=m
> CONFIG_KEYBOARD_ATKBD=y
< CONFIG_KEYBOARD_STMPE=m
< CONFIG_KEYBOARD_OMAP4=m
< CONFIG_KEYBOARD_TC3589X=m
< CONFIG_KEYBOARD_CAP11XX=m
< CONFIG_KEYBOARD_BCM=m
> CONFIG_JOYSTICK_ADC=m
< CONFIG_TOUCHSCREEN_AR1021_I2C=m
< CONFIG_TOUCHSCREEN_CHIPONE_ICN8318=m
< CONFIG_TOUCHSCREEN_EGALAX=m
< CONFIG_TOUCHSCREEN_IMX6UL_TSC=m
< CONFIG_TOUCHSCREEN_STMPE=m
< CONFIG_TOUCHSCREEN_COLIBRI_VF50=m
> CONFIG_TOUCHSCREEN_ZINITIX=m
< CONFIG_INPUT_ATMEL_CAPTOUCH=m
< CONFIG_INPUT_MAX77650_ONKEY=m
< CONFIG_INPUT_CPCAP_PWRBUTTON=m
< CONFIG_INPUT_TPS65218_PWRBUTTON=m
< CONFIG_INPUT_RK805_PWRKEY=m
< CONFIG_INPUT_STPMIC1_ONKEY=m
> CONFIG_RMI4_F3A=y
# Hardware I/O ports
< CONFIG_SERIO=m
> CONFIG_SERIO=y
< CONFIG_SERIO_I8042=m
> CONFIG_SERIO_I8042=y
< CONFIG_SERIO_LIBPS2=m
> CONFIG_SERIO_LIBPS2=y
< # CONFIG_SERIO_APBPS2 is not set
< CONFIG_SERIAL_8250_RUNTIME_UARTS=4
> CONFIG_SERIAL_8250_RUNTIME_UARTS=32
< CONFIG_SERIAL_8250_ASPEED_VUART=m
< CONFIG_SERIAL_OF_PLATFORM=m
< CONFIG_SERIAL_SIFIVE=m
< CONFIG_SERIAL_LANTIQ=m
> # CONFIG_SERIAL_LANTIQ is not set
< CONFIG_SERIAL_XILINX_PS_UART=m
< CONFIG_SERIAL_CONEXANT_DIGICOLOR=m
< # CONFIG_TTY_PRINTK is not set
< # CONFIG_LP_CONSOLE is not set
> CONFIG_LP_CONSOLE=y
< CONFIG_HW_RANDOM_CCTRNG=m
> CONFIG_HW_RANDOM_XIPHERA=m
< CONFIG_NVRAM=m
> CONFIG_NVRAM=y
< CONFIG_MAX_RAW_DEVS=256
> CONFIG_MAX_RAW_DEVS=8192
< CONFIG_HPET_MMAP=y
> # CONFIG_HPET_MMAP is not set
< CONFIG_HPET_MMAP_DEFAULT=y
< CONFIG_XILLYBUS_OF=m
# Multiplexer I2C Chip support
< CONFIG_I2C_ARB_GPIO_CHALLENGE=m
< CONFIG_I2C_MUX_GPMUX=m
< CONFIG_I2C_MUX_PINCTRL=m
< CONFIG_I2C_DEMUX_PINCTRL=m
< CONFIG_I2C_DESIGNWARE_PCI=m
> CONFIG_I2C_DESIGNWARE_PCI=y
< CONFIG_I2C_RK3X=m
< CONFIG_I2C_FSI=m
> CONFIG_I2C_SLAVE_TESTUNIT=m
< CONFIG_I3C=m
< CONFIG_CDNS_I3C_MASTER=m
< CONFIG_DW_I3C_MASTER=m
> # CONFIG_I3C is not set
< CONFIG_SPI_FSI=m
< CONFIG_SPI_FSL_LIB=m
< CONFIG_SPI_FSL_SPI=m
< CONFIG_SPI_LANTIQ_SSC=m
> # CONFIG_SPI_LANTIQ_SSC is not set
< CONFIG_SPI_ROCKCHIP=m
> # CONFIG_SPI_ROCKCHIP is not set
# SPI Protocol Masters
< CONFIG_SPMI=m
> # CONFIG_SPMI is not set
< CONFIG_HSI=m
> # CONFIG_HSI is not set
< CONFIG_HSI_BOARDINFO=y
# HSI clients
< CONFIG_HSI_CHAR=m
# PTP clock support
< CONFIG_GENERIC_PINCTRL_GROUPS=y
< CONFIG_GENERIC_PINMUX_FUNCTIONS=y
< CONFIG_PINCTRL_AS3722=m
< CONFIG_PINCTRL_AXP209=m
< CONFIG_PINCTRL_SINGLE=m
< CONFIG_PINCTRL_STMFX=m
< CONFIG_PINCTRL_MAX77620=m
< CONFIG_PINCTRL_PALMAS=m
< CONFIG_PINCTRL_RK805=m
< CONFIG_PINCTRL_OCELOT=y
< CONFIG_PINCTRL_LOCHNAGAR=m
< CONFIG_PINCTRL_EQUILIBRIUM=m
< CONFIG_OF_GPIO=y
> CONFIG_GPIO_CDEV=y
> CONFIG_GPIO_CDEV_V1=y
< CONFIG_GPIO_GENERIC=y
> CONFIG_GPIO_GENERIC=m
# Memory mapped GPIO drivers
< CONFIG_GPIO_74XX_MMIO=m
< CONFIG_GPIO_ALTERA=m
< CONFIG_GPIO_CADENCE=m
< CONFIG_GPIO_FTGPIO010=y
< CONFIG_GPIO_GRGPIO=m
< CONFIG_GPIO_HLWD=m
< CONFIG_GPIO_LOGICVC=m
< CONFIG_GPIO_SAMA5D2_PIOBU=m
< CONFIG_GPIO_SIFIVE=y
< CONFIG_GPIO_SYSCON=m
< CONFIG_GPIO_WCD934X=m
# I2C GPIO expanders
< CONFIG_GPIO_ADNP=m
< CONFIG_GPIO_GW_PLD=m
< CONFIG_GPIO_BD70528=m
< CONFIG_GPIO_BD71828=m
< CONFIG_GPIO_LP87565=m
< CONFIG_GPIO_MAX77620=m
< CONFIG_GPIO_MAX77650=m
< CONFIG_GPIO_STMPE=y
< CONFIG_GPIO_TC3589X=y
< CONFIG_GPIO_TPS65218=m
< CONFIG_GPIO_SODAVILLE=y
# SPI GPIO expanders
< CONFIG_GPIO_74X164=m
< CONFIG_GPIO_MOXTET=m
< CONFIG_POWER_AVS=y
< CONFIG_QCOM_CPR=m
< CONFIG_POWER_RESET_AS3722=y
< CONFIG_POWER_RESET_GPIO=y
< CONFIG_POWER_RESET_GPIO_RESTART=y
< CONFIG_POWER_RESET_LTC2952=y
< CONFIG_POWER_RESET_SYSCON=y
< CONFIG_POWER_RESET_SYSCON_POWEROFF=y
< CONFIG_REBOOT_MODE=m
< CONFIG_SYSCON_REBOOT_MODE=m
< CONFIG_NVMEM_REBOOT_MODE=m
< CONFIG_BATTERY_ACT8945A=m
< CONFIG_BATTERY_CPCAP=m
< CONFIG_BATTERY_LEGO_EV3=m
< CONFIG_CHARGER_DETECTOR_MAX14656=m
< CONFIG_CHARGER_MAX77650=m
> CONFIG_CHARGER_BQ25980=m
< CONFIG_CHARGER_TPS65217=m
< CONFIG_CHARGER_UCS1002=m
< CONFIG_CHARGER_BD70528=m
< CONFIG_SENSORS_GSC=m
< CONFIG_SENSORS_GPIO_FAN=m
< CONFIG_SENSORS_LOCHNAGAR=m
> CONFIG_SENSORS_MR75203=m
> CONFIG_SENSORS_ADM1266=m
> CONFIG_SENSORS_MP2975=m
< CONFIG_SENSORS_PWM_FAN=m
> CONFIG_SENSORS_INTEL_M10_BMC_HWMON=m
< CONFIG_THERMAL_OF=y
< CONFIG_CPU_THERMAL=y
< CONFIG_CPU_FREQ_THERMAL=y
< CONFIG_CPU_IDLE_THERMAL=y
< CONFIG_THERMAL_MMIO=m
< CONFIG_MAX77620_THERMAL=m
< CONFIG_DA9062_THERMAL=m
# Watchdog Device Drivers
< CONFIG_BD70528_WATCHDOG=m
< CONFIG_GPIO_WATCHDOG=m
< CONFIG_RN5T618_WATCHDOG=m
< CONFIG_MAX77620_WATCHDOG=m
< CONFIG_STPMIC1_WATCHDOG=m
# Multifunction device drivers
< CONFIG_MFD_ACT8945A=m
< CONFIG_MFD_AS3722=m
< CONFIG_MFD_ATMEL_FLEXCOM=m
< CONFIG_MFD_ATMEL_HLCDC=m
< CONFIG_MFD_GATEWORKS_GSC=m
< CONFIG_MFD_HI6421_PMIC=m
< CONFIG_MFD_MAX77620=y
< CONFIG_MFD_MAX77650=m
< CONFIG_MFD_MAX77686=m
< CONFIG_MFD_CPCAP=m
< CONFIG_MFD_RK808=m
< CONFIG_MFD_RN5T618=m
< CONFIG_MFD_STMPE=y
# STMicroelectronics STMPE Interface Drivers
< CONFIG_STMPE_I2C=y
< CONFIG_STMPE_SPI=y
< CONFIG_MFD_TPS65217=m
< CONFIG_MFD_TI_LP87565=m
< CONFIG_MFD_TPS65218=m
< CONFIG_MFD_TC3589X=y
< CONFIG_MFD_LOCHNAGAR=y
< CONFIG_MFD_ROHM_BD718XX=m
< CONFIG_MFD_ROHM_BD70528=m
< CONFIG_MFD_ROHM_BD71828=m
< CONFIG_MFD_STPMIC1=m
< CONFIG_MFD_STMFX=m
> CONFIG_MFD_INTEL_M10_BMC=m
< CONFIG_REGULATOR_ACT8945A=m
< CONFIG_REGULATOR_AS3722=m
< CONFIG_REGULATOR_BD70528=m
< CONFIG_REGULATOR_BD71828=m
< CONFIG_REGULATOR_BD718XX=m
< CONFIG_REGULATOR_CPCAP=m
< CONFIG_REGULATOR_CROS_EC=m
< CONFIG_REGULATOR_DA9063=m
< CONFIG_REGULATOR_FAN53880=m
< CONFIG_REGULATOR_HI6421=m
< CONFIG_REGULATOR_HI6421V530=m
< CONFIG_REGULATOR_LOCHNAGAR=m
< CONFIG_REGULATOR_LP873X=m
< CONFIG_REGULATOR_LP87565=m
< CONFIG_REGULATOR_MAX77620=m
< CONFIG_REGULATOR_MAX77650=m
< CONFIG_REGULATOR_MAX8973=m
< CONFIG_REGULATOR_MAX77686=m
< CONFIG_REGULATOR_MAX77802=m
< CONFIG_REGULATOR_MCP16502=m
< CONFIG_REGULATOR_MP5416=m
< CONFIG_REGULATOR_MP886X=m
< CONFIG_REGULATOR_MPQ7920=m
> CONFIG_REGULATOR_MT6360=m
< CONFIG_REGULATOR_QCOM_SPMI=m
< CONFIG_REGULATOR_QCOM_USB_VBUS=m
< CONFIG_REGULATOR_RK808=m
< CONFIG_REGULATOR_RN5T618=m
< CONFIG_REGULATOR_ROHM=m
> CONFIG_REGULATOR_RASPBERRYPI_TOUCHSCREEN_ATTINY=m
> CONFIG_REGULATOR_RT4801=m
> CONFIG_REGULATOR_RTMV20=m
< CONFIG_REGULATOR_STPMIC1=m
< CONFIG_REGULATOR_SY8106A=m
< CONFIG_REGULATOR_SY8824X=m
< CONFIG_REGULATOR_SY8827N=m
< CONFIG_REGULATOR_TPS65217=m
< CONFIG_REGULATOR_TPS65218=m
< CONFIG_REGULATOR_VCTRL=m
< CONFIG_REGULATOR_QCOM_LABIBB=m
< CONFIG_RC_CORE=m
> CONFIG_RC_CORE=y
> CONFIG_BPF_LIRC_MODE2=y
< CONFIG_IR_HIX5HD2=m
< CONFIG_IR_SPI=m
< CONFIG_IR_GPIO_CIR=m
< CONFIG_IR_GPIO_TX=m
< CONFIG_IR_PWM_TX=m
< # CONFIG_MEDIA_SUPPORT_FILTER is not set
> CONFIG_MEDIA_SUPPORT_FILTER=y
< CONFIG_MEDIA_SDR_SUPPORT=y
> # CONFIG_MEDIA_SDR_SUPPORT is not set
# Media device types
< # CONFIG_DVB_DYNAMIC_MINORS is not set
> CONFIG_DVB_DYNAMIC_MINORS=y
# Software defined radio USB devices
< CONFIG_USB_AIRSPY=m
< CONFIG_USB_HACKRF=m
< CONFIG_USB_MSI2500=m
# common driver options
< CONFIG_VIDEO_MUX=m
< CONFIG_VIDEO_XILINX=m
< CONFIG_VIDEO_XILINX_CSI2RXSS=m
< CONFIG_VIDEO_XILINX_TPG=m
< CONFIG_VIDEO_XILINX_VTC=m
< CONFIG_SDR_PLATFORM_DRIVERS=y
> CONFIG_DVB_TEST_DRIVERS=y
> CONFIG_DVB_VIDTV=m
> CONFIG_MEDIA_HIDE_ANCILLARY_SUBDRV=y
# Audio decoders, processors and mixers
< CONFIG_VIDEO_TDA1997X=m
< CONFIG_VIDEO_TLV320AIC23B=m
# Video decoders
< CONFIG_VIDEO_ADV7180=m
< CONFIG_VIDEO_ADV7183=m
< CONFIG_VIDEO_ADV748X=m
< CONFIG_VIDEO_ADV7604=m
< CONFIG_VIDEO_ADV7604_CEC=y
< CONFIG_VIDEO_ADV7842=m
< CONFIG_VIDEO_ADV7842_CEC=y
< CONFIG_VIDEO_BT819=m
< CONFIG_VIDEO_BT856=m
< CONFIG_VIDEO_BT866=m
< CONFIG_VIDEO_KS0127=m
< CONFIG_VIDEO_ML86V7667=m
< CONFIG_VIDEO_SAA7110=m
< CONFIG_VIDEO_TC358743=m
< CONFIG_VIDEO_TC358743_CEC=y
< CONFIG_VIDEO_TVP514X=m
< CONFIG_VIDEO_TVP7002=m
< CONFIG_VIDEO_VPX3220=m
< CONFIG_VIDEO_MAX9286=m
# Video encoders
< CONFIG_VIDEO_SAA7185=m
< CONFIG_VIDEO_ADV7170=m
< CONFIG_VIDEO_ADV7175=m
< CONFIG_VIDEO_ADV7343=m
< CONFIG_VIDEO_ADV7393=m
< CONFIG_VIDEO_AD9389B=m
< CONFIG_VIDEO_AK881X=m
< CONFIG_VIDEO_THS8200=m
# SDR tuner chips
< CONFIG_SDR_MAX2175=m
# Miscellaneous helper chips
< CONFIG_VIDEO_THS7303=m
< CONFIG_VIDEO_I2C=m
< CONFIG_VIDEO_ST_MIPID02=m
# Camera sensor devices
< CONFIG_VIDEO_OV5640=m
< CONFIG_VIDEO_OV5645=m
# SPI helper chips
< CONFIG_VIDEO_GS1662=m
# Customize TV tuners
< CONFIG_MEDIA_TUNER_MSI001=m
# DVB-T (terrestrial) frontends
< CONFIG_DVB_S5H1432=m
< CONFIG_DVB_DIB9000=m
< CONFIG_DVB_RTL2832_SDR=m
< CONFIG_DVB_CXD2880=m
# ISDB-S (satellite) & ISDB-T (terrestrial) frontends
< CONFIG_DVB_MN88443X=m
# SEC control devices for DVB-S
< CONFIG_DVB_LNBH29=m
< CONFIG_DVB_LGS8GL5=m
# ARM devices
< CONFIG_DRM_KOMEDA=m
# Display Engine Configuration
< # CONFIG_DEBUG_KERNEL_DC is not set
> CONFIG_DRM_AMD_DC_SI=y
< CONFIG_DRM_RCAR_DW_HDMI=m
< CONFIG_DRM_RCAR_LVDS=m
# Display Panels
< CONFIG_DRM_PANEL_ARM_VERSATILE=m
< CONFIG_DRM_PANEL_ASUS_Z00T_TM5P5_NT35596=m
< CONFIG_DRM_PANEL_BOE_HIMAX8279D=m
< CONFIG_DRM_PANEL_BOE_TV101WUM_NL6=m
< CONFIG_DRM_PANEL_LVDS=m
< CONFIG_DRM_PANEL_SIMPLE=m
< CONFIG_DRM_PANEL_ELIDA_KD35T133=m
< CONFIG_DRM_PANEL_FEIXIN_K101_IM2BA02=m
< CONFIG_DRM_PANEL_FEIYANG_FY07024DI26A30D=m
< CONFIG_DRM_PANEL_ILITEK_IL9322=m
< CONFIG_DRM_PANEL_ILITEK_ILI9881C=m
< CONFIG_DRM_PANEL_INNOLUX_P079ZCA=m
< CONFIG_DRM_PANEL_JDI_LT070ME05000=m
< CONFIG_DRM_PANEL_KINGDISPLAY_KD097D04=m
< CONFIG_DRM_PANEL_LEADTEK_LTK050H3146W=m
< CONFIG_DRM_PANEL_LEADTEK_LTK500HD1829=m
< CONFIG_DRM_PANEL_SAMSUNG_LD9040=m
< CONFIG_DRM_PANEL_LG_LB035Q02=m
< CONFIG_DRM_PANEL_LG_LG4573=m
< CONFIG_DRM_PANEL_NEC_NL8048HL11=m
< CONFIG_DRM_PANEL_NOVATEK_NT35510=m
< CONFIG_DRM_PANEL_NOVATEK_NT39016=m
< CONFIG_DRM_PANEL_OLIMEX_LCD_OLINUXINO=m
< CONFIG_DRM_PANEL_ORISETECH_OTM8009A=m
< CONFIG_DRM_PANEL_OSD_OSD101T2587_53TS=m
< CONFIG_DRM_PANEL_PANASONIC_VVX10F034N00=m
< CONFIG_DRM_PANEL_RAYDIUM_RM67191=m
< CONFIG_DRM_PANEL_RAYDIUM_RM68200=m
< CONFIG_DRM_PANEL_RONBO_RB070D30=m
< CONFIG_DRM_PANEL_SAMSUNG_S6D16D0=m
< CONFIG_DRM_PANEL_SAMSUNG_S6E3HA2=m
< CONFIG_DRM_PANEL_SAMSUNG_S6E63J0X03=m
< CONFIG_DRM_PANEL_SAMSUNG_S6E63M0=m
< CONFIG_DRM_PANEL_SAMSUNG_S6E88A0_AMS452EF01=m
< CONFIG_DRM_PANEL_SAMSUNG_S6E8AA0=m
< CONFIG_DRM_PANEL_SEIKO_43WVF1G=m
< CONFIG_DRM_PANEL_SHARP_LQ101R1SX01=m
< CONFIG_DRM_PANEL_SHARP_LS037V7DW01=m
< CONFIG_DRM_PANEL_SHARP_LS043T1LE01=m
< CONFIG_DRM_PANEL_SITRONIX_ST7701=m
< CONFIG_DRM_PANEL_SITRONIX_ST7703=m
< CONFIG_DRM_PANEL_SITRONIX_ST7789V=m
< CONFIG_DRM_PANEL_SONY_ACX424AKP=m
< CONFIG_DRM_PANEL_SONY_ACX565AKM=m
< CONFIG_DRM_PANEL_TPO_TD028TTEC1=m
< CONFIG_DRM_PANEL_TPO_TD043MTEA1=m
< CONFIG_DRM_PANEL_TPO_TPG110=m
< CONFIG_DRM_PANEL_TRULY_NT35597_WQXGA=m
< CONFIG_DRM_PANEL_VISIONOX_RM69299=m
< CONFIG_DRM_PANEL_XINPENG_XPP055C272=m
# Display Interface Bridges
< CONFIG_DRM_CDNS_DSI=m
< CONFIG_DRM_CHRONTEL_CH7033=m
< CONFIG_DRM_DISPLAY_CONNECTOR=m
< CONFIG_DRM_LVDS_CODEC=m
< CONFIG_DRM_MEGACHIPS_STDPXXXX_GE_B850V3_FW=m
< CONFIG_DRM_NWL_MIPI_DSI=m
< CONFIG_DRM_NXP_PTN3460=m
< CONFIG_DRM_PARADE_PS8622=m
< CONFIG_DRM_PARADE_PS8640=m
< CONFIG_DRM_SIL_SII8620=m
< CONFIG_DRM_SII902X=m
< CONFIG_DRM_SII9234=m
< CONFIG_DRM_SIMPLE_BRIDGE=m
< CONFIG_DRM_THINE_THC63LVD1024=m
< CONFIG_DRM_TOSHIBA_TC358764=m
< CONFIG_DRM_TOSHIBA_TC358767=m
< CONFIG_DRM_TOSHIBA_TC358768=m
< CONFIG_DRM_TI_TFP410=m
< CONFIG_DRM_TI_SN65DSI86=m
< CONFIG_DRM_TI_TPD12S015=m
< CONFIG_DRM_ANALOGIX_ANX6345=m
< CONFIG_DRM_I2C_ADV7511=m
< CONFIG_DRM_I2C_ADV7511_AUDIO=y
< CONFIG_DRM_I2C_ADV7511_CEC=y
< CONFIG_DRM_DW_HDMI=m
< CONFIG_DRM_DW_HDMI_AHB_AUDIO=m
< CONFIG_DRM_DW_HDMI_I2S_AUDIO=m
< CONFIG_DRM_DW_HDMI_CEC=m
< CONFIG_DRM_ARCPGU=m
< CONFIG_DRM_MXS=y
< CONFIG_DRM_MXSFB=m
# Frame buffer Devices
< CONFIG_FB_BACKLIGHT=m
< CONFIG_FB_MODE_HELPERS=y
> # CONFIG_FB_MODE_HELPERS is not set
< # CONFIG_FB_INTEL is not set
> CONFIG_BACKLIGHT_KTD253=m
< CONFIG_BACKLIGHT_TPS65217=m
< CONFIG_BACKLIGHT_LED=m
# HD-Audio
< CONFIG_SND_HDA_INPUT_BEEP_MODE=1
> CONFIG_SND_HDA_INPUT_BEEP_MODE=0
< CONFIG_SND_HDA_POWER_SAVE_DEFAULT=0
> CONFIG_SND_HDA_POWER_SAVE_DEFAULT=1
< CONFIG_SND_SOC_MIKROE_PROTO=m
< CONFIG_SND_SST_IPC=m
< CONFIG_SND_SST_IPC_PCI=m
< CONFIG_SND_SST_IPC_ACPI=m
< CONFIG_SND_SOC_INTEL_SST_ACPI=m
< CONFIG_SND_SOC_INTEL_SST_FIRMWARE=m
< CONFIG_SND_SOC_INTEL_HASWELL=m
> CONFIG_SND_SOC_INTEL_CATPT=m
< # CONFIG_SND_SOC_INTEL_USER_FRIENDLY_LONG_NAMES is not set
> CONFIG_SND_SOC_INTEL_USER_FRIENDLY_LONG_NAMES=y
> CONFIG_SND_SOC_INTEL_SOUNDWIRE_SOF_MACH=m
< CONFIG_SND_SOC_SOF_OF=m
< # CONFIG_SND_SOC_SOF_DEVELOPER_SUPPORT is not set
> # CONFIG_SND_SOC_SOF_BROADWELL_SUPPORT is not set
> CONFIG_SND_SOC_SOF_INTEL_SOUNDWIRE_LINK=y
> CONFIG_SND_SOC_SOF_INTEL_SOUNDWIRE_LINK_BASELINE=m
> CONFIG_SND_SOC_SOF_INTEL_SOUNDWIRE=m
# CODEC drivers
< CONFIG_SND_SOC_CPCAP=m
> CONFIG_SND_SOC_CS4234=m
< CONFIG_SND_SOC_LOCHNAGAR_SC=m
< CONFIG_SND_SOC_MSM8916_WCD_ANALOG=m
> CONFIG_SND_SOC_RT1308=m
> CONFIG_SND_SOC_TAS2764=m
< CONFIG_SND_AUDIO_GRAPH_CARD=m
# HID support
< CONFIG_HID=m
> CONFIG_HID=y
< CONFIG_HID_GENERIC=m
> CONFIG_HID_GENERIC=y
# Special HID drivers
> CONFIG_HID_VIVALDI=m
# Miscellaneous USB options
< CONFIG_USB_DYNAMIC_MINORS=y
> # CONFIG_USB_FEW_INIT_RETRIES is not set
> # CONFIG_USB_DYNAMIC_MINORS is not set
# USB Host Controller Drivers
< CONFIG_USB_XHCI_HCD=m
> CONFIG_USB_XHCI_HCD=y
< CONFIG_USB_EHCI_HCD=m
> CONFIG_USB_EHCI_HCD=y
< CONFIG_USB_EHCI_PCI=m
> CONFIG_USB_EHCI_PCI=y
< CONFIG_USB_OHCI_HCD=m
> CONFIG_USB_OHCI_HCD=y
< CONFIG_USB_OHCI_HCD_PCI=m
> CONFIG_USB_OHCI_HCD_PCI=y
< # CONFIG_USB_OHCI_HCD_SSB is not set
< CONFIG_USB_UHCI_HCD=m
> CONFIG_USB_UHCI_HCD=y
# USB Imaging devices
< CONFIG_USBIP_VUDC=m
< CONFIG_USB_CDNS3=m
> # CONFIG_USB_CDNS3 is not set
< CONFIG_USB_CDNS3_GADGET=y
< CONFIG_USB_CDNS3_HOST=y
< CONFIG_USB_CDNS3_PCI_WRAP=m
< CONFIG_USB_MUSB_HDRC=m
> # CONFIG_USB_MUSB_HDRC is not set
< # CONFIG_USB_MUSB_HOST is not set
< # CONFIG_USB_MUSB_GADGET is not set
< CONFIG_USB_MUSB_DUAL_ROLE=y
> # CONFIG_USB_DWC3 is not set
> # CONFIG_USB_DWC2 is not set
> # CONFIG_USB_CHIPIDEA is not set
> # CONFIG_USB_ISP1760 is not set
< CONFIG_USB_GADGET=m
> # CONFIG_USB_GADGET is not set
< # CONFIG_USB_GADGET_DEBUG is not set
< # CONFIG_USB_GADGET_DEBUG_FILES is not set
< # CONFIG_USB_GADGET_DEBUG_FS is not set
< CONFIG_USB_GADGET_VBUS_DRAW=2
< CONFIG_USB_GADGET_STORAGE_NUM_BUFFERS=2
< CONFIG_U_SERIAL_CONSOLE=y
< # USB Peripheral Controller
< CONFIG_USB_FOTG210_UDC=m
< CONFIG_USB_GR_UDC=m
< CONFIG_USB_R8A66597=m
< CONFIG_USB_PXA27X=m
< CONFIG_USB_MV_UDC=m
< CONFIG_USB_MV_U3D=m
< CONFIG_USB_SNP_CORE=m
< CONFIG_USB_SNP_UDC_PLAT=m
< CONFIG_USB_M66592=m
< CONFIG_USB_BDC_UDC=m
# Platform Support
< CONFIG_USB_BDC_PCI=m
< CONFIG_USB_AMD5536UDC=m
< CONFIG_USB_NET2272=m
< CONFIG_USB_NET2272_DMA=y
< CONFIG_USB_NET2280=m
< CONFIG_USB_GOKU=m
< CONFIG_USB_EG20T=m
< CONFIG_USB_GADGET_XILINX=m
< CONFIG_USB_MAX3420_UDC=m
< CONFIG_USB_DUMMY_HCD=m
< # end of USB Peripheral Controller
< CONFIG_USB_LIBCOMPOSITE=m
< CONFIG_USB_F_ACM=m
< CONFIG_USB_F_SS_LB=m
< CONFIG_USB_U_SERIAL=m
< CONFIG_USB_U_ETHER=m
< CONFIG_USB_U_AUDIO=m
< CONFIG_USB_F_SERIAL=m
< CONFIG_USB_F_OBEX=m
< CONFIG_USB_F_NCM=m
< CONFIG_USB_F_ECM=m
< CONFIG_USB_F_PHONET=m
< CONFIG_USB_F_EEM=m
< CONFIG_USB_F_SUBSET=m
< CONFIG_USB_F_RNDIS=m
< CONFIG_USB_F_MASS_STORAGE=m
< CONFIG_USB_F_FS=m
< CONFIG_USB_F_UAC1=m
< CONFIG_USB_F_UAC1_LEGACY=m
< CONFIG_USB_F_UAC2=m
< CONFIG_USB_F_UVC=m
< CONFIG_USB_F_MIDI=m
< CONFIG_USB_F_HID=m
< CONFIG_USB_F_PRINTER=m
< CONFIG_USB_F_TCM=m
< CONFIG_USB_CONFIGFS=m
< CONFIG_USB_CONFIGFS_SERIAL=y
< CONFIG_USB_CONFIGFS_ACM=y
< CONFIG_USB_CONFIGFS_OBEX=y
< CONFIG_USB_CONFIGFS_NCM=y
< CONFIG_USB_CONFIGFS_ECM=y
< CONFIG_USB_CONFIGFS_ECM_SUBSET=y
< CONFIG_USB_CONFIGFS_RNDIS=y
< CONFIG_USB_CONFIGFS_EEM=y
< CONFIG_USB_CONFIGFS_PHONET=y
< CONFIG_USB_CONFIGFS_MASS_STORAGE=y
< CONFIG_USB_CONFIGFS_F_LB_SS=y
< CONFIG_USB_CONFIGFS_F_FS=y
< CONFIG_USB_CONFIGFS_F_UAC1=y
< CONFIG_USB_CONFIGFS_F_UAC1_LEGACY=y
< CONFIG_USB_CONFIGFS_F_UAC2=y
< CONFIG_USB_CONFIGFS_F_MIDI=y
< CONFIG_USB_CONFIGFS_F_HID=y
< CONFIG_USB_CONFIGFS_F_UVC=y
< CONFIG_USB_CONFIGFS_F_PRINTER=y
< CONFIG_USB_CONFIGFS_F_TCM=y
# USB Gadget precomposed configurations
< CONFIG_USB_ZERO=m
< CONFIG_USB_AUDIO=m
< # CONFIG_GADGET_UAC1 is not set
< CONFIG_USB_ETH=m
< CONFIG_USB_ETH_RNDIS=y
< CONFIG_USB_ETH_EEM=y
< CONFIG_USB_G_NCM=m
< CONFIG_USB_GADGETFS=m
< CONFIG_USB_FUNCTIONFS=m
< CONFIG_USB_FUNCTIONFS_ETH=y
< CONFIG_USB_FUNCTIONFS_RNDIS=y
< CONFIG_USB_FUNCTIONFS_GENERIC=y
< CONFIG_USB_MASS_STORAGE=m
< CONFIG_USB_GADGET_TARGET=m
< CONFIG_USB_G_SERIAL=m
< CONFIG_USB_MIDI_GADGET=m
< CONFIG_USB_G_PRINTER=m
< CONFIG_USB_CDC_COMPOSITE=m
< CONFIG_USB_G_NOKIA=m
< CONFIG_USB_G_ACM_MS=m
< CONFIG_USB_G_MULTI=m
< CONFIG_USB_G_MULTI_RNDIS=y
< CONFIG_USB_G_MULTI_CDC=y
< CONFIG_USB_G_HID=m
< CONFIG_USB_G_DBGP=m
< # CONFIG_USB_G_DBGP_PRINTK is not set
< CONFIG_USB_G_DBGP_SERIAL=y
< CONFIG_USB_G_WEBCAM=m
< CONFIG_USB_RAW_GADGET=m
> CONFIG_TYPEC_MT6360=m
> CONFIG_TYPEC_TCPCI_MAXIM=m
> CONFIG_TYPEC_STUSB160X=m
# USB Type-C Alternate Mode drivers
< CONFIG_PWRSEQ_EMMC=m
< CONFIG_PWRSEQ_SD8787=m
< CONFIG_PWRSEQ_SIMPLE=m
# MMC/SD/SDIO Host Controller Drivers
< CONFIG_MMC_SDHCI_OF_ARASAN=m
< CONFIG_MMC_SDHCI_OF_ASPEED=m
< CONFIG_MMC_SDHCI_OF_AT91=m
< CONFIG_MMC_SDHCI_OF_DWCMSHC=m
< CONFIG_MMC_SDHCI_CADENCE=m
< CONFIG_MMC_SDHCI_MILBEAUT=m
< CONFIG_MMC_SDHCI_OMAP=m
< CONFIG_MMC_SDHCI_AM654=m
< CONFIG_MMC_SDHCI_EXTERNAL_DMA=y
# LED drivers
< CONFIG_LEDS_AAT1290=m
< CONFIG_LEDS_AN30259A=m
< CONFIG_LEDS_AW2013=m
< CONFIG_LEDS_BCM6328=m
< CONFIG_LEDS_BCM6358=m
< CONFIG_LEDS_CPCAP=m
< CONFIG_LEDS_CR0014114=m
< CONFIG_LEDS_EL15203000=m
< CONFIG_LEDS_LM3692X=m
< # CONFIG_LEDS_LP55XX_COMMON is not set
> CONFIG_LEDS_LP50XX=m
< CONFIG_LEDS_LP8860=m
< CONFIG_LEDS_LT3593=m
< CONFIG_LEDS_MAX77650=m
< CONFIG_LEDS_MAX77693=m
< CONFIG_LEDS_KTD2692=m
< CONFIG_LEDS_IS31FL319X=m
< CONFIG_LEDS_IS31FL32XX=m
# LED driver for blink(1) USB RGB LED is under Special HID drivers (HID_THINGM)
< CONFIG_LEDS_SYSCON=y
< CONFIG_LEDS_SPI_BYTE=m
< CONFIG_LEDS_LM3697=m
# I2C RTC drivers
< CONFIG_RTC_DRV_AS3722=m
< CONFIG_RTC_DRV_HYM8563=m
< CONFIG_RTC_DRV_MAX77686=m
< CONFIG_RTC_DRV_RK808=m
< CONFIG_RTC_DRV_ISL12026=m
< CONFIG_RTC_DRV_BD70528=m
< CONFIG_RTC_DRV_TWL4030=m
< CONFIG_RTC_DRV_RC5T619=m
> CONFIG_RTC_DRV_RV3032=m
< CONFIG_RTC_DRV_ZYNQMP=m
# on-CPU RTC drivers
< CONFIG_RTC_DRV_CADENCE=m
< CONFIG_RTC_DRV_R7301=m
< CONFIG_RTC_DRV_CPCAP=m
# DMA Devices
< CONFIG_DMA_OF=y
< CONFIG_DW_AXI_DMAC=m
< CONFIG_FSL_EDMA=m
< CONFIG_INTEL_MIC_X100_DMA=m
< CONFIG_DW_DMAC=y
> CONFIG_DW_DMAC=m
# DMABUF options
> CONFIG_DMABUF_HEAPS_CMA=y
< CONFIG_HT16K33=m
> CONFIG_NITRO_ENCLAVES=m
> CONFIG_VIRTIO_DMA_SHARED_BUFFER=m
< CONFIG_COMEDI=m
> # CONFIG_COMEDI is not set
< # CONFIG_COMEDI_DEBUG is not set
< CONFIG_COMEDI_DEFAULT_BUF_SIZE_KB=2048
< CONFIG_COMEDI_DEFAULT_BUF_MAXSIZE_KB=20480
< CONFIG_COMEDI_MISC_DRIVERS=y
< CONFIG_COMEDI_BOND=m
< CONFIG_COMEDI_TEST=m
< CONFIG_COMEDI_PARPORT=m
< # CONFIG_COMEDI_ISA_DRIVERS is not set
< CONFIG_COMEDI_PCI_DRIVERS=m
< CONFIG_COMEDI_8255_PCI=m
< CONFIG_COMEDI_ADDI_WATCHDOG=m
< CONFIG_COMEDI_ADDI_APCI_1032=m
< CONFIG_COMEDI_ADDI_APCI_1500=m
< CONFIG_COMEDI_ADDI_APCI_1516=m
< CONFIG_COMEDI_ADDI_APCI_1564=m
< CONFIG_COMEDI_ADDI_APCI_16XX=m
< CONFIG_COMEDI_ADDI_APCI_2032=m
< CONFIG_COMEDI_ADDI_APCI_2200=m
< CONFIG_COMEDI_ADDI_APCI_3120=m
< CONFIG_COMEDI_ADDI_APCI_3501=m
< CONFIG_COMEDI_ADDI_APCI_3XXX=m
< CONFIG_COMEDI_ADL_PCI6208=m
< CONFIG_COMEDI_ADL_PCI7X3X=m
< CONFIG_COMEDI_ADL_PCI8164=m
< CONFIG_COMEDI_ADL_PCI9111=m
< CONFIG_COMEDI_ADL_PCI9118=m
< CONFIG_COMEDI_ADV_PCI1710=m
< CONFIG_COMEDI_ADV_PCI1720=m
< CONFIG_COMEDI_ADV_PCI1723=m
< CONFIG_COMEDI_ADV_PCI1724=m
< CONFIG_COMEDI_ADV_PCI1760=m
< CONFIG_COMEDI_ADV_PCI_DIO=m
< CONFIG_COMEDI_AMPLC_DIO200_PCI=m
< CONFIG_COMEDI_AMPLC_PC236_PCI=m
< CONFIG_COMEDI_AMPLC_PC263_PCI=m
< CONFIG_COMEDI_AMPLC_PCI224=m
< CONFIG_COMEDI_AMPLC_PCI230=m
< CONFIG_COMEDI_CONTEC_PCI_DIO=m
< CONFIG_COMEDI_DAS08_PCI=m
< CONFIG_COMEDI_DT3000=m
< CONFIG_COMEDI_DYNA_PCI10XX=m
< CONFIG_COMEDI_GSC_HPDI=m
< CONFIG_COMEDI_MF6X4=m
< CONFIG_COMEDI_ICP_MULTI=m
< CONFIG_COMEDI_DAQBOARD2000=m
< CONFIG_COMEDI_JR3_PCI=m
< CONFIG_COMEDI_KE_COUNTER=m
< CONFIG_COMEDI_CB_PCIDAS64=m
< CONFIG_COMEDI_CB_PCIDAS=m
< CONFIG_COMEDI_CB_PCIDDA=m
< CONFIG_COMEDI_CB_PCIMDAS=m
< CONFIG_COMEDI_CB_PCIMDDA=m
< CONFIG_COMEDI_ME4000=m
< CONFIG_COMEDI_ME_DAQ=m
< CONFIG_COMEDI_NI_6527=m
< CONFIG_COMEDI_NI_65XX=m
< CONFIG_COMEDI_NI_660X=m
< CONFIG_COMEDI_NI_670X=m
< CONFIG_COMEDI_NI_LABPC_PCI=m
< CONFIG_COMEDI_NI_PCIDIO=m
< CONFIG_COMEDI_NI_PCIMIO=m
< CONFIG_COMEDI_RTD520=m
< CONFIG_COMEDI_S626=m
< CONFIG_COMEDI_MITE=m
< CONFIG_COMEDI_NI_TIOCMD=m
< CONFIG_COMEDI_PCMCIA_DRIVERS=m
< CONFIG_COMEDI_CB_DAS16_CS=m
< CONFIG_COMEDI_DAS08_CS=m
< CONFIG_COMEDI_NI_DAQ_700_CS=m
< CONFIG_COMEDI_NI_DAQ_DIO24_CS=m
< CONFIG_COMEDI_NI_LABPC_CS=m
< CONFIG_COMEDI_NI_MIO_CS=m
< CONFIG_COMEDI_QUATECH_DAQP_CS=m
< CONFIG_COMEDI_USB_DRIVERS=m
< CONFIG_COMEDI_DT9812=m
< CONFIG_COMEDI_NI_USB6501=m
< CONFIG_COMEDI_USBDUX=m
< CONFIG_COMEDI_USBDUXFAST=m
< CONFIG_COMEDI_USBDUXSIGMA=m
< CONFIG_COMEDI_VMK80XX=m
< CONFIG_COMEDI_8254=m
< CONFIG_COMEDI_8255=m
< CONFIG_COMEDI_8255_SA=m
< CONFIG_COMEDI_KCOMEDILIB=m
< CONFIG_COMEDI_AMPLC_DIO200=m
< CONFIG_COMEDI_AMPLC_PC236=m
< CONFIG_COMEDI_DAS08=m
< CONFIG_COMEDI_NI_LABPC=m
< CONFIG_COMEDI_NI_TIO=m
< CONFIG_COMEDI_NI_ROUTING=m
< CONFIG_VIDEO_USBVISION=m
< CONFIG_STAGING_BOARD=y
< CONFIG_MOST_CDEV=m
< CONFIG_MOST_DIM2=m
< CONFIG_XIL_AXIS_FIFO=m
< CONFIG_HMS_ANYBUSS_BUS=m
< CONFIG_ARCX_ANYBUS_CONTROLLER=m
< CONFIG_HMS_PROFINET=m
< CONFIG_MFD_CROS_EC=m
< CONFIG_CROS_EC_RPMSG=m
< CONFIG_CROS_EC_VBC=m
< CONFIG_CLK_HSDK=y
< CONFIG_COMMON_CLK_MAX77686=m
< CONFIG_COMMON_CLK_RK808=m
< CONFIG_COMMON_CLK_SI514=m
< CONFIG_COMMON_CLK_SI570=m
< CONFIG_COMMON_CLK_CDCE925=m
< CONFIG_COMMON_CLK_LOCHNAGAR=m
< CONFIG_COMMON_CLK_VC5=m
< CONFIG_COMMON_CLK_BD718XX=m
< CONFIG_COMMON_CLK_FIXED_MMIO=y
< CONFIG_CLK_LGM_CGU=y
# Clock Source drivers
< CONFIG_TIMER_OF=y
< CONFIG_TIMER_PROBE=y
< CONFIG_CLKSRC_MMIO=y
< CONFIG_MICROCHIP_PIT64B=y
< CONFIG_PLATFORM_MHU=m
< CONFIG_MAILBOX_TEST=m
< CONFIG_OF_IOMMU=y
< # CONFIG_INTEL_IOMMU_SCALABLE_MODE_DEFAULT_ON is not set
> CONFIG_INTEL_IOMMU_SCALABLE_MODE_DEFAULT_ON=y
> CONFIG_SOUNDWIRE_GENERIC_ALLOCATION=m
> CONFIG_QCOM_QMI_HELPERS=m
< CONFIG_DMARD06=m
< CONFIG_CPCAP_ADC=m
< CONFIG_ENVELOPE_DETECTOR=m
< CONFIG_QCOM_VADC_COMMON=m
< CONFIG_QCOM_SPMI_IADC=m
< CONFIG_QCOM_SPMI_VADC=m
< CONFIG_QCOM_SPMI_ADC5=m
< CONFIG_RN5T618_ADC=m
< CONFIG_SD_ADC_MODULATOR=m
< CONFIG_STMPE_ADC=m
< CONFIG_TI_ADS8344=m
< CONFIG_TI_ADS8688=m
< CONFIG_TI_ADS124S08=m
< CONFIG_VF610_ADC
# Analog Front Ends
< CONFIG_IIO_RESCALE=m
# Digital to analog converters
< CONFIG_DPOT_DAC=m
< CONFIG_MAX5821=m
< CONFIG_VF610_DAC=m
# Digital gyroscope sensors
> CONFIG_ADXRS290=m
> CONFIG_HDC2010=m
< CONFIG_IIO_ST_LSM6DSX_I3C=m
> CONFIG_AS73211=m
< CONFIG_CM3605=m
< CONFIG_AK8974=m
# Multiplexers
< CONFIG_IIO_MUX=m
< CONFIG_VME_BUS=y
> # CONFIG_VME_BUS is not set
# VME Bridge Drivers
< CONFIG_VME_CA91CX42=m
< CONFIG_VME_TSI148=m
< # CONFIG_VME_FAKE is not set
# VME Board Drivers
< CONFIG_VMIVME_7805=m
# VME Device Drivers
< CONFIG_VME_USER=m
< CONFIG_PWM_ATMEL_HLCDC_PWM=m
< CONFIG_PWM_FSL_FTM=m
< CONFIG_PWM_STMPE=y
# IRQ chip support
< CONFIG_IRQCHIP=y
< CONFIG_AL_FIC=y
< CONFIG_RESET_INTEL_GW=y
# PHY Subsystem
< CONFIG_GENERIC_PHY_MIPI_DPHY=y
> CONFIG_USB_LGM_PHY=m
< CONFIG_PHY_CADENCE_TORRENT=m
< CONFIG_PHY_CADENCE_DPHY=m
< CONFIG_PHY_CADENCE_SIERRA=m
< CONFIG_PHY_CADENCE_SALVO=m
< CONFIG_PHY_FSL_IMX8MQ_USB=m
< CONFIG_PHY_MIXEL_MIPI_DPHY=m
< CONFIG_PHY_MAPPHONE_MDM6600=m
< CONFIG_PHY_OCELOT_SERDES=m
< CONFIG_PHY_SAMSUNG_USB2=m
< CONFIG_PHY_INTEL_COMBO=y
< CONFIG_PHY_INTEL_EMMC=m
> CONFIG_PHY_INTEL_LGM_EMMC=m
> # CONFIG_USB4_DEBUGFS_WRITE is not set
< CONFIG_OF_PMEM=m
> CONFIG_DEV_DAX_HMEM_DEVICES=y
< CONFIG_NVMEM_SPMI_SDAM=m
< CONFIG_ALTERA_PR_IP_CORE_PLAT=m
< CONFIG_FPGA_MGR_ICE40_SPI=m
< CONFIG_OF_FPGA_REGION=m
< CONFIG_FSI=m
< CONFIG_FSI_NEW_DEV_NODE=y
< CONFIG_FSI_MASTER_GPIO=m
< CONFIG_FSI_MASTER_HUB=m
< CONFIG_FSI_MASTER_ASPEED=m
< CONFIG_FSI_SCOM=m
< CONFIG_FSI_SBEFIFO=m
< CONFIG_FSI_OCC=m
< CONFIG_MUX_MMIO=m
< CONFIG_FTM_QUADDEC=m
< CONFIG_MICROCHIP_TCB_CAPTURE=m
> CONFIG_MOST_CDEV=m
> CONFIG_XFS_SUPPORT_V4=y
< CONFIG_QUOTACTL_COMPAT=y
> CONFIG_FUSE_DAX=y
# Caches
< CONFIG_FSCACHE_HISTOGRAM=y
> # CONFIG_FSCACHE_HISTOGRAM is not set
< # CONFIG_FSCACHE_OBJECT_LIST is not set
> CONFIG_FSCACHE_OBJECT_LIST=y
# DOS/FAT/EXFAT/NT Filesystems
< CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
> CONFIG_FAT_DEFAULT_IOCHARSET="ascii"
< CONFIG_NTFS_FS=m
< # CONFIG_NTFS_DEBUG is not set
< CONFIG_NTFS_RW=y
> # CONFIG_NTFS_FS is not set
> CONFIG_PSTORE_RAM=m
> # CONFIG_NFS_V4_2_READ_PLUS is not set
< CONFIG_NLS_CODEPAGE_437=m
> CONFIG_NLS_CODEPAGE_437=y
< CONFIG_NLS_ASCII=m
> CONFIG_NLS_ASCII=y
< # CONFIG_DLM_DEBUG is not set
> CONFIG_DLM_DEBUG=y
< # CONFIG_HARDENED_USERCOPY_PAGESPAN is not set
< # CONFIG_SECURITY_LOADPIN is not set
> CONFIG_SECURITY_LOADPIN=y
> CONFIG_SECURITY_LOADPIN_ENFORCE=y
< CONFIG_CRYPTO_AEAD=y
> CONFIG_CRYPTO_AEAD=m
< CONFIG_CRYPTO_RNG_DEFAULT=y
> CONFIG_CRYPTO_RNG_DEFAULT=m
< CONFIG_CRYPTO_GF128MUL=y
< CONFIG_CRYPTO_NULL=y
> CONFIG_CRYPTO_GF128MUL=m
> CONFIG_CRYPTO_NULL=m
> CONFIG_CRYPTO_SM2=m
< CONFIG_CRYPTO_GCM=y
> CONFIG_CRYPTO_GCM=m
< CONFIG_CRYPTO_SEQIV=y
> CONFIG_CRYPTO_SEQIV=m
< CONFIG_CRYPTO_GHASH=y
> CONFIG_CRYPTO_GHASH=m
# Ciphers
< CONFIG_CRYPTO_ANUBIS=m
< CONFIG_CRYPTO_ARC4=m
< CONFIG_CRYPTO_KHAZAD=m
< CONFIG_CRYPTO_SEED=m
< CONFIG_CRYPTO_TEA=m
< CONFIG_CRYPTO_DRBG_MENU=y
> CONFIG_CRYPTO_DRBG_MENU=m
< CONFIG_CRYPTO_DRBG=y
> CONFIG_CRYPTO_DRBG=m
> # CONFIG_CRYPTO_USER_API_RNG_CAVP is not set
> # CONFIG_CRYPTO_USER_API_ENABLE_OBSOLETE is not set
< # CONFIG_CRYPTO_STATS is not set
> CONFIG_CRYPTO_STATS=y
< CONFIG_CHELSIO_IPSEC_INLINE=y
< CONFIG_CHELSIO_TLS_DEVICE=y
< CONFIG_CRYPTO_DEV_CCREE=m
# Library routines
< CONFIG_RAID6_PQ_BENCHMARK=y
> # CONFIG_RAID6_PQ_BENCHMARK is not set
< CONFIG_REED_SOLOMON=y
> CONFIG_REED_SOLOMON=m
< CONFIG_REED_SOLOMON_DEC16=y
< CONFIG_BCH=m
< CONFIG_DMA_DECLARE_COHERENT=y
< CONFIG_DMA_VIRT_OPS=y
< CONFIG_IOMMU_HELPER=y
< CONFIG_LIBFDT=y
> CONFIG_DMA_CMA=y
> # CONFIG_DMA_PERNUMA_CMA is not set
# Default contiguous memory area size:
> CONFIG_CMA_SIZE_MBYTES=0
> CONFIG_CMA_SIZE_SEL_MBYTES=y
> # CONFIG_CMA_SIZE_SEL_PERCENTAGE is not set
> # CONFIG_CMA_SIZE_SEL_MIN is not set
> # CONFIG_CMA_SIZE_SEL_MAX is not set
> CONFIG_CMA_ALIGNMENT=8
I guess, if the same issue shows up in 5.11.1, I’ll compile a kernel using my own config - picking the best from 5.9 and 5.11.
Last night this problem occurred on 5.11.1. Now I’ll need to figure out what it takes to compile a new kernel… Plan is to start with the 5.9 config, run oldconfig, say no to most new things, compile and install.
In the world of manjaro, what should be installed in order to get the required compilation tools?
the package-group
base-devel
if you go through “make menuconfig”
or similar
you get to easily read the descriptions of what all those options are there fore and what they do
pretty daunting at first - lots of info you won’t know where and what to connect it to - but educational nonetheless …
Is the package “meta-group-base-devel-202001281517-1” the package I’m looking for?
Yes, “base-devel” is a package group.
By default, everything in it is installed - so you don’t have to search and pick and choose which of the 24 members you need (all of them …).
In the graphical tool you search for base-devel
in pamac you do:
pamac install base-devel
With pacman you do:
sudo pacman -S base-devel
I don’t know where you got that long and highly specific name from. There is no need for that.
When searching for “base-devel” that long and highly specific name was the only package name that looked somewhat similar to the search term. And being such a highly specific name I got the feeling of not being on the right track.
Gcc is also one of the results. which is the only that looks like having something todo with compiling stuff.
You don’t seem to have used any of these native tools to look for software.
… anyway - these are three equivalent ways to install the prerequisites you need to be able to build your own kernel … or to build anything from source
no - although gcc is the compiler, gcc is by far not the only tool you need to build software from source
There is a howto on building your own kernel on Manjaro.
