I’d like to use an HDMI 3-in-1-out switch.
I’ve tried connecting my computer’s output to the 3-in-1 device, but my screen remains black. If I connect my computer directly to the screen, everything works.
What should I do?
What should I do?
Provide more information, and read these posts:
Cheers.
Thanks for the advices and the links.
Lets’ start first with inxi.
[xxx@xxx-manjaro ~]$ inxi -v7azy
Kernel: 6.5.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
root=UUID=9b49cd51-c08f-4cb3-af43-e321b329be94 rw quiet apparmor=1
Desktop: Cinnamon v: 5.8.4 tk: GTK v: 3.24.38 vt: 7 dm: LightDM v: 1.32.0
Mobo: ASUSTeK model: TUF GAMING B560M-PLUS WIFI v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 1601
date: 05/07/2022
System RAM: total: 16 GiB note: est. available: 15.39 GiB
used: 3.52 GiB (22.9%)
Info: model: 11th Gen Intel Core i5-11400 bits: 64 type: MT MCP
arch: Rocket Lake gen: core 11 level: v4 note: check built: 2021+
process: Intel 14nm family: 6 model-id: 0xA7 (167) stepping: 1
microcode: 0x59
L1: 480 KiB desc: d-6x48 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 12 MiB
desc: 1x12 MiB
Speed (MHz): avg: 808 high: 901 min/max: 800/4400 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 901 9: 800 10: 800 11: 800 12: 800 bogomips: 62232
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma
avx512vbmi avx512vl bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb erms est f16c
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp rep_good sdbg
sep sha_ni smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme
vpclmulqdq x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
RSB filling, PBRSB-eIBRS: SW sequence
Device-1: Intel RocketLake-S GT1 [UHD Graphics 730] vendor: ASUSTeK
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: HDMI-A-1 empty: DP-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:4c8b class-ID: 0300
Display: x11 server: X.org v: 1.21.1.8 driver: X: loaded: modesetting
alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: HDMI-A-1 mapped: HDMI-1 model: LG (GoldStar) E2241 built: 2010
res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2 size: 477x268mm (18.78x10.55")
diag: 547mm (21.5") ratio: 16:9 modes: max: 1920x1080 min: 720x400
device: 1 drv: swrast surfaceless: drv: iris x11: drv: iris
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RKL GT1)
device-ID: 8086:4c8b memory: 15.03 GiB unified: yes
Device-1: Intel Tiger Lake-H HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:43c8
class-ID: 0403
API: ALSA v: k6.5.5-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.81 status: off tools: pw-cli
type: plugin tools: pacat,pactl,pavucontrol
Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:43f0 class-ID: 0280
Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 4000 bus-ID: 03:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:7 chip-ID: 8087:0026
class-ID: e001
Local Storage: total: 1.82 TiB used: 609.18 GiB (32.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P3SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR309 temp: 30.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC46
Optical-1: /dev/sr0 vendor: ASUS model: DRW-24D5MT rev: 2.00
dev-links: cdrom
Features: speed: 12 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
used: 609.18 GiB (66.5%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 9b49cd51-c08f-4cb3-af43-e321b329be94
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: FE67-FCF5
Device-1: 1-1:2 info: Logitech Mouse type: mouse driver: hid-generic,usbhid
interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0
power: 100mA chip-ID: 046d:c077 class-ID: 0301
Device-2: 1-2:3 info: Holtek Keyboard type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 04d9:1603 class-ID: 0300
Hub-2: 1-3:4 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
chip-ID: 174c:2074 class-ID: 0900
Device-1: 1-8:5 info: ASUSTek AURA LED Controller type: HID
lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:19af class-ID: 0300
serial: <filter>
Hub-3: 1-9:6 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-14:7 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0026 class-ID: e001
Hub-4: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
Hub-5: 2-3:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
chip-ID: 174c:3074 class-ID: 0900
System Temperatures: cpu: 31.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 292 Uptime: 3h 12m wakeups: 0 Init: systemd v: 254
Packages: pm: pacman pkgs: 1188 libs: 353 tools: pamac,yay pm: flatpak
pkgs: 0 Shell: Bash v: 5.1.16 running-in: terminator inxi: 3.3.30
Perhaps more detailed information about this switch will be helpful to someone. Usually, a separate graphics card (dGPU) would be used to achieve this result. I’m dubious as to whether using a switch in this way will produce the expected result.
That said, there are probably others with deeper insight to share, as I’ve never attempted this. Using a discrete Radeon RX 580, RX590, or similar, might be a better alternative. Cheers.
Here is the device used.
Switch HDMI 3 Inputs to 1 Outputs Splitter HDMI 4K
Brand : Fokky
I have moved my question from here to https://forums.archlinux.fr/viewtopic.php?t=22922.
