2nd NIC refuses connection with PCIE card installed
I have a couple of these small x86 computers I’m testing for a machine control application running Manjaro XFCE
https://www.seeedstudio.com/ODYSSEY-X86J4125800-p-4915.html
I used to use an Odroid H2 which is similar but appears to be out of production. Anyway I have an issue with the 2nd ethernet NIC not showing a network connection when a PCIE card is attached. The PC has 2 built in Intel NICs attached to PCIE lanes. The PC has an M.2 slot with 4 PCIE gen 2 lanes and I’m using an adapter to connect a PCIE USB3 card that has multiple USB3 controllers. I have 2 different cards both with Renasis chips that do exactly the same thing. The adapter is powered from a HDD power connector since M.2 slots only provide 3.3v.
Without the PCIE card attached both NICs work fine. With the PCIE card attached the PCIE card works fine, and USB devices work fine, but the 2nd NIC just won’t see the same network connection it had prior to plugging it in. I don’t think it’s a power issue or anything like that because this happens even without a USB device attached and these cards can’t draw that much power by themselves.
https://www.amazon.com/dp/B07R63J6FS?psc=1&ref=ppx_yo2_dt_b_product_details
https://www.amazon.com/dp/B07NTZ84LD?psc=1&ref=ppx_yo2_dt_b_product_details
This is probably a BIOS thing or a hardware issue but Seeed is pretty bad with support so I figured I’d see if there were possibly some Linux conflict I can rule out.
$ lspci
00:00.0 Host bridge: Intel Corporation Gemini Lake Host Bridge (rev 06)
00:00.1 Signal processing controller: Intel Corporation Celeron/Pentium Silver Processor Dynamic Platform and Thermal Framework Processor Participant (rev 06)
00:02.0 VGA compatible controller: Intel Corporation GeminiLake [UHD Graphics 600] (rev 06)
00:0e.0 Audio device: Intel Corporation Celeron/Pentium Silver Processor High Definition Audio (rev 06)
00:0f.0 Communication controller: Intel Corporation Celeron/Pentium Silver Processor Trusted Execution Engine Interface (rev 06)
00:12.0 SATA controller: Intel Corporation Celeron/Pentium Silver Processor SATA Controller (rev 06)
00:13.0 PCI bridge: Intel Corporation Gemini Lake PCI Express Root Port (rev f6)
00:14.0 PCI bridge: Intel Corporation Gemini Lake PCI Express Root Port (rev f6)
00:14.1 PCI bridge: Intel Corporation Gemini Lake PCI Express Root Port (rev f6)
00:15.0 USB controller: Intel Corporation Celeron/Pentium Silver Processor USB 3.0 xHCI Controller (rev 06)
00:17.0 Signal processing controller: Intel Corporation Device 31b4 (rev 06)
00:17.1 Signal processing controller: Intel Corporation Device 31b6 (rev 06)
00:17.2 Signal processing controller: Intel Corporation Device 31b8 (rev 06)
00:18.0 Signal processing controller: Intel Corporation Celeron/Pentium Silver Processor Serial IO UART Host Controller (rev 06)
00:18.1 Signal processing controller: Intel Corporation Celeron/Pentium Silver Processor Serial IO UART Host Controller (rev 06)
00:18.2 Signal processing controller: Intel Corporation Celeron/Pentium Silver Processor Serial IO UART Host Controller (rev 06)
00:18.3 Signal processing controller: Intel Corporation Celeron/Pentium Silver Processor Serial IO UART Host Controller (rev 06)
00:19.0 Signal processing controller: Intel Corporation Celeron/Pentium Silver Processor Serial IO SPI Host Controller (rev 06)
00:1c.0 SD Host controller: Intel Corporation Celeron/Pentium Silver Processor SDA Standard Compliant SD Host Controller (rev 06)
00:1e.0 SD Host controller: Intel Corporation Device 31d0 (rev 06)
00:1f.0 ISA bridge: Intel Corporation Celeron/Pentium Silver Processor LPC Controller (rev 06)
00:1f.1 SMBus: Intel Corporation Celeron/Pentium Silver Processor Gaussian Mixture Model (rev 06)
01:00.0 PCI bridge: Pericom Semiconductor PI7C9X2G608GP PCIe2 6-Port/8-Lane Packet Switch
02:01.0 PCI bridge: Pericom Semiconductor PI7C9X2G608GP PCIe2 6-Port/8-Lane Packet Switch
02:02.0 PCI bridge: Pericom Semiconductor PI7C9X2G608GP PCIe2 6-Port/8-Lane Packet Switch
02:03.0 PCI bridge: Pericom Semiconductor PI7C9X2G608GP PCIe2 6-Port/8-Lane Packet Switch
02:04.0 PCI bridge: Pericom Semiconductor PI7C9X2G608GP PCIe2 6-Port/8-Lane Packet Switch
03:00.0 USB controller: Renesas Technology Corp. uPD720202 USB 3.0 Host Controller (rev 02)
04:00.0 USB controller: Renesas Technology Corp. uPD720202 USB 3.0 Host Controller (rev 02)
05:00.0 USB controller: Renesas Technology Corp. uPD720202 USB 3.0 Host Controller (rev 02)
06:00.0 USB controller: Renesas Technology Corp. uPD720202 USB 3.0 Host Controller (rev 02)
07:00.0 Ethernet controller: Intel Corporation I211 Gigabit Network Connection (rev 03)
08:00.0 Ethernet controller: Intel Corporation I211 Gigabit Network Connection (rev 03)
Hello blazini36. To enable someone to help you please provide some more info about the system.
Provide Information:
$ inxi --admin --verbosity=7 --filter --width
  Kernel: 5.15.5-1-rt22-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-5.15-rt-x86_64
    root=UUID=269048c7-1b02-4bf8-b1d4-49bac336e1da rw quiet apparmor=1
    security=apparmor resume=UUID=54cc14b0-30dc-4f45-910d-00aba1a77ac0
    udev.log_priority=3 processor.max_cstate=1 idle=poll
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
    vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
  Type: Desktop Mobo: SeeedStudio model: ODYSSEY-X86J41X5
    v: SD-BS-CJ41G-300-101-G 04/17/2021 14:49:27 serial: <superuser required>
    UEFI: American Megatrends v: SD-BS-CJ41G-300-101-G date: 04/17/2021
  RAM: total: 7.6 GiB used: 1.1 GiB (14.4%)
  RAM Report:
  Info: model: Intel Celeron J4125 bits: 64 type: MCP arch: Goldmont Plus
    family: 6 model-id: 0x7A (122) stepping: 8 microcode: 0x1A
  Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 224 KiB
    desc: d-4x24 KiB; i-4x32 KiB L2: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 2376 high: 2429 min/max: 800/2700 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 2429 2: 2410 3: 2364
    4: 2304 bogomips: 15974
  Flags: 3dnowprefetch acpi aes aperfmperf apic arat arch_capabilities
    arch_perfmon art bts cat_l2 cdp_l2 clflush clflushopt cmov constant_tsc
    cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est
    flexpriority fpu fsgsbase fxsr ht ibpb ibrs ibrs_enhanced ida intel_pt
    lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc
    nopl nx pae pat pbe pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse
    pse36 pts rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep sha_ni smap
    smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
    tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip vme vmx vnmi vpid
    x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Device-1: Intel GeminiLake [UHD Graphics 600] driver: i915 v: kernel
    bus-ID: 00:02.0 chip-ID: 8086:3185 class-ID: 0300
  Display: x11 server: X.Org 1.21.1.2 compositor: xfwm4 v: 4.16.1 driver:
    loaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
    s-diag: 582mm (22.9")
  Monitor-1: HDMI-1 res: 1920x1080 hz: 60 dpi: 70
    size: 698x393mm (27.5x15.5") diag: 801mm (31.5")
  Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio
    vendor: Realtek driver: snd_hda_intel v: kernel
    alternate: snd_soc_skl,snd_sof_pci_intel_apl bus-ID: 00:0e.0
    chip-ID: 8086:3198 class-ID: 0403
  Sound Server-1: ALSA v: k5.15.5-1-rt22-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.40 running: no
  Device-1: Intel I211 Gigabit Network driver: igb v: kernel port: e000
    bus-ID: 07:00.0 chip-ID: 8086:1539 class-ID: 0200
  IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IP v6: <filter> type: noprefixroute scope: global
  Device-2: Intel I211 Gigabit Network driver: igb v: kernel port: d000
    bus-ID: 08:00.0 chip-ID: 8086:1539 class-ID: 0200
  IF: enp8s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Local Storage: total: 58.24 GiB used: 11.19 GiB (19.2%)
  ID-1: /dev/mmcblk0 maj-min: 179:0 vendor: SanDisk model: DA4064
    size: 58.24 GiB block-size: physical: 512 B logical: 512 B type: SSD
    serial: <filter> rev: 0x8 scheme: GPT
  ID-1: / raw-size: 29.3 GiB size: 28.67 GiB (97.86%) used: 11.02 GiB (38.5%)
    fs: ext4 dev: /dev/mmcblk0p2 maj-min: 179:2 label: Root
    uuid: 269048c7-1b02-4bf8-b1d4-49bac336e1da
    used: 288 KiB (0.1%) fs: vfat dev: /dev/mmcblk0p1 maj-min: 179:1
    label: SYSTEM uuid: 88CD-2995
  ID-3: /home raw-size: 24.41 GiB size: 23.86 GiB (97.74%)
    used: 166 MiB (0.7%) fs: ext4 dev: /dev/mmcblk0p3 maj-min: 179:3 label: Home
    uuid: 95e22d92-5455-404a-9869-102676a8aa17
  ID-1: swap-1 type: partition size: 4.03 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/mmcblk0p4 maj-min: 179:4 label: Swap
    uuid: 54cc14b0-30dc-4f45-910d-00aba1a77ac0
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 9 rev: 2.0
  Device-1: 1-2:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
    power: 98mA chip-ID: 046d:c52b class-ID: 0300
  Device-2: 1-4:3 info: Realtek RTS5129 Card Reader Controller
    interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
    class-ID: ff00 serial: <filter>
  Device-3: 1-7:4 info: Seeed Seeeduino_Cortex_M0+
    type: Abstract (modem),CDC-Data driver: cdc_acm interfaces: 2 rev: 2.0
    speed: 12 Mb/s power: 500mA chip-ID: 2886:8027 class-ID: 0a00
    serial: <filter>
  Hub-2: 2-0:1 info: Super-speed hub ports: 7 rev: 3.0 speed: 5 Gb/s
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s
  Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-6: 6-0:1 info: Super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s
  Hub-7: 7-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-8: 8-0:1 info: Super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s
  Hub-9: 9-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-10: 10-0:1 info: Super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 46.0 C mobo: N/A
  Processes: 238 Uptime: 16h 30m wakeups: 1 Init: systemd v: 249
  tool: systemctl Compilers: gcc: 11.1.0 alt: 6 Packages: pacman: 1163
  lib: 322 flatpak: 0 Shell: Bash v: 5.1.12 running-in: xfce4-terminal
  inxi: 3.3.11
$ sudo dmesg
[    0.000000] microcode: microcode updated early to revision 0x1a, date = 2020-10-23
[    0.000000] Linux version 5.15.5-1-rt22-MANJARO (bernhard@mk5) (gcc (GCC) 11.1.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP PREEMPT_RT Wed Dec 1 16:28:32 CET 2021
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.15-rt-x86_64 root=UUID=269048c7-1b02-4bf8-b1d4-49bac336e1da rw quiet apparmor=1 security=apparmor resume=UUID=54cc14b0-30dc-4f45-910d-00aba1a77ac0 udev.log_priority=3 processor.max_cstate=1 idle=poll pci=pcie_bus_safe
[    0.000000] KERNEL supported cpus:
[    0.000000]   Intel GenuineIntel
[    0.000000]   AMD AuthenticAMD
[    0.000000]   Hygon HygonGenuine
[    0.000000]   Centaur CentaurHauls
[    0.000000]   zhaoxin   Shanghai
[    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[    0.000000] x86/fpu: xstate_offset[3]:  576, xstate_sizes[3]:   64
[    0.000000] x86/fpu: xstate_offset[4]:  640, xstate_sizes[4]:   64
[    0.000000] x86/fpu: Enabled xstate features 0x1b, context size is 704 bytes, using 'compacted' format.
[    0.000000] signal: max sigframe size: 2032
[    0.000000] process: using polling idle threads
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000003dfff] usable
[    0.000000] BIOS-e820: [mem 0x000000000003e000-0x000000000003ffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000040000-0x000000000009efff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000000fffffff] usable
[    0.000000] BIOS-e820: [mem 0x0000000010000000-0x0000000012150fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000012151000-0x0000000076783fff] usable
[    0.000000] BIOS-e820: [mem 0x0000000076784000-0x0000000079048fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000079049000-0x0000000079124fff] usable
[    0.000000] BIOS-e820: [mem 0x0000000079125000-0x000000007947ffff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x0000000079480000-0x0000000079d6ffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000079d70000-0x0000000079e16fff] type 20
[    0.000000] BIOS-e820: [mem 0x0000000079e17000-0x000000007a765fff] usable
[    0.000000] BIOS-e820: [mem 0x000000007a766000-0x000000007a811fff] reserved
[    0.000000] BIOS-e820: [mem 0x000000007a812000-0x000000007abfffff] usable
[    0.000000] BIOS-e820: [mem 0x000000007ac00000-0x000000007fffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000d0000000-0x00000000d0ffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000d3709000-0x00000000d3709fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fe042000-0x00000000fe044fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fe900000-0x00000000fe902fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed01000-0x00000000fed01fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ff800000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000027fffffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] efi: EFI v2.70 by American Megatrends
[    0.000000] efi: ACPI 2.0=0x79429000 ACPI=0x79429000 TPMFinalLog=0x7944e000 SMBIOS=0x79c5b000 SMBIOS 3.0=0x79c5a000 MEMATTR=0x757f8418 ESRT=0x75841598
[    0.000000] SMBIOS 3.2.0 present.
[    0.000000] DMI: Default string ODYSSEY-X86J4125/ODYSSEY-X86J41X5, BIOS SD-BS-CJ41G-300-101-G 04/17/2021
[    0.000000] tsc: Detected 1996.800 MHz processor
[    0.000023] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000027] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000039] last_pfn = 0x280000 max_arch_pfn = 0x400000000
[    0.000091] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.000220] last_pfn = 0x7ac00 max_arch_pfn = 0x400000000
[    0.005967] found SMP MP-table at [mem 0x000fcde0-0x000fcdef]
[    0.006000] Using GB pages for direct mapping
[    0.007475] Secure boot disabled
[    0.007476] RAMDISK: [mem 0x3669b000-0x37344fff]
[    0.007484] ACPI: Early table checksum verification disabled
[    0.007489] ACPI: RSDP 0x0000000079429000 000024 (v02 ALASKA)
[    0.007495] ACPI: XSDT 0x00000000794290C0 0000E4 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.007505] ACPI: FACP 0x0000000079435990 000114 (v06 ALASKA A M I    01072009 AMI  00010013)
[    0.007514] ACPI: DSDT 0x0000000079429250 00C737 (v02 ALASKA A M I    01072009 INTL 20160930)
[    0.007519] ACPI: FACS 0x000000007947F080 000040
[    0.007523] ACPI: FPDT 0x0000000079435AB0 000044 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.007528] ACPI: FIDT 0x0000000079435B00 00009C (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.007532] ACPI: MCFG 0x0000000079435BA0 00003C (v01 ALASKA A M I    01072009 MSFT 00000097)
[    0.007536] ACPI: DBG2 0x0000000079435BE0 000072 (v00 INTEL  GLK-SOC  00000003 BRXT 0100000D)
[    0.007541] ACPI: DBGP 0x0000000079435C60 000034 (v01 INTEL  GLK-SOC  00000003 BRXT 0100000D)
[    0.007545] ACPI: HPET 0x0000000079435CA0 000038 (v01 INTEL  GLK-SOC  00000003 BRXT 0100000D)
[    0.007549] ACPI: LPIT 0x0000000079435CE0 00005C (v01 INTEL  GLK-SOC  00000003 BRXT 0100000D)
[    0.007554] ACPI: APIC 0x0000000079435D40 000084 (v04 INTEL  GLK-SOC  00000003 BRXT 0100000D)
[    0.007558] ACPI: NPKT 0x0000000079435DD0 000065 (v01 INTEL  GLK-SOC  00000003 BRXT 0100000D)
[    0.007562] ACPI: SSDT 0x0000000079435E40 003F28 (v02 INTEL  DptfTab  00000003 BRXT 0100000D)
[    0.007567] ACPI: SSDT 0x0000000079439D70 000C8F (v02 INTEL  UsbCTabl 00000003 BRXT 0100000D)
[    0.007572] ACPI: SSDT 0x000000007943AA00 0007DE (v01 Intel_ Platform 00001000 INTL 20160930)
[    0.007576] ACPI: SSDT 0x000000007943B1E0 0000B1 (v01 Intel_ ADebTabl 00001000 INTL 20160930)
[    0.007581] ACPI: SSDT 0x000000007943B2A0 0005BC (v02 PmRef  Cpu0Ist  00003000 INTL 20160930)
[    0.007586] ACPI: SSDT 0x000000007943B860 000775 (v02 CpuRef CpuSsdt  00003000 INTL 20160930)
[    0.007591] ACPI: SSDT 0x000000007943BFE0 00035F (v02 PmRef  Cpu0Tst  00003000 INTL 20160930)
[    0.007595] ACPI: SSDT 0x000000007943C340 0001E6 (v02 PmRef  ApTst    00003000 INTL 20160930)
[    0.007600] ACPI: SSDT 0x000000007943C530 00286F (v02 SaSsdt SaSsdt   00003000 INTL 20160930)
[    0.007605] ACPI: UEFI 0x000000007943EDA0 000048 (v01 ALASKA A M I    00000002      01000013)
[    0.007609] ACPI: TPM2 0x000000007943EDF0 000034 (v04 ALASKA A M I    00000001 AMI  00000000)
[    0.007613] ACPI: DMAR 0x000000007943EE30 0000A8 (v01 INTEL  GLK-SOC  00000003 BRXT 0100000D)
[    0.007617] ACPI: WDAT 0x000000007943EEE0 000104 (v01                 00000000      00000000)
[    0.007622] ACPI: WSMT 0x000000007943EFF0 000028 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.007626] ACPI: Reserving FACP table memory at [mem 0x79435990-0x79435aa3]
[    0.007628] ACPI: Reserving DSDT table memory at [mem 0x79429250-0x79435986]
[    0.007630] ACPI: Reserving FACS table memory at [mem 0x7947f080-0x7947f0bf]
[    0.007631] ACPI: Reserving FPDT table memory at [mem 0x79435ab0-0x79435af3]
[    0.007632] ACPI: Reserving FIDT table memory at [mem 0x79435b00-0x79435b9b]
[    0.007634] ACPI: Reserving MCFG table memory at [mem 0x79435ba0-0x79435bdb]
[    0.007635] ACPI: Reserving DBG2 table memory at [mem 0x79435be0-0x79435c51]
[    0.007636] ACPI: Reserving DBGP table memory at [mem 0x79435c60-0x79435c93]
[    0.007638] ACPI: Reserving HPET table memory at [mem 0x79435ca0-0x79435cd7]
[    0.007639] ACPI: Reserving LPIT table memory at [mem 0x79435ce0-0x79435d3b]
[    0.007640] ACPI: Reserving APIC table memory at [mem 0x79435d40-0x79435dc3]
[    0.007642] ACPI: Reserving NPKT table memory at [mem 0x79435dd0-0x79435e34]
[    0.007643] ACPI: Reserving SSDT table memory at [mem 0x79435e40-0x79439d67]
[    0.007645] ACPI: Reserving SSDT table memory at [mem 0x79439d70-0x7943a9fe]
[    0.007646] ACPI: Reserving SSDT table memory at [mem 0x7943aa00-0x7943b1dd]
[    0.007648] ACPI: Reserving SSDT table memory at [mem 0x7943b1e0-0x7943b290]
[    0.007649] ACPI: Reserving SSDT table memory at [mem 0x7943b2a0-0x7943b85b]
[    0.007650] ACPI: Reserving SSDT table memory at [mem 0x7943b860-0x7943bfd4]
[    0.007652] ACPI: Reserving SSDT table memory at [mem 0x7943bfe0-0x7943c33e]
[    0.007653] ACPI: Reserving SSDT table memory at [mem 0x7943c340-0x7943c525]
[    0.007655] ACPI: Reserving SSDT table memory at [mem 0x7943c530-0x7943ed9e]
[    0.007656] ACPI: Reserving UEFI table memory at [mem 0x7943eda0-0x7943ede7]
[    0.007658] ACPI: Reserving TPM2 table memory at [mem 0x7943edf0-0x7943ee23]
[    0.007659] ACPI: Reserving DMAR table memory at [mem 0x7943ee30-0x7943eed7]
[    0.007661] ACPI: Reserving WDAT table memory at [mem 0x7943eee0-0x7943efe3]
[    0.007663] ACPI: Reserving WSMT table memory at [mem 0x7943eff0-0x7943f017]
[    0.007785] No NUMA configuration found
[    0.007786] Faking a node at [mem 0x0000000000000000-0x000000027fffffff]
[    0.007793] NODE_DATA(0) allocated [mem 0x27fffc000-0x27fffffff]
[    0.007854] Zone ranges:
[    0.007855]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.007858]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.007861]   Normal   [mem 0x0000000100000000-0x000000027fffffff]
[    0.007863]   Device   empty
[    0.007864] Movable zone start for each node
[    0.007865] Early memory node ranges
[    0.007866]   node   0: [mem 0x0000000000001000-0x000000000003dfff]
[    0.007868]   node   0: [mem 0x0000000000040000-0x000000000009efff]
[    0.007869]   node   0: [mem 0x0000000000100000-0x000000000fffffff]
[    0.007871]   node   0: [mem 0x0000000012151000-0x0000000076783fff]
[    0.007873]   node   0: [mem 0x0000000079049000-0x0000000079124fff]
[    0.007874]   node   0: [mem 0x0000000079e17000-0x000000007a765fff]
[    0.007876]   node   0: [mem 0x000000007a812000-0x000000007abfffff]
[    0.007877]   node   0: [mem 0x0000000100000000-0x000000027fffffff]
[    0.007880] Initmem setup node 0 [mem 0x0000000000001000-0x000000027fffffff]
[    0.007886] On node 0, zone DMA: 1 pages in unavailable ranges
[    0.007889] On node 0, zone DMA: 2 pages in unavailable ranges
[    0.007935] On node 0, zone DMA: 97 pages in unavailable ranges
[    0.013172] On node 0, zone DMA32: 8529 pages in unavailable ranges
[    0.013363] On node 0, zone DMA32: 10437 pages in unavailable ranges
[    0.013449] On node 0, zone DMA32: 3314 pages in unavailable ranges
[    0.013465] On node 0, zone DMA32: 172 pages in unavailable ranges
[    0.030689] On node 0, zone Normal: 21504 pages in unavailable ranges
[    0.030713] Reserving Intel graphics memory at [mem 0x7c000000-0x7fffffff]
[    0.031151] ACPI: PM-Timer IO Port: 0x408
[    0.031164] ACPI: LAPIC_NMI (acpi_id[0x01] high level lint[0x1])
[    0.031167] ACPI: LAPIC_NMI (acpi_id[0x02] high level lint[0x1])
[    0.031169] ACPI: LAPIC_NMI (acpi_id[0x03] high level lint[0x1])
[    0.031170] ACPI: LAPIC_NMI (acpi_id[0x04] high level lint[0x1])
[    0.031206] IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-119
[    0.031211] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.031214] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[    0.031220] ACPI: Using ACPI (MADT) for SMP configuration information
[    0.031222] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[    0.031230] TSC deadline timer available
[    0.031232] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[    0.031295] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.031299] PM: hibernation: Registered nosave memory: [mem 0x0003e000-0x0003ffff]
[    0.031303] PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x000fffff]
[    0.031306] PM: hibernation: Registered nosave memory: [mem 0x10000000-0x12150fff]
[    0.031309] PM: hibernation: Registered nosave memory: [mem 0x76784000-0x79048fff]
[    0.031312] PM: hibernation: Registered nosave memory: [mem 0x79125000-0x7947ffff]
[    0.031313] PM: hibernation: Registered nosave memory: [mem 0x79480000-0x79d6ffff]
[    0.031315] PM: hibernation: Registered nosave memory: [mem 0x79d70000-0x79e16fff]
[    0.031318] PM: hibernation: Registered nosave memory: [mem 0x7a766000-0x7a811fff]
[    0.031321] PM: hibernation: Registered nosave memory: [mem 0x7ac00000-0x7fffffff]
[    0.031322] PM: hibernation: Registered nosave memory: [mem 0x80000000-0xcfffffff]
[    0.031323] PM: hibernation: Registered nosave memory: [mem 0xd0000000-0xd0ffffff]
[    0.031325] PM: hibernation: Registered nosave memory: [mem 0xd1000000-0xd3708fff]
[    0.031326] PM: hibernation: Registered nosave memory: [mem 0xd3709000-0xd3709fff]
[    0.031327] PM: hibernation: Registered nosave memory: [mem 0xd370a000-0xdfffffff]
[    0.031328] PM: hibernation: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[    0.031329] PM: hibernation: Registered nosave memory: [mem 0xf0000000-0xfe041fff]
[    0.031331] PM: hibernation: Registered nosave memory: [mem 0xfe042000-0xfe044fff]
[    0.031332] PM: hibernation: Registered nosave memory: [mem 0xfe045000-0xfe8fffff]
[    0.031333] PM: hibernation: Registered nosave memory: [mem 0xfe900000-0xfe902fff]
[    0.031334] PM: hibernation: Registered nosave memory: [mem 0xfe903000-0xfebfffff]
[    0.031335] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[    0.031336] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfed00fff]
[    0.031338] PM: hibernation: Registered nosave memory: [mem 0xfed01000-0xfed01fff]
[    0.031339] PM: hibernation: Registered nosave memory: [mem 0xfed02000-0xfedfffff]
[    0.031340] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[    0.031341] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xff7fffff]
[    0.031342] PM: hibernation: Registered nosave memory: [mem 0xff800000-0xffffffff]
[    0.031347] [mem 0x80000000-0xcfffffff] available for PCI devices
[    0.031349] Booting paravirtualized kernel on bare hardware
[    0.031353] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1910969940391419 ns
[    0.039087] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:4 nr_node_ids:1
[    0.039511] percpu: Embedded 61 pages/cpu s212992 r8192 d28672 u524288
[    0.039526] pcpu-alloc: s212992 r8192 d28672 u524288 alloc=1*2097152
[    0.039532] pcpu-alloc: [0] 0 1 2 3
[    0.039582] Built 1 zonelists, mobility grouping on.  Total pages: 2020858
[    0.039586] Policy zone: Normal
[    0.039588] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-rt-x86_64 root=UUID=269048c7-1b02-4bf8-b1d4-49bac336e1da rw quiet apparmor=1 security=apparmor resume=UUID=54cc14b0-30dc-4f45-910d-00aba1a77ac0 udev.log_priority=3 processor.max_cstate=1 idle=poll pci=pcie_bus_safe
[    0.039838] Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-5.15-rt-x86_64", will be passed to user space.
[    0.041052] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.041677] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.041748] mem auto-init: stack:byref_all(zero), heap alloc:on, heap free:off
[    0.094278] Memory: 7948836K/8212384K available (14344K kernel code, 2111K rwdata, 9360K rodata, 1812K init, 4056K bss, 263288K reserved, 0K cma-reserved)
[    0.094289] random: random: get_random_u64 called from __kmem_cache_create+0x1e/0x640 with crng_init=0
[    0.094522] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.094552] ftrace: allocating 42386 entries in 166 pages
[    0.116174] ftrace: allocated 166 pages with 4 groups
[    0.116382] rcu: Preemptible hierarchical RCU implementation.
[    0.116384] rcu: 	RCU dyntick-idle grace-period acceleration is enabled.
[    0.116385] rcu: 	RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=4.
[    0.116386] rcu: 	RCU priority boosting: priority 1 delay 500 ms.
[    0.116387] rcu: 	RCU_SOFTIRQ processing moved to rcuc kthreads.
[    0.116388] 	No expedited grace period (rcu_normal_after_boot).
[    0.116389] 	Trampoline variant of Tasks RCU enabled.
[    0.116389] 	Rude variant of Tasks RCU enabled.
[    0.116390] 	Tracing variant of Tasks RCU enabled.
[    0.116391] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
[    0.116392] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.124642] NR_IRQS: 20736, nr_irqs: 1024, preallocated irqs: 16
[    0.125475] Console: colour dummy device 80x25
[    0.125479] printk: console [tty0] enabled
[    0.125512] ACPI: Core revision 20210730
[    0.125924] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 99544814920 ns
[    0.126017] APIC: Switch to symmetric I/O mode setup
[    0.126020] DMAR: Host address width 39
[    0.126021] DMAR: DRHD base: 0x000000fed64000 flags: 0x0
[    0.126033] DMAR: dmar0: reg_base_addr fed64000 ver 1:0 cap 1c0000c40660462 ecap 9e2ff0505e
[    0.126036] DMAR: DRHD base: 0x000000fed65000 flags: 0x1
[    0.126045] DMAR: dmar1: reg_base_addr fed65000 ver 1:0 cap d2008c40660462 ecap f050da
[    0.126049] DMAR: RMRR base: 0x00000078fe7000 end: 0x00000079006fff
[    0.126052] DMAR: RMRR base: 0x0000007b800000 end: 0x0000007fffffff
[    0.126056] DMAR-IR: IOAPIC id 1 under DRHD base  0xfed65000 IOMMU 1
[    0.126058] DMAR-IR: HPET id 0 under DRHD base 0xfed65000
[    0.126059] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[    0.128286] DMAR-IR: Enabled IRQ remapping in x2apic mode
[    0.128290] x2apic enabled
[    0.128314] Switched APIC routing to cluster x2apic.
[    0.133265] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.137978] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x3990bec8342, max_idle_ns: 881590769617 ns
[    0.138006] Calibrating delay loop (skipped), value calculated using timer frequency.. 3993.60 BogoMIPS (lpj=1996800)
[    0.138011] pid_max: default: 32768 minimum: 301
[    0.138056] LSM: Security Framework initializing
[    0.138069] landlock: Up and running.
[    0.138070] Yama: becoming mindful.
[    0.138124] AppArmor: AppArmor initialized
[    0.138171] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.138198] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.138652] x86/cpu: SGX disabled by BIOS.
[    0.138667] CPU0: Thermal monitoring enabled (TM1)
[    0.138670] x86/cpu: User Mode Instruction Prevention (UMIP) activated
[    0.138781] Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
[    0.138783] Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
[    0.138788] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.138792] Spectre V2 : Mitigation: Enhanced IBRS
[    0.138794] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.138797] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.138799] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[    0.146025] Freeing SMP alternatives memory: 36K
[    0.146208] smpboot: Estimated ratio of average max frequency by base frequency (times 1024): 1382
[    0.146229] smpboot: CPU0: Intel(R) Celeron(R) J4125 CPU @ 2.00GHz (family: 0x6, model: 0x7a, stepping: 0x8)
[    0.146572] Performance Events: PEBS fmt3+, Goldmont plus events, 32-deep LBR, full-width counters, Intel PMU driver.
[    0.146593] ... version:                4
[    0.146594] ... bit width:              48
[    0.146595] ... generic registers:      4
[    0.146596] ... value mask:             0000ffffffffffff
[    0.146597] ... max period:             00007fffffffffff
[    0.146598] ... fixed-purpose events:   3
[    0.146599] ... event mask:             000000070000000f
[    0.146772] rcu: Hierarchical SRCU implementation.
[    0.147786] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.147911] smp: Bringing up secondary CPUs ...
[    0.148258] x86: Booting SMP configuration:
[    0.148260] .... node  #0, CPUs:      #1 #2 #3
[    0.160790] smp: Brought up 1 node, 4 CPUs
[    0.160790] smpboot: Max logical packages: 1
[    0.160790] smpboot: Total of 4 processors activated (15974.40 BogoMIPS)
[    0.162073] devtmpfs: initialized
[    0.162120] x86/mm: Memory block size: 128MB
[    0.164197] ACPI: PM: Registering ACPI NVS region [mem 0x79125000-0x7947ffff] (3518464 bytes)
[    0.164404] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[    0.164424] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.164517] pinctrl core: initialized pinctrl subsystem
[    0.165186] PM: RTC time: 09:04:17, date: 2021-12-24
[    0.165453] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.165956] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.166152] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.166339] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.166370] audit: initializing netlink subsys (disabled)
[    0.166391] audit: type=2000 audit(1640336657.036:1): state=initialized audit_enabled=0 res=1
[    0.166391] thermal_sys: Registered thermal governor 'fair_share'
[    0.166391] thermal_sys: Registered thermal governor 'bang_bang'
[    0.166391] thermal_sys: Registered thermal governor 'step_wise'
[    0.166391] thermal_sys: Registered thermal governor 'user_space'
[    0.166391] thermal_sys: Registered thermal governor 'power_allocator'
[    0.166391] cpuidle: using governor ladder
[    0.166391] cpuidle: using governor menu
[    0.167046] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.167049] ACPI: bus type PCI registered
[    0.167051] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.167209] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[    0.167217] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[    0.167249] PCI: Using configuration type 1 for base access
[    0.171384] Kprobes globally optimized
[    0.171384] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.171384] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.174249] ACPI: Added _OSI(Module Device)
[    0.174252] ACPI: Added _OSI(Processor Device)
[    0.174253] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.174254] ACPI: Added _OSI(Processor Aggregator Device)
[    0.174256] ACPI: Added _OSI(Linux-Dell-Video)
[    0.174258] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.174260] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[    0.205221] ACPI: 10 ACPI AML tables successfully acquired and loaded
[    0.215127] ACPI: Dynamic OEM Table Load:
[    0.215138] ACPI: SSDT 0xFFFF891B81106E00 000190 (v02 PmRef  Cpu0Cst  00003001 INTL 20160930)
[    0.217427] ACPI: Dynamic OEM Table Load:
[    0.217436] ACPI: SSDT 0xFFFF891B81107A00 0001E6 (v02 PmRef  ApIst    00003000 INTL 20160930)
[    0.219140] ACPI: Dynamic OEM Table Load:
[    0.219147] ACPI: SSDT 0xFFFF891B810E4500 0000C9 (v02 PmRef  ApCst    00003000 INTL 20160930)
[    0.223119] ACPI: EC: EC started
[    0.223120] ACPI: EC: interrupt blocked
[    0.330168] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.330173] ACPI: \_SB_.PCI0.SBRG.H_EC: Boot DSDT EC used to handle transactions
[    0.330175] ACPI: Interpreter enabled
[    0.330228] ACPI: PM: (supports S0 S3 S4 S5)
[    0.330230] ACPI: Using IOAPIC for interrupt routing
[    0.330302] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.331298] ACPI: Enabled 7 GPEs in block 00 to 7F
[    0.341850] ACPI: PM: Power Resource [DRST]
[    0.342443] ACPI: PM: Power Resource [DRST]
[    0.343043] ACPI: PM: Power Resource [DRST]
[    0.343637] ACPI: PM: Power Resource [DRST]
[    0.344231] ACPI: PM: Power Resource [DRST]
[    0.344822] ACPI: PM: Power Resource [DRST]
[    0.345571] ACPI: PM: Power Resource [WRST]
[    0.355841] ACPI: PM: Power Resource [FN00]
[    0.357560] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[    0.357573] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[    0.357703] acpi PNP0A08:00: _OSC: platform retains control of PCIe features (AE_ERROR)
[    0.358058] acpi PNP0A08:00: host bridge window [mem 0x1000000010000 window] (ignored, not CPU addressable)
[    0.359740] PCI host bridge to bus 0000:00
[    0.359742] pci_bus 0000:00: root bus resource [io  0x0070-0x0077]
[    0.359746] pci_bus 0000:00: root bus resource [io  0x0000-0x006f window]
[    0.359748] pci_bus 0000:00: root bus resource [io  0x0078-0x0cf7 window]
[    0.359751] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.359753] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.359756] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000dffff window]
[    0.359758] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000fffff window]
[    0.359760] pci_bus 0000:00: root bus resource [mem 0x7c000001-0x7fffffff window]
[    0.359763] pci_bus 0000:00: root bus resource [mem 0x80000000-0xbfffffff window]
[    0.359766] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xefffffff window]
[    0.359768] pci_bus 0000:00: root bus resource [mem 0xfea00000-0xfeafffff window]
[    0.359770] pci_bus 0000:00: root bus resource [mem 0xfed00000-0xfed003ff window]
[    0.359773] pci_bus 0000:00: root bus resource [mem 0xfed01000-0xfed01fff window]
[    0.359775] pci_bus 0000:00: root bus resource [mem 0xfed03000-0xfed03fff window]
[    0.359777] pci_bus 0000:00: root bus resource [mem 0xfed06000-0xfed06fff window]
[    0.359779] pci_bus 0000:00: root bus resource [mem 0xfed08000-0xfed09fff window]
[    0.359781] pci_bus 0000:00: root bus resource [mem 0xfed80000-0xfedbffff window]
[    0.359784] pci_bus 0000:00: root bus resource [mem 0xfed1c000-0xfed1cfff window]
[    0.359786] pci_bus 0000:00: root bus resource [mem 0xfee00000-0xfeefffff window]
[    0.359789] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.360819] pci 0000:00:00.0: [8086:31f0] type 00 class 0x060000
[    0.362048] pci 0000:00:00.1: [8086:318c] type 00 class 0x118000
[    0.362077] pci 0000:00:00.1: reg 0x10: [mem 0x80000000-0x80007fff 64bit]
[    0.363327] pci 0000:00:02.0: [8086:3185] type 00 class 0x030000
[    0.363339] pci 0000:00:02.0: reg 0x10: [mem 0xa0000000-0xa0ffffff 64bit]
[    0.363346] pci 0000:00:02.0: reg 0x18: [mem 0x90000000-0x9fffffff 64bit pref]
[    0.363352] pci 0000:00:02.0: reg 0x20: [io  0xf000-0xf03f]
[    0.363376] pci 0000:00:02.0: BAR 2: assigned to efifb
[    0.364899] pci 0000:00:0e.0: [8086:3198] type 00 class 0x040300
[    0.364920] pci 0000:00:0e.0: reg 0x10: [mem 0xa1710000-0xa1713fff 64bit]
[    0.364968] pci 0000:00:0e.0: reg 0x20: [mem 0xa1000000-0xa10fffff 64bit]
[    0.365034] pci 0000:00:0e.0: PME# supported from D0 D3hot D3cold
[    0.369451] pci 0000:00:0f.0: [8086:319a] type 00 class 0x078000
[    0.369503] pci 0000:00:0f.0: reg 0x10: [mem 0xa172b000-0xa172bfff 64bit]
[    0.369613] pci 0000:00:0f.0: PME# supported from D3hot
[    0.370840] pci 0000:00:12.0: [8086:31e3] type 00 class 0x010601
[    0.370856] pci 0000:00:12.0: reg 0x10: [mem 0xa1714000-0xa1715fff]
[    0.370866] pci 0000:00:12.0: reg 0x14: [mem 0xa172a000-0xa172a0ff]
[    0.370875] pci 0000:00:12.0: reg 0x18: [io  0xf090-0xf097]
[    0.370885] pci 0000:00:12.0: reg 0x1c: [io  0xf080-0xf083]
[    0.370894] pci 0000:00:12.0: reg 0x20: [io  0xf060-0xf07f]
[    0.370903] pci 0000:00:12.0: reg 0x24: [mem 0xa1729000-0xa17297ff]
[    0.370950] pci 0000:00:12.0: PME# supported from D3hot
[    0.372169] pci 0000:00:13.0: [8086:31d8] type 01 class 0x060400
[    0.372249] pci 0000:00:13.0: PME# supported from D0 D3hot D3cold
[    0.373521] pci 0000:00:14.0: [8086:31d6] type 01 class 0x060400
[    0.373597] pci 0000:00:14.0: PME# supported from D0 D3hot D3cold
[    0.374816] pci 0000:00:14.1: [8086:31d7] type 01 class 0x060400
[    0.374896] pci 0000:00:14.1: PME# supported from D0 D3hot D3cold
[    0.376147] pci 0000:00:15.0: [8086:31a8] type 00 class 0x0c0330
[    0.376167] pci 0000:00:15.0: reg 0x10: [mem 0xa1700000-0xa170ffff 64bit]
[    0.376244] pci 0000:00:15.0: PME# supported from D3hot D3cold
[    0.377448] pci 0000:00:17.0: [8086:31b4] type 00 class 0x118000
[    0.377468] pci 0000:00:17.0: reg 0x10: [mem 0xa1728000-0xa1728fff 64bit]
[    0.377483] pci 0000:00:17.0: reg 0x18: [mem 0xa1727000-0xa1727fff 64bit]
[    0.378718] pci 0000:00:17.1: [8086:31b6] type 00 class 0x118000
[    0.378740] pci 0000:00:17.1: reg 0x10: [mem 0xa1726000-0xa1726fff 64bit]
[    0.378753] pci 0000:00:17.1: reg 0x18: [mem 0xa1725000-0xa1725fff 64bit]
[    0.379976] pci 0000:00:17.2: [8086:31b8] type 00 class 0x118000
[    0.379997] pci 0000:00:17.2: reg 0x10: [mem 0xa1724000-0xa1724fff 64bit]
[    0.380011] pci 0000:00:17.2: reg 0x18: [mem 0xa1723000-0xa1723fff 64bit]
[    0.381262] pci 0000:00:18.0: [8086:31bc] type 00 class 0x118000
[    0.381283] pci 0000:00:18.0: reg 0x10: [mem 0xa1722000-0xa1722fff 64bit]
[    0.381298] pci 0000:00:18.0: reg 0x18: [mem 0xa1721000-0xa1721fff 64bit]
[    0.382513] pci 0000:00:18.1: [8086:31be] type 00 class 0x118000
[    0.382534] pci 0000:00:18.1: reg 0x10: [mem 0xa1720000-0xa1720fff 64bit]
[    0.382565] pci 0000:00:18.1: reg 0x18: [mem 0xa171f000-0xa171ffff 64bit]
[    0.383785] pci 0000:00:18.2: [8086:31c0] type 00 class 0x118000
[    0.383806] pci 0000:00:18.2: reg 0x10: [mem 0xfea10000-0xfea10fff 64bit]
[    0.383821] pci 0000:00:18.2: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[    0.385038] pci 0000:00:18.3: [8086:31ee] type 00 class 0x118000
[    0.385059] pci 0000:00:18.3: reg 0x10: [mem 0xa171e000-0xa171efff 64bit]
[    0.385089] pci 0000:00:18.3: reg 0x18: [mem 0xa171d000-0xa171dfff 64bit]
[    0.386314] pci 0000:00:19.0: [8086:31c2] type 00 class 0x118000
[    0.386334] pci 0000:00:19.0: reg 0x10: [mem 0xa171c000-0xa171cfff 64bit]
[    0.386349] pci 0000:00:19.0: reg 0x18: [mem 0xa171b000-0xa171bfff 64bit]
[    0.387607] pci 0000:00:1c.0: [8086:31cc] type 00 class 0x080501
[    0.387627] pci 0000:00:1c.0: reg 0x10: [mem 0xa171a000-0xa171afff 64bit]
[    0.387642] pci 0000:00:1c.0: reg 0x18: [mem 0xa1719000-0xa1719fff 64bit]
[    0.389159] pci 0000:00:1e.0: [8086:31d0] type 00 class 0x080501
[    0.389180] pci 0000:00:1e.0: reg 0x10: [mem 0xa1718000-0xa1718fff 64bit]
[    0.389194] pci 0000:00:1e.0: reg 0x18: [mem 0xa1717000-0xa1717fff 64bit]
[    0.390409] pci 0000:00:1f.0: [8086:31e8] type 00 class 0x060100
[    0.391242] pci 0000:00:1f.1: [8086:31d4] type 00 class 0x0c0500
[    0.391302] pci 0000:00:1f.1: reg 0x10: [mem 0xa1716000-0xa17160ff 64bit]
[    0.391380] pci 0000:00:1f.1: reg 0x20: [io  0xf040-0xf05f]
[    0.392186] pci 0000:01:00.0: [12d8:2608] type 01 class 0x060400
[    0.392312] pci 0000:01:00.0: supports D1 D2
[    0.392314] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.392574] pci 0000:00:13.0: PCI bridge to [bus 01-06]
[    0.392596] pci 0000:00:13.0:   bridge window [mem 0xa1100000-0xa14fffff]
[    0.392687] pci 0000:02:01.0: [12d8:2608] type 01 class 0x060400
[    0.392815] pci 0000:02:01.0: supports D1 D2
[    0.392817] pci 0000:02:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.392964] pci 0000:02:02.0: [12d8:2608] type 01 class 0x060400
[    0.393112] pci 0000:02:02.0: supports D1 D2
[    0.393114] pci 0000:02:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.393264] pci 0000:02:03.0: [12d8:2608] type 01 class 0x060400
[    0.393390] pci 0000:02:03.0: supports D1 D2
[    0.393391] pci 0000:02:03.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.393546] pci 0000:02:04.0: [12d8:2608] type 01 class 0x060400
[    0.393690] pci 0000:02:04.0: supports D1 D2
[    0.393691] pci 0000:02:04.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.393838] pci 0000:01:00.0: PCI bridge to [bus 02-06]
[    0.393847] pci 0000:01:00.0:   bridge window [mem 0xa1100000-0xa14fffff]
[    0.393939] pci 0000:03:00.0: [1912:0015] type 00 class 0x0c0330
[    0.393969] pci 0000:03:00.0: reg 0x10: [mem 0xa1400000-0xa1401fff 64bit]
[    0.394147] pci 0000:03:00.0: PME# supported from D0 D3hot D3cold
[    0.394288] pci 0000:02:01.0: PCI bridge to [bus 03]
[    0.394297] pci 0000:02:01.0:   bridge window [mem 0xa1400000-0xa14fffff]
[    0.394386] pci 0000:04:00.0: [1912:0015] type 00 class 0x0c0330
[    0.394416] pci 0000:04:00.0: reg 0x10: [mem 0xa1300000-0xa1301fff 64bit]
[    0.394573] pci 0000:04:00.0: PME# supported from D0 D3hot D3cold
[    0.394733] pci 0000:02:02.0: PCI bridge to [bus 04]
[    0.394742] pci 0000:02:02.0:   bridge window [mem 0xa1300000-0xa13fffff]
[    0.394832] pci 0000:05:00.0: [1912:0015] type 00 class 0x0c0330
[    0.394863] pci 0000:05:00.0: reg 0x10: [mem 0xa1200000-0xa1201fff 64bit]
[    0.395022] pci 0000:05:00.0: PME# supported from D0 D3hot D3cold
[    0.395159] pci 0000:02:03.0: PCI bridge to [bus 05]
[    0.395168] pci 0000:02:03.0:   bridge window [mem 0xa1200000-0xa12fffff]
[    0.395271] pci 0000:06:00.0: [1912:0015] type 00 class 0x0c0330
[    0.395301] pci 0000:06:00.0: reg 0x10: [mem 0xa1100000-0xa1101fff 64bit]
[    0.395458] pci 0000:06:00.0: PME# supported from D0 D3hot D3cold
[    0.395606] pci 0000:02:04.0: PCI bridge to [bus 06]
[    0.395627] pci 0000:02:04.0:   bridge window [mem 0xa1100000-0xa11fffff]
[    0.395770] pci 0000:07:00.0: [8086:1539] type 00 class 0x020000
[    0.395795] pci 0000:07:00.0: reg 0x10: [mem 0xa1600000-0xa161ffff]
[    0.395822] pci 0000:07:00.0: reg 0x18: [io  0xe000-0xe01f]
[    0.395837] pci 0000:07:00.0: reg 0x1c: [mem 0xa1620000-0xa1623fff]
[    0.395978] pci 0000:07:00.0: PME# supported from D0 D3hot D3cold
[    0.396207] pci 0000:00:14.0: PCI bridge to [bus 07]
[    0.396212] pci 0000:00:14.0:   bridge window [io  0xe000-0xefff]
[    0.396216] pci 0000:00:14.0:   bridge window [mem 0xa1600000-0xa16fffff]
[    0.396334] pci 0000:08:00.0: [8086:1539] type 00 class 0x020000
[    0.396360] pci 0000:08:00.0: reg 0x10: [mem 0xa1500000-0xa151ffff]
[    0.396386] pci 0000:08:00.0: reg 0x18: [io  0xd000-0xd01f]
[    0.396400] pci 0000:08:00.0: reg 0x1c: [mem 0xa1520000-0xa1523fff]
[    0.396540] pci 0000:08:00.0: PME# supported from D0 D3hot D3cold
[    0.396787] pci 0000:00:14.1: PCI bridge to [bus 08]
[    0.396792] pci 0000:00:14.1:   bridge window [io  0xd000-0xdfff]
[    0.396796] pci 0000:00:14.1:   bridge window [mem 0xa1500000-0xa15fffff]
[    0.396819] pci 0000:00:13.0: Max Payload Size set to  128/ 256 (was  256), Max Read Rq  128
[    0.396828] pci 0000:01:00.0: Max Payload Size set to  128/ 256 (was  128), Max Read Rq  128
[    0.396836] pci 0000:02:01.0: Max Payload Size set to  128/ 256 (was  128), Max Read Rq  128
[    0.396847] pci 0000:03:00.0: Max Payload Size set to  128/ 128 (was  128), Max Read Rq  512
[    0.396855] pci 0000:02:02.0: Max Payload Size set to  128/ 256 (was  128), Max Read Rq  128
[    0.396866] pci 0000:04:00.0: Max Payload Size set to  128/ 128 (was  128), Max Read Rq  512
[    0.396873] pci 0000:02:03.0: Max Payload Size set to  128/ 256 (was  128), Max Read Rq  128
[    0.396884] pci 0000:05:00.0: Max Payload Size set to  128/ 128 (was  128), Max Read Rq  512
[    0.396892] pci 0000:02:04.0: Max Payload Size set to  128/ 256 (was  128), Max Read Rq  128
[    0.396903] pci 0000:06:00.0: Max Payload Size set to  128/ 128 (was  128), Max Read Rq  512
[    0.396909] pci 0000:00:14.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  128
[    0.396920] pci 0000:07:00.0: Max Payload Size set to  256/ 512 (was  256), Max Read Rq  512
[    0.396926] pci 0000:00:14.1: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  128
[    0.396937] pci 0000:08:00.0: Max Payload Size set to  256/ 512 (was  256), Max Read Rq  512
[    0.400375] ACPI: PCI: Interrupt link LNKA configured for IRQ 3
[    0.400576] ACPI: PCI: Interrupt link LNKB configured for IRQ 4
[    0.400781] ACPI: PCI: Interrupt link LNKC configured for IRQ 5
[    0.400977] ACPI: PCI: Interrupt link LNKD configured for IRQ 11
[    0.401186] ACPI: PCI: Interrupt link LNKE configured for IRQ 7
[    0.401382] ACPI: PCI: Interrupt link LNKF configured for IRQ 9
[    0.401578] ACPI: PCI: Interrupt link LNKG configured for IRQ 10
[    0.401774] ACPI: PCI: Interrupt link LNKH configured for IRQ 11
[    0.410374] ACPI Warning: GPE type mismatch (level/edge) (20210730/evxface-791)
[    0.410405] ACPI: EC: interrupt unblocked
[    0.410406] ACPI: EC: event unblocked
[    0.410423] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.410425] ACPI: EC: GPE=0x26
[    0.410428] ACPI: \_SB_.PCI0.SBRG.H_EC: Boot DSDT EC initialization complete
[    0.410431] ACPI: \_SB_.PCI0.SBRG.H_EC: EC: Used to handle transactions and events
[    0.411055] iommu: Default domain type: Translated
[    0.411057] iommu: DMA domain TLB invalidation policy: lazy mode
[    0.411084] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[    0.411084] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.411084] pci 0000:00:02.0: vgaarb: bridge control possible
[    0.411084] vgaarb: loaded
[    0.411302] SCSI subsystem initialized
[    0.411302] libata version 3.00 loaded.
[    0.411302] ACPI: bus type USB registered
[    0.411302] usbcore: registered new interface driver usbfs
[    0.411302] usbcore: registered new interface driver hub
[    0.411302] usbcore: registered new device driver usb
[    0.411302] pps_core: LinuxPPS API ver. 1 registered
[    0.411302] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.411302] PTP clock support registered
[    0.411302] EDAC MC: Ver: 3.0.0
[    0.412198] NetLabel: Initializing
[    0.412198] NetLabel:  domain hash size = 128
[    0.412198] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.412198] NetLabel:  unlabeled traffic allowed by default
[    0.412198] PCI: Using ACPI for IRQ routing
[    0.440852] PCI: pci_cache_line_size set to 64 bytes
[    0.441021] e820: reserve RAM buffer [mem 0x0003e000-0x0003ffff]
[    0.441025] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[    0.441027] e820: reserve RAM buffer [mem 0x76784000-0x77ffffff]
[    0.441029] e820: reserve RAM buffer [mem 0x79125000-0x7bffffff]
[    0.441031] e820: reserve RAM buffer [mem 0x7a766000-0x7bffffff]
[    0.441033] e820: reserve RAM buffer [mem 0x7ac00000-0x7bffffff]
[    0.444145] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[    0.444160] hpet0: 8 comparators, 64-bit 19.200000 MHz counter
[    0.446183] clocksource: Switched to clocksource tsc-early
[    0.474982] VFS: Disk quotas dquot_6.6.0
[    0.475018] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.475338] AppArmor: AppArmor Filesystem Enabled
[    0.475433] pnp: PnP ACPI init
[    0.475736] system 00:00: [io  0x0680-0x069f] has been reserved
[    0.475743] system 00:00: [io  0x0400-0x047f] could not be reserved
[    0.475747] system 00:00: [io  0x0500-0x05fe] has been reserved
[    0.475750] system 00:00: [io  0x0600-0x061f] has been reserved
[    0.475753] system 00:00: [io  0x164e-0x164f] has been reserved
[    0.476824] system 00:01: [mem 0xe0000000-0xefffffff] has been reserved
[    0.476830] system 00:01: [mem 0xfea00000-0xfeafffff] could not be reserved
[    0.476835] system 00:01: [mem 0xfed01000-0xfed01fff] has been reserved
[    0.476840] system 00:01: [mem 0xfed03000-0xfed03fff] has been reserved
[    0.476845] system 00:01: [mem 0xfed06000-0xfed06fff] has been reserved
[    0.476849] system 00:01: [mem 0xfed08000-0xfed09fff] has been reserved
[    0.476854] system 00:01: [mem 0xfed80000-0xfedbffff] has been reserved
[    0.476859] system 00:01: [mem 0xfed1c000-0xfed1cfff] has been reserved
[    0.476862] system 00:01: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.478429] pnp: PnP ACPI: found 4 devices
[    0.486271] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.486398] NET: Registered PF_INET protocol family
[    0.486618] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.488490] tcp_listen_portaddr_hash hash table entries: 4096 (order: 5, 196608 bytes, linear)
[    0.488613] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.489659] TCP bind hash table entries: 65536 (order: 9, 2621440 bytes, linear)
[    0.490131] TCP: Hash tables configured (established 65536 bind 65536)
[    0.490357] MPTCP token hash table entries: 8192 (order: 6, 458752 bytes, linear)
[    0.490535] UDP hash table entries: 4096 (order: 6, 393216 bytes, linear)
[    0.490683] UDP-Lite hash table entries: 4096 (order: 6, 393216 bytes, linear)
[    0.490904] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.490917] NET: Registered PF_XDP protocol family
[    0.490932] pci 0000:02:01.0: bridge window [io  0x1000-0x0fff] to [bus 03] add_size 1000
[    0.490940] pci 0000:02:01.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03] add_size 200000 add_align 100000
[    0.490946] pci 0000:02:02.0: bridge window [io  0x1000-0x0fff] to [bus 04] add_size 1000
[    0.490950] pci 0000:02:02.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 04] add_size 200000 add_align 100000
[    0.490954] pci 0000:02:03.0: bridge window [io  0x1000-0x0fff] to [bus 05] add_size 1000
[    0.490958] pci 0000:02:03.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 05] add_size 200000 add_align 100000
[    0.490962] pci 0000:02:04.0: bridge window [io  0x1000-0x0fff] to [bus 06] add_size 1000
[    0.490965] pci 0000:02:04.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 06] add_size 200000 add_align 100000
[    0.490971] pci 0000:01:00.0: bridge window [io  0x1000-0x0fff] to [bus 02-06] add_size 4000
[    0.490975] pci 0000:01:00.0: bridge window [mem 0x00100000-0x004fffff 64bit pref] to [bus 02-06] add_size 800000 add_align 100000
[    0.490980] pci 0000:00:13.0: bridge window [io  0x1000-0x0fff] to [bus 01-06] add_size 4000
[    0.490986] pci 0000:00:13.0: bridge window [mem 0x00100000-0x004fffff 64bit pref] to [bus 01-06] add_size 800000 add_align 100000
[    0.491035] pci 0000:00:13.0: BAR 15: assigned [mem 0x80100000-0x80cfffff 64bit pref]
[    0.491042] pci 0000:00:13.0: BAR 13: assigned [io  0x2000-0x5fff]
[    0.491057] pci 0000:00:18.2: BAR 2: assigned [mem 0x80008000-0x80008fff 64bit]
[    0.491077] pci 0000:01:00.0: BAR 15: assigned [mem 0x80100000-0x80cfffff 64bit pref]
[    0.491080] pci 0000:01:00.0: BAR 13: assigned [io  0x2000-0x5fff]
[    0.491090] pci 0000:02:01.0: BAR 15: assigned [mem 0x80100000-0x802fffff 64bit pref]
[    0.491093] pci 0000:02:02.0: BAR 15: assigned [mem 0x80300000-0x804fffff 64bit pref]
[    0.491097] pci 0000:02:03.0: BAR 15: assigned [mem 0x80500000-0x806fffff 64bit pref]
[    0.491100] pci 0000:02:04.0: BAR 15: assigned [mem 0x80700000-0x808fffff 64bit pref]
[    0.491103] pci 0000:02:01.0: BAR 13: assigned [io  0x2000-0x2fff]
[    0.491105] pci 0000:02:02.0: BAR 13: assigned [io  0x3000-0x3fff]
[    0.491108] pci 0000:02:03.0: BAR 13: assigned [io  0x4000-0x4fff]
[    0.491110] pci 0000:02:04.0: BAR 13: assigned [io  0x5000-0x5fff]
[    0.491118] pci 0000:02:01.0: PCI bridge to [bus 03]
[    0.491122] pci 0000:02:01.0:   bridge window [io  0x2000-0x2fff]
[    0.491128] pci 0000:02:01.0:   bridge window [mem 0xa1400000-0xa14fffff]
[    0.491134] pci 0000:02:01.0:   bridge window [mem 0x80100000-0x802fffff 64bit pref]
[    0.491141] pci 0000:02:02.0: PCI bridge to [bus 04]
[    0.491144] pci 0000:02:02.0:   bridge window [io  0x3000-0x3fff]
[    0.491151] pci 0000:02:02.0:   bridge window [mem 0xa1300000-0xa13fffff]
[    0.491155] pci 0000:02:02.0:   bridge window [mem 0x80300000-0x804fffff 64bit pref]
[    0.491162] pci 0000:02:03.0: PCI bridge to [bus 05]
[    0.491165] pci 0000:02:03.0:   bridge window [io  0x4000-0x4fff]
[    0.491170] pci 0000:02:03.0:   bridge window [mem 0xa1200000-0xa12fffff]
[    0.491175] pci 0000:02:03.0:   bridge window [mem 0x80500000-0x806fffff 64bit pref]
[    0.491182] pci 0000:02:04.0: PCI bridge to [bus 06]
[    0.491185] pci 0000:02:04.0:   bridge window [io  0x5000-0x5fff]
[    0.491190] pci 0000:02:04.0:   bridge window [mem 0xa1100000-0xa11fffff]
[    0.491195] pci 0000:02:04.0:   bridge window [mem 0x80700000-0x808fffff 64bit pref]
[    0.491201] pci 0000:01:00.0: PCI bridge to [bus 02-06]
[    0.491205] pci 0000:01:00.0:   bridge window [io  0x2000-0x5fff]
[    0.491210] pci 0000:01:00.0:   bridge window [mem 0xa1100000-0xa14fffff]
[    0.491215] pci 0000:01:00.0:   bridge window [mem 0x80100000-0x80cfffff 64bit pref]
[    0.491221] pci 0000:00:13.0: PCI bridge to [bus 01-06]
[    0.491224] pci 0000:00:13.0:   bridge window [io  0x2000-0x5fff]
[    0.491228] pci 0000:00:13.0:   bridge window [mem 0xa1100000-0xa14fffff]
[    0.491232] pci 0000:00:13.0:   bridge window [mem 0x80100000-0x80cfffff 64bit pref]
[    0.491239] pci 0000:00:14.0: PCI bridge to [bus 07]
[    0.491241] pci 0000:00:14.0:   bridge window [io  0xe000-0xefff]
[    0.491246] pci 0000:00:14.0:   bridge window [mem 0xa1600000-0xa16fffff]
[    0.491254] pci 0000:00:14.1: PCI bridge to [bus 08]
[    0.491257] pci 0000:00:14.1:   bridge window [io  0xd000-0xdfff]
[    0.491262] pci 0000:00:14.1:   bridge window [mem 0xa1500000-0xa15fffff]
[    0.491270] pci_bus 0000:00: resource 4 [io  0x0070-0x0077]
[    0.491272] pci_bus 0000:00: resource 5 [io  0x0000-0x006f window]
[    0.491275] pci_bus 0000:00: resource 6 [io  0x0078-0x0cf7 window]
[    0.491277] pci_bus 0000:00: resource 7 [io  0x0d00-0xffff window]
[    0.491279] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000bffff window]
[    0.491281] pci_bus 0000:00: resource 9 [mem 0x000c0000-0x000dffff window]
[    0.491284] pci_bus 0000:00: resource 10 [mem 0x000e0000-0x000fffff window]
[    0.491286] pci_bus 0000:00: resource 11 [mem 0x7c000001-0x7fffffff window]
[    0.491288] pci_bus 0000:00: resource 12 [mem 0x80000000-0xbfffffff window]
[    0.491290] pci_bus 0000:00: resource 13 [mem 0xe0000000-0xefffffff window]
[    0.491292] pci_bus 0000:00: resource 14 [mem 0xfea00000-0xfeafffff window]
[    0.491295] pci_bus 0000:00: resource 15 [mem 0xfed00000-0xfed003ff window]
[    0.491297] pci_bus 0000:00: resource 16 [mem 0xfed01000-0xfed01fff window]
[    0.491299] pci_bus 0000:00: resource 17 [mem 0xfed03000-0xfed03fff window]
[    0.491301] pci_bus 0000:00: resource 18 [mem 0xfed06000-0xfed06fff window]
[    0.491303] pci_bus 0000:00: resource 19 [mem 0xfed08000-0xfed09fff window]
[    0.491305] pci_bus 0000:00: resource 20 [mem 0xfed80000-0xfedbffff window]
[    0.491307] pci_bus 0000:00: resource 21 [mem 0xfed1c000-0xfed1cfff window]
[    0.491310] pci_bus 0000:00: resource 22 [mem 0xfee00000-0xfeefffff window]
[    0.491313] pci_bus 0000:01: resource 0 [io  0x2000-0x5fff]
[    0.491315] pci_bus 0000:01: resource 1 [mem 0xa1100000-0xa14fffff]
[    0.491317] pci_bus 0000:01: resource 2 [mem 0x80100000-0x80cfffff 64bit pref]
[    0.491319] pci_bus 0000:02: resource 0 [io  0x2000-0x5fff]
[    0.491321] pci_bus 0000:02: resource 1 [mem 0xa1100000-0xa14fffff]
[    0.491323] pci_bus 0000:02: resource 2 [mem 0x80100000-0x80cfffff 64bit pref]
[    0.491326] pci_bus 0000:03: resource 0 [io  0x2000-0x2fff]
[    0.491328] pci_bus 0000:03: resource 1 [mem 0xa1400000-0xa14fffff]
[    0.491330] pci_bus 0000:03: resource 2 [mem 0x80100000-0x802fffff 64bit pref]
[    0.491333] pci_bus 0000:04: resource 0 [io  0x3000-0x3fff]
[    0.491335] pci_bus 0000:04: resource 1 [mem 0xa1300000-0xa13fffff]
[    0.491337] pci_bus 0000:04: resource 2 [mem 0x80300000-0x804fffff 64bit pref]
[    0.491340] pci_bus 0000:05: resource 0 [io  0x4000-0x4fff]
[    0.491342] pci_bus 0000:05: resource 1 [mem 0xa1200000-0xa12fffff]
[    0.491344] pci_bus 0000:05: resource 2 [mem 0x80500000-0x806fffff 64bit pref]
[    0.491347] pci_bus 0000:06: resource 0 [io  0x5000-0x5fff]
[    0.491349] pci_bus 0000:06: resource 1 [mem 0xa1100000-0xa11fffff]
[    0.491351] pci_bus 0000:06: resource 2 [mem 0x80700000-0x808fffff 64bit pref]
[    0.491354] pci_bus 0000:07: resource 0 [io  0xe000-0xefff]
[    0.491356] pci_bus 0000:07: resource 1 [mem 0xa1600000-0xa16fffff]
[    0.491359] pci_bus 0000:08: resource 0 [io  0xd000-0xdfff]
[    0.491360] pci_bus 0000:08: resource 1 [mem 0xa1500000-0xa15fffff]
[    0.491622] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.493734] PCI: CLS 64 bytes, default 64
[    0.493798] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.493800] software IO TLB: mapped [mem 0x00000000717f8000-0x00000000757f8000] (64MB)
[    0.493877] Trying to unpack rootfs image as initramfs...
[    0.493920] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x3990bec8342, max_idle_ns: 881590769617 ns
[    0.493950] clocksource: Switched to clocksource tsc
[    0.495475] Initialise system trusted keyrings
[    0.495498] Key type blacklist registered
[    0.495627] workingset: timestamp_bits=57 max_order=21 bucket_order=0
[    0.498414] zbud: loaded
[    0.510734] Key type asymmetric registered
[    0.510738] Asymmetric key parser 'x509' registered
[    0.510777] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.510847] io scheduler mq-deadline registered
[    0.510849] io scheduler kyber registered
[    0.510898] io scheduler bfq registered
[    0.513167] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    0.514229] ACPI: AC: AC Adapter [ADP1] (on-line)
[    0.514359] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:03/PNP0C09:00/PNP0C0D:00/input/input0
[    0.517060] ACPI: button: Lid Switch [LID0]
[    0.517155] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[    0.517201] ACPI: button: Power Button [PWRB]
[    0.522462] thermal LNXTHERM:00: registered as thermal_zone0
[    0.522465] ACPI: thermal: Thermal Zone [TZ01] (44 C)
[    0.522792] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[    0.527634] Non-volatile memory driver v1.3
[    0.527636] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[    0.527638] AMD-Vi: AMD IOMMUv2 functionality not available on this system
[    0.528568] ahci 0000:00:12.0: version 3.0
[    0.529033] ahci 0000:00:12.0: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
[    0.529039] ahci 0000:00:12.0: flags: 64bit ncq sntf pm clo only pmp pio slum part deso sadm sds apst
[    0.529654] scsi host0: ahci
[    0.529912] scsi host1: ahci
[    0.530024] ata1: SATA max UDMA/133 abar m2048@0xa1729000 port 0xa1729100 irq 129
[    0.530031] ata2: SATA max UDMA/133 abar m2048@0xa1729000 port 0xa1729180 irq 129
[    0.530124] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.530135] ehci-pci: EHCI PCI platform driver
[    0.530159] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.530171] ohci-pci: OHCI PCI platform driver
[    0.530194] uhci_hcd: USB Universal Host Controller Interface driver
[    0.530283] usbcore: registered new interface driver usbserial_generic
[    0.530293] usbserial: USB Serial support registered for generic
[    0.530456] rtc_cmos 00:03: RTC can wake from S4
[    0.531347] rtc_cmos 00:03: registered as rtc0
[    0.531520] rtc_cmos 00:03: setting system clock to 2021-12-24T09:04:17 UTC (1640336657)
[    0.531556] rtc_cmos 00:03: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[    0.531730] intel_pstate: Intel P-state driver initializing
[    0.532776] efifb: probing for efifb
[    0.532792] efifb: No BGRT, not showing boot graphics
[    0.532793] efifb: framebuffer at 0x90000000, using 8128k, total 8128k
[    0.532795] efifb: mode is 1920x1080x32, linelength=7680, pages=1
[    0.532796] efifb: scrolling: redraw
[    0.532797] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    0.532864] fbcon: Deferring console take-over
[    0.532865] fb0: EFI VGA frame buffer device
[    0.532888] hid: raw HID events driver (C) Jiri Kosina
[    0.533014] ashmem: initialized
[    0.537208] drop_monitor: Initializing network drop monitor service
[    0.537299] Initializing XFRM netlink socket
[    0.537447] NET: Registered PF_INET6 protocol family
[    0.652091] Freeing initrd memory: 12968K
[    0.659777] Segment Routing with IPv6
[    0.659781] RPL Segment Routing with IPv6
[    0.659808] In-situ OAM (IOAM) with IPv6
[    0.659859] NET: Registered PF_PACKET protocol family
[    0.660505] microcode: sig=0x706a8, pf=0x1, revision=0x1a
[    0.660536] microcode: Microcode Update Driver: v2.2.
[    0.660596] resctrl: L2 allocation detected
[    0.660603] IPI shorthand broadcast: enabled
[    0.660623] sched_clock: Marking stable (655847253, 4722552)->(662555772, -1985967)
[    0.660890] printk: console [tty0]: printing thread started
[    0.660918] registered taskstats version 1
[    0.660991] Loading compiled-in X.509 certificates
[    0.665799] Loaded X.509 cert 'Build time autogenerated kernel key: 2d545de9dc4a109d1f2e12d18d33a67ae1345dee'
[    0.667426] zswap: loaded using pool zstd/z3fold
[    0.667765] Key type ._fscrypt registered
[    0.667767] Key type .fscrypt registered
[    0.667768] Key type fscrypt-provisioning registered
[    0.667859] AppArmor: AppArmor sha1 policy hashing enabled
[    0.668431] PM:   Magic number: 1:308:71
[    0.668802] RAS: Correctable Errors collector initialized.
[    0.839196] ata2: SATA link down (SStatus 4 SControl 300)
[    0.839230] ata1: SATA link down (SStatus 4 SControl 300)
[    0.841887] Freeing unused decrypted memory: 2036K
[    0.842459] Freeing unused kernel image (initmem) memory: 1812K
[    0.845012] Write protecting the kernel read-only data: 26624k
[    0.845913] Freeing unused kernel image (text/rodata gap) memory: 2036K
[    0.846167] Freeing unused kernel image (rodata/data gap) memory: 880K
[    0.864933] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    0.864940] rodata_test: all tests were successful
[    0.864950] Run /init as init process
[    0.864952]   with arguments:
[    0.864954]     /init
[    0.864955]   with environment:
[    0.864956]     HOME=/
[    0.864957]     TERM=linux
[    0.864958]     BOOT_IMAGE=/boot/vmlinuz-5.15-rt-x86_64
[    0.875291] fbcon: Taking over console
[    0.875513] Console: switching to colour frame buffer device 240x67
[    1.063822] xhci_hcd 0000:00:15.0: xHCI Host Controller
[    1.063835] xhci_hcd 0000:00:15.0: new USB bus registered, assigned bus number 1
[    1.064946] xhci_hcd 0000:00:15.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000000009810
[    1.065474] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[    1.065478] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.065481] usb usb1: Product: xHCI Host Controller
[    1.065483] usb usb1: Manufacturer: Linux 5.15.5-1-rt22-MANJARO xhci-hcd
[    1.065485] usb usb1: SerialNumber: 0000:00:15.0
[    1.065723] hub 1-0:1.0: USB hub found
[    1.065744] hub 1-0:1.0: 9 ports detected
[    1.069055] xhci_hcd 0000:00:15.0: xHCI Host Controller
[    1.069064] xhci_hcd 0000:00:15.0: new USB bus registered, assigned bus number 2
[    1.069069] xhci_hcd 0000:00:15.0: Host supports USB 3.0 SuperSpeed
[    1.069144] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[    1.069147] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.069149] usb usb2: Product: xHCI Host Controller
[    1.069151] usb usb2: Manufacturer: Linux 5.15.5-1-rt22-MANJARO xhci-hcd
[    1.069152] usb usb2: SerialNumber: 0000:00:15.0
[    1.069381] hub 2-0:1.0: USB hub found
[    1.069394] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[    1.069397] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[    1.069401] hub 2-0:1.0: 7 ports detected
[    1.072202] serio: i8042 KBD port at 0x60,0x64 irq 1
[    1.077858] xhci_hcd 0000:03:00.0: xHCI Host Controller
[    1.077872] xhci_hcd 0000:03:00.0: new USB bus registered, assigned bus number 3
[    1.078693] sdhci: Secure Digital Host Controller Interface driver
[    1.078696] sdhci: Copyright(c) Pierre Ossman
[    1.083335] xhci_hcd 0000:03:00.0: hcc params 0x014051cf hci version 0x100 quirks 0x0000000100000090
[    1.086546] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[    1.086554] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.086556] usb usb3: Product: xHCI Host Controller
[    1.086558] usb usb3: Manufacturer: Linux 5.15.5-1-rt22-MANJARO xhci-hcd
[    1.086559] usb usb3: SerialNumber: 0000:03:00.0
[    1.086950] hub 3-0:1.0: USB hub found
[    1.086973] hub 3-0:1.0: 2 ports detected
[    1.087467] sdhci-pci 0000:00:1c.0: SDHCI controller found [8086:31cc] (rev 6)
[    1.087493] xhci_hcd 0000:03:00.0: xHCI Host Controller
[    1.087500] xhci_hcd 0000:03:00.0: new USB bus registered, assigned bus number 4
[    1.087506] xhci_hcd 0000:03:00.0: Host supports USB 3.0 SuperSpeed
[    1.087555] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.087601] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[    1.087604] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.087606] usb usb4: Product: xHCI Host Controller
[    1.087608] usb usb4: Manufacturer: Linux 5.15.5-1-rt22-MANJARO xhci-hcd
[    1.087609] usb usb4: SerialNumber: 0000:03:00.0
[    1.087892] hub 4-0:1.0: USB hub found
[    1.087908] hub 4-0:1.0: 2 ports detected
[    1.088290] mmc0: CQHCI version 5.10
[    1.088362] xhci_hcd 0000:04:00.0: xHCI Host Controller
[    1.088369] xhci_hcd 0000:04:00.0: new USB bus registered, assigned bus number 5
[    1.093631] xhci_hcd 0000:04:00.0: hcc params 0x014051cf hci version 0x100 quirks 0x0000000100000090
[    1.094132] mmc0: SDHCI controller on PCI [0000:00:1c.0] using ADMA 64-bit
[    1.094225] sdhci-pci 0000:00:1e.0: SDHCI controller found [8086:31d0] (rev 6)
[    1.094564] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[    1.094568] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.094571] usb usb5: Product: xHCI Host Controller
[    1.094573] usb usb5: Manufacturer: Linux 5.15.5-1-rt22-MANJARO xhci-hcd
[    1.094574] usb usb5: SerialNumber: 0000:04:00.0
[    1.094861] hub 5-0:1.0: USB hub found
[    1.094888] hub 5-0:1.0: 2 ports detected
[    1.095053] mmc1: SDHCI controller on PCI [0000:00:1e.0] using ADMA 64-bit
[    1.095689] xhci_hcd 0000:04:00.0: xHCI Host Controller
[    1.095695] xhci_hcd 0000:04:00.0: new USB bus registered, assigned bus number 6
[    1.095701] xhci_hcd 0000:04:00.0: Host supports USB 3.0 SuperSpeed
[    1.097170] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.097214] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[    1.097217] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.097219] usb usb6: Product: xHCI Host Controller
[    1.097221] usb usb6: Manufacturer: Linux 5.15.5-1-rt22-MANJARO xhci-hcd
[    1.097222] usb usb6: SerialNumber: 0000:04:00.0
[    1.097449] hub 6-0:1.0: USB hub found
[    1.097463] hub 6-0:1.0: 2 ports detected
[    1.097918] xhci_hcd 0000:05:00.0: xHCI Host Controller
[    1.097928] xhci_hcd 0000:05:00.0: new USB bus registered, assigned bus number 7
[    1.103184] xhci_hcd 0000:05:00.0: hcc params 0x014051cf hci version 0x100 quirks 0x0000000100000090
[    1.104579] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[    1.104583] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.104586] usb usb7: Product: xHCI Host Controller
[    1.104588] usb usb7: Manufacturer: Linux 5.15.5-1-rt22-MANJARO xhci-hcd
[    1.104590] usb usb7: SerialNumber: 0000:05:00.0
[    1.105166] hub 7-0:1.0: USB hub found
[    1.105186] hub 7-0:1.0: 2 ports detected
[    1.105450] xhci_hcd 0000:05:00.0: xHCI Host Controller
[    1.105456] xhci_hcd 0000:05:00.0: new USB bus registered, assigned bus number 8
[    1.105461] xhci_hcd 0000:05:00.0: Host supports USB 3.0 SuperSpeed
[    1.107063] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.107106] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[    1.107109] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.107111] usb usb8: Product: xHCI Host Controller
[    1.107113] usb usb8: Manufacturer: Linux 5.15.5-1-rt22-MANJARO xhci-hcd
[    1.107115] usb usb8: SerialNumber: 0000:05:00.0
[    1.107315] hub 8-0:1.0: USB hub found
[    1.107334] hub 8-0:1.0: 2 ports detected
[    1.107816] xhci_hcd 0000:06:00.0: xHCI Host Controller
[    1.107823] xhci_hcd 0000:06:00.0: new USB bus registered, assigned bus number 9
[    1.113091] xhci_hcd 0000:06:00.0: hcc params 0x014051cf hci version 0x100 quirks 0x0000000100000090
[    1.114451] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[    1.114456] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.114458] usb usb9: Product: xHCI Host Controller
[    1.114460] usb usb9: Manufacturer: Linux 5.15.5-1-rt22-MANJARO xhci-hcd
[    1.114461] usb usb9: SerialNumber: 0000:06:00.0
[    1.115497] hub 9-0:1.0: USB hub found
[    1.115517] hub 9-0:1.0: 2 ports detected
[    1.115811] xhci_hcd 0000:06:00.0: xHCI Host Controller
[    1.115819] xhci_hcd 0000:06:00.0: new USB bus registered, assigned bus number 10
[    1.115825] xhci_hcd 0000:06:00.0: Host supports USB 3.0 SuperSpeed
[    1.116634] usb usb10: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.116678] usb usb10: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[    1.116681] usb usb10: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.116683] usb usb10: Product: xHCI Host Controller
[    1.116684] usb usb10: Manufacturer: Linux 5.15.5-1-rt22-MANJARO xhci-hcd
[    1.116686] usb usb10: SerialNumber: 0000:06:00.0
[    1.116881] hub 10-0:1.0: USB hub found
[    1.116896] hub 10-0:1.0: 2 ports detected
[    1.131894] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input2
[    1.216095] mmc0: Command Queue Engine enabled
[    1.216105] mmc0: new HS400 MMC card at address 0001
[    1.219324] mmcblk0: mmc0:0001 DA4064 58.2 GiB
[    1.225692]  mmcblk0: p1 p2 p3 p4
[    1.226070] mmcblk0boot0: mmc0:0001 DA4064 4.00 MiB
[    1.230585] mmcblk0boot1: mmc0:0001 DA4064 4.00 MiB
[    1.234547] mmcblk0rpmb: mmc0:0001 DA4064 16.0 MiB, chardev (237:0)
[    1.251435] random: fast init done
[    1.308015] usb 1-2: new full-speed USB device number 2 using xhci_hcd
[    1.437211] usb 1-2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.01
[    1.437215] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.437217] usb 1-2: Product: USB Receiver
[    1.437219] usb 1-2: Manufacturer: Logitech
[    1.446883] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:15.0/usb1/1-2/1-2:1.0/0003:046D:C52B.0001/input/input3
[    1.459042] mmc0: Requiring re-tune after rpm resume
[    1.468456] PM: Image not found (code -22)
[    1.498388] hid-generic 0003:046D:C52B.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:00:15.0-2/input0
[    1.501741] input: Logitech USB Receiver Mouse as /devices/pci0000:00/0000:00:15.0/usb1/1-2/1-2:1.1/0003:046D:C52B.0002/input/input4
[    1.501871] input: Logitech USB Receiver Consumer Control as /devices/pci0000:00/0000:00:15.0/usb1/1-2/1-2:1.1/0003:046D:C52B.0002/input/input5
[    1.543416] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[    1.553044] usb 1-4: new high-speed USB device number 3 using xhci_hcd
[    1.553187] input: Logitech USB Receiver System Control as /devices/pci0000:00/0000:00:15.0/usb1/1-2/1-2:1.1/0003:046D:C52B.0002/input/input6
[    1.553354] hid-generic 0003:046D:C52B.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:15.0-2/input1
[    1.556059] hid-generic 0003:046D:C52B.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:15.0-2/input2
[    1.556109] usbcore: registered new interface driver usbhid
[    1.556112] usbhid: USB HID core driver
[    1.655314] systemd[1]: RTC configured in localtime, applying delta of -300 minutes to system time.
[    1.679287] usb 1-4: New USB device found, idVendor=0bda, idProduct=0129, bcdDevice=39.60
[    1.679292] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    1.679295] usb 1-4: Product: USB2.0-CRW
[    1.679297] usb 1-4: Manufacturer: Generic
[    1.679299] usb 1-4: SerialNumber: 20100201396000000
[    1.698058] request_module fs-efivarfs succeeded, but still no fs?
[    1.794027] usb 1-7: new full-speed USB device number 4 using xhci_hcd
[    1.801590] systemd[1]: systemd 249.7-2-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[    1.813083] systemd[1]: Detected architecture x86-64.
[    1.814778] systemd[1]: Hostname set to <websight>.
[    1.930157] usb 1-7: New USB device found, idVendor=2886, idProduct=8027, bcdDevice= 1.00
[    1.930165] usb 1-7: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    1.930168] usb 1-7: Product: Seeeduino_Cortex_M0+
[    1.930170] usb 1-7: Manufacturer: Unknown
[    1.930171] usb 1-7: SerialNumber: BF595FD85054414B352E3120FF0A2B24
[    2.065518] random: lvmconfig: uninitialized urandom read (4 bytes read)
[    2.219657] systemd[1]: Queued start job for default target Graphical Interface.
[    2.220746] systemd[1]: Created slice Slice /system/getty.
[    2.221111] systemd[1]: Created slice Slice /system/modprobe.
[    2.221401] systemd[1]: Created slice Slice /system/systemd-fsck.
[    2.221625] systemd[1]: Created slice User and Session Slice.
[    2.221752] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    2.221854] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    2.222164] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    2.222234] systemd[1]: Reached target Local Encrypted Volumes.
[    2.222261] systemd[1]: Reached target Login Prompts.
[    2.222300] systemd[1]: Reached target Remote File Systems.
[    2.222333] systemd[1]: Reached target Slice Units.
[    2.222373] systemd[1]: Reached target Local Verity Protected Volumes.
[    2.222504] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[    2.222677] systemd[1]: Listening on LVM2 poll daemon socket.
[    2.224420] systemd[1]: Listening on Process Core Dump Socket.
[    2.224668] systemd[1]: Listening on Journal Audit Socket.
[    2.224846] systemd[1]: Listening on Journal Socket (/dev/log).
[    2.225104] systemd[1]: Listening on Journal Socket.
[    2.227202] systemd[1]: Listening on udev Control Socket.
[    2.227349] systemd[1]: Listening on udev Kernel Socket.
[    2.228573] systemd[1]: Mounting Huge Pages File System...
[    2.229621] systemd[1]: Mounting POSIX Message Queue File System...
[    2.230703] systemd[1]: Mounting Kernel Debug File System...
[    2.231838] systemd[1]: Mounting Kernel Trace File System...
[    2.233270] systemd[1]: Starting Load AppArmor profiles...
[    2.234595] systemd[1]: Starting Create List of Static Device Nodes...
[    2.235753] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[    2.237148] systemd[1]: Starting Load Kernel Module configfs...
[    2.238600] systemd[1]: Starting Load Kernel Module drm...
[    2.240163] systemd[1]: Starting Load Kernel Module fuse...
[    2.240951] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    2.241074] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    2.241472] random: lvm: uninitialized urandom read (4 bytes read)
[    2.243474] systemd[1]: Starting Load Kernel Modules...
[    2.244885] systemd[1]: Starting Remount Root and Kernel File Systems...
[    2.245069] systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
[    2.246479] systemd[1]: Starting Coldplug All udev Devices...
[    2.249975] systemd[1]: Mounted Huge Pages File System.
[    2.250323] systemd[1]: Mounted POSIX Message Queue File System.
[    2.250451] systemd[1]: Mounted Kernel Debug File System.
[    2.250585] systemd[1]: Mounted Kernel Trace File System.
[    2.251089] systemd[1]: Finished Create List of Static Device Nodes.
[    2.251605] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[    2.251979] systemd[1]: Finished Load Kernel Module configfs.
[    2.264514] systemd[1]: Mounting Kernel Configuration File System...
[    2.267031] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
[    2.268012] fuse: init (API version 7.34)
[    2.275715] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[    2.276291] systemd[1]: Finished Load Kernel Module fuse.
[    2.276583] systemd[1]: Mounted Kernel Configuration File System.
[    2.278247] systemd[1]: Mounting FUSE Control File System...
[    2.280618] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[    2.282752] systemd[1]: Finished Remount Root and Kernel File Systems.
[    2.283934] systemd[1]: Mounted FUSE Control File System.
[    2.284208] systemd[1]: Condition check resulted in First Boot Wizard being skipped.
[    2.286520] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[    2.288260] systemd[1]: Starting Load/Save Random Seed...
[    2.288386] systemd[1]: Condition check resulted in Create System Users being skipped.
[    2.289920] systemd[1]: Starting Create Static Device Nodes in /dev...
[    2.291972] systemd[1]: Finished Load Kernel Modules.
[    2.300373] systemd[1]: modprobe@drm.service: Deactivated successfully.
[    2.300780] systemd[1]: Finished Load Kernel Module drm.
[    2.302790] systemd[1]: Starting Apply Kernel Variables...
[    2.314888] systemd[1]: Finished Apply Kernel Variables.
[    2.318458] systemd[1]: Starting CLI Netfilter Manager...
[    2.335962] systemd[1]: Finished CLI Netfilter Manager.
[    2.347111] systemd[1]: Finished Create Static Device Nodes in /dev.
[    2.347299] systemd[1]: Reached target Preparation for Local File Systems.
[    2.347364] systemd[1]: Condition check resulted in Virtual Machine and Container Storage (Compatibility) being skipped.
[    2.347394] systemd[1]: Condition check resulted in Entropy Daemon based on the HAVEGE algorithm being skipped.
[    2.349874] systemd[1]: Starting Journal Service...
[    2.352914] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[    2.479434] systemd[1]: Finished Coldplug All udev Devices.
[    2.479530] audit: type=1130 audit(1640354659.446:2): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    2.482649] audit: type=1400 audit(1640354659.449:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=293 comm="apparmor_parser"
[    2.495129] systemd[1]: Started Rule-based Manager for Device Events and Files.
[    2.495310] audit: type=1130 audit(1640354659.462:4): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    2.515074] audit: type=1400 audit(1640354659.478:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=294 comm="apparmor_parser"
[    2.517471] audit: type=1400 audit(1640354659.484:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=294 comm="apparmor_parser"
[    2.528403] systemd[1]: Started Journal Service.
[    2.528537] audit: type=1130 audit(1640354659.495:7): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    2.537635] systemd-journald[303]: Received client request to flush runtime journal.
[    2.667175] audit: type=1400 audit(1640354659.631:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-script-login" pid=305 comm="apparmor_parser"
[    2.667199] audit: type=1300 audit(1640354659.631:8): arch=c000003e syscall=1 success=yes exit=33505 a0=5 a1=559b5ca3fa40 a2=82e1 a3=0 items=0 ppid=288 pid=305 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="apparmor_parser" exe="/usr/bin/apparmor_parser" subj==unconfined key=(null)
[    2.667208] audit: type=1327 audit(1640354659.631:8): proctitle=2F7362696E2F61707061726D6F725F706172736572002D2D7265706C616365002D2D002F6574632F61707061726D6F722E64
[    2.921122] Linux agpgart interface v0.103
[    2.969414] dca service started, version 1.12.1
[    3.024528] random: tlp-readconfs: uninitialized urandom read (4 bytes read)
[    3.058179] idma64 idma64.0: Found Intel integrated DMA 64-bit
[    3.106490] urandom_read: 5 callbacks suppressed
[    3.106497] random: tlp-readconfs: uninitialized urandom read (4 bytes read)
[    3.109201] random: tlp-readconfs: uninitialized urandom read (4 bytes read)
[    3.147426] igb: Intel(R) Gigabit Ethernet Network Driver
[    3.147433] igb: Copyright (c) 2007-2014 Intel Corporation.
[    3.158188] idma64 idma64.1: Found Intel integrated DMA 64-bit
[    3.180126] idma64 idma64.2: Found Intel integrated DMA 64-bit
[    3.192582] pps pps0: new PPS source ptp0
[    3.192672] igb 0000:07:00.0: added PHC on eth0
[    3.192674] igb 0000:07:00.0: Intel(R) Gigabit Ethernet Network Connection
[    3.192676] igb 0000:07:00.0: eth0: (PCIe:2.5Gb/s:Width x1) 00:e0:4c:04:b1:03
[    3.192680] igb 0000:07:00.0: eth0: PBA No: FFFFFF-0FF
[    3.192681] igb 0000:07:00.0: Using MSI-X interrupts. 2 rx queue(s), 2 tx queue(s)
[    3.213623] idma64 idma64.3: Found Intel integrated DMA 64-bit
[    3.220190] idma64 idma64.4: Found Intel integrated DMA 64-bit
[    3.224112] idma64 idma64.7: Found Intel integrated DMA 64-bit
[    3.247798] pps pps1: new PPS source ptp1
[    3.247901] igb 0000:08:00.0: added PHC on eth1
[    3.247903] igb 0000:08:00.0: Intel(R) Gigabit Ethernet Network Connection
[    3.247905] igb 0000:08:00.0: eth1: (PCIe:2.5Gb/s:Width x1) 00:e0:4c:04:b1:04
[    3.247909] igb 0000:08:00.0: eth1: PBA No: FFFFFF-0FF
[    3.247910] igb 0000:08:00.0: Using MSI-X interrupts. 2 rx queue(s), 2 tx queue(s)
[    3.255746] i801_smbus 0000:00:1f.1: SPD Write Disable is set
[    3.256774] i801_smbus 0000:00:1f.1: SMBus using PCI interrupt
[    3.256901] i2c i2c-3: 4/4 memory slots populated (from DMI)
[    3.317408] Adding 4225764k swap on /dev/mmcblk0p4.  Priority:-2 extents:1 across:4225764k SSFS
[    3.364838] input: PC Speaker as /devices/platform/pcspkr/input/input8
[    3.384575] RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
[    3.384581] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[    3.384582] RAPL PMU: hw unit of domain package 2^-14 Joules
[    3.384583] RAPL PMU: hw unit of domain dram 2^-14 Joules
[    3.384584] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[    3.392901] cryptd: max_cpu_qlen set to 1000
[    3.421502] SSE version of gcm_enc/dec engaged.
[    3.481342] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[    3.659046] random: crng init done
[    3.739798] i915 0000:00:02.0: [drm] Unknown revid 0x06
[    3.741265] checking generic (90000000 7f0000) vs hw (a0000000 1000000)
[    3.741269] checking generic (90000000 7f0000) vs hw (90000000 10000000)
[    3.741271] fb0: switching to i915 from EFI VGA
[    3.741390] Console: switching to colour dummy device 80x25
[    3.741447] i915 0000:00:02.0: vgaarb: deactivate vga console
[    3.741634] i915 0000:00:02.0: [drm] couldn't get memory information
[    3.762194] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[    3.771267] [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 0
[    3.775035] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/glk_dmc_ver1_04.bin (v1.4)
[    3.776692] ACPI: video: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[    3.777337] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input9
[    3.777536] snd_hda_intel 0000:00:0e.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[    3.791691] intel_rapl_common: Found RAPL domain package
[    3.791698] intel_rapl_common: Found RAPL domain core
[    3.791700] intel_rapl_common: Found RAPL domain uncore
[    3.791702] intel_rapl_common: Found RAPL domain dram
[    3.820767] fbcon: i915 (fb0) is primary device
[    3.836402] Console: switching to colour frame buffer device 240x67
[    3.858717] mei_hdcp 0000:00:0f.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
[    3.860314] i915 0000:00:02.0: [drm] fb0: i915 frame buffer device
[    3.864525] igb 0000:07:00.0 enp7s0: renamed from eth0
[    3.916174] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC269VC: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[    3.916183] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    3.916186] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x15/0x0/0x0/0x0/0x0)
[    3.916188] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[    3.916189] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[    3.916190] snd_hda_codec_realtek hdaudioC0D0:      Mic=0x18
[    3.971391] dw-apb-uart.3: ttyS4 at MMIO 0xa1722000 (irq = 4, base_baud = 115200) is a 16550A
[    3.985425] igb 0000:08:00.0 enp8s0: renamed from eth1
[    3.986381] dw-apb-uart.4: ttyS5 at MMIO 0xa1720000 (irq = 5, base_baud = 115200) is a 16550A
[    3.992321] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:0e.0/sound/card0/input10
[    3.992433] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:0e.0/sound/card0/input11
[    3.992528] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:0e.0/sound/card0/input12
[    3.992805] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:0e.0/sound/card0/input13
[    3.992903] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:0e.0/sound/card0/input14
[    3.993375] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:0e.0/sound/card0/input15
[    3.993535] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:0e.0/sound/card0/input16
[    4.018038] dw-apb-uart.5: ttyS6 at MMIO 0xfea10000 (irq = 6, base_baud = 115200) is a 16550A
[    4.041105] dw-apb-uart.6: ttyS7 at MMIO 0xa171e000 (irq = 7, base_baud = 115200) is a 16550A
[    4.114134] intel_telemetry_core Init
[    4.198723] Invalid pltconfig, ensure IPC1 device is enabled in BIOS
[    4.242182] Invalid pltconfig, ensure IPC1 device is enabled in BIOS
[    4.255271] Invalid pltconfig, ensure IPC1 device is enabled in BIOS
[    4.302975] Invalid pltconfig, ensure IPC1 device is enabled in BIOS
[    4.351915] NET: Registered PF_QIPCRTR protocol family
[    4.402410] loop: module loaded
[    4.402986] loop0: detected capacity change from 0 to 8
[    4.427508] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    4.975555] logitech-djreceiver 0003:046D:C52B.0003: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:15.0-2/input2
[    5.020766] usbcore: registered new interface driver rtsx_usb
[    5.084106] input: Logitech Wireless Device PID:404d Keyboard as /devices/pci0000:00/0000:00:15.0/usb1/1-2/1-2:1.2/0003:046D:C52B.0003/0003:046D:404D.0004/input/input17
[    5.086784] input: Logitech Wireless Device PID:404d Mouse as /devices/pci0000:00/0000:00:15.0/usb1/1-2/1-2:1.2/0003:046D:C52B.0003/0003:046D:404D.0004/input/input18
[    5.086957] hid-generic 0003:046D:404D.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech Wireless Device PID:404d] on usb-0000:00:15.0-2/input2:1
[    5.095663] cdc_acm 1-7:1.0: ttyACM0: USB ACM device
[    5.099675] usbcore: registered new interface driver cdc_acm
[    5.099681] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    5.099839] mousedev: PS/2 mouse device common for all mice
[    5.181222] input: Logitech K400 Plus as /devices/pci0000:00/0000:00:15.0/usb1/1-2/1-2:1.2/0003:046D:C52B.0003/0003:046D:404D.0004/input/input22
[    5.181713] logitech-hidpp-device 0003:046D:404D.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech K400 Plus] on usb-0000:00:15.0-2/input2:1
[    5.531180] kauditd_printk_skb: 45 callbacks suppressed
[    5.531185] audit: type=1100 audit(1640354662.498:50): pid=839 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_shells,pam_permit,pam_gnome_keyring acct="shadetechnik" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[    5.535844] audit: type=1101 audit(1640354662.502:51): pid=839 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="shadetechnik" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[    5.545954] audit: type=1103 audit(1640354662.512:52): pid=839 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_shells,pam_permit,pam_gnome_keyring acct="shadetechnik" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[    5.546079] audit: type=1006 audit(1640354662.513:53): pid=839 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
[    5.546097] audit: type=1300 audit(1640354662.513:53): arch=c000003e syscall=1 success=yes exit=4 a0=9 a1=7fff18ad6cf0 a2=4 a3=3e8 items=0 ppid=623 pid=839 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="lightdm" exe="/usr/bin/lightdm" subj==unconfined key=(null)
[    5.546107] audit: type=1327 audit(1640354662.513:53): proctitle=6C69676874646D002D2D73657373696F6E2D6368696C64003132003135
[    5.574088] audit: type=1130 audit(1640354662.541:54): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.584102] audit: type=1101 audit(1640354662.551:55): pid=844 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="shadetechnik" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.584165] audit: type=1103 audit(1640354662.551:56): pid=844 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="shadetechnik" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[    5.584267] audit: type=1006 audit(1640354662.551:57): pid=844 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[    6.161542] igb 0000:08:00.0 enp8s0: igb: enp8s0 NIC Link is Up 100 Mbps Full Duplex, Flow Control: RX/TX
[    6.161759] IPv6: ADDRCONF(NETDEV_CHANGE): enp8s0: link becomes ready
[    7.525517] igb 0000:07:00.0 enp7s0: igb: enp7s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[    7.634238] IPv6: ADDRCONF(NETDEV_CHANGE): enp7s0: link becomes ready
[    8.409042] snd_hda_intel 0000:00:0e.0: azx_get_response timeout, switching to polling mode: last cmd=0x20bf8100
[    9.411027] snd_hda_intel 0000:00:0e.0: No response from codec, disabling MSI: last cmd=0x20bf8100
[   10.415014] snd_hda_intel 0000:00:0e.0: azx_get_response timeout, switching to single_cmd mode: last cmd=0x20bf8100
[   10.532163] azx_single_send_cmd: 170 callbacks suppressed
[   10.655406] snd_hda_codec_hdmi hdaudioC0D2: Unable to sync register 0x2f0d00. -5
[   10.913722] snd_hda_codec_realtek hdaudioC0D0: Unable to sync register 0x2b8000. -5
[   10.914233] snd_hda_codec_realtek hdaudioC0D0: Unable to sync register 0x2b8000. -5
[   17.128635] azx_single_send_cmd: 472 callbacks suppressed
[   19.814830] snd_hda_codec_realtek hdaudioC0D0: Unable to sync register 0x2b8000. -5
[   19.815321] snd_hda_codec_realtek hdaudioC0D0: Unable to sync register 0x2b8000. -5
[   25.949108] azx_single_send_cmd: 380 callbacks suppressed
[   34.339152] kauditd_printk_skb: 174 callbacks suppressed
[   34.339159] audit: type=1131 audit(1640354690.125:81): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   34.380072] audit: type=1334 audit(1640354690.166:82): prog-id=0 op=UNLOAD
[   34.380081] audit: type=1334 audit(1640354690.166:83): prog-id=0 op=UNLOAD
[   34.380085] audit: type=1334 audit(1640354690.166:84): prog-id=0 op=UNLOAD
[   34.646100] audit: type=1131 audit(1640354690.432:85): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   34.651095] audit: type=1334 audit(1640354690.437:86): prog-id=0 op=UNLOAD
[   34.651102] audit: type=1334 audit(1640354690.437:87): prog-id=0 op=UNLOAD
[   34.651107] audit: type=1334 audit(1640354690.437:88): prog-id=0 op=UNLOAD
[   39.493502] audit: type=1131 audit(1640354695.279:89): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Maybe this is related:
Please also search the forum for “renesas”
Is it possible that this 2nd nic does use the same pci-channel that is now used by the extension card ?
In the manual of my motherboard there are some warnings about:
This […] uses the same pcie-channel as pcie -slot […] (if using one, the other will be disabled)
That’s a firmware load issue from the Linux side. All USB3-PCIE chips need firmware loaded when they are initialized and this is generally done by an on card EEPROM. In the event that the EEPPROM contains old or problematic firmware the OS driver is supposed to load firmware directly to the USB3 chip, the Linux Renansis driver has mishandled this for years but it appears to no longer be a problem.
Anyway as you can see from that thread the problem that occurs is that the USB3 chip does not work, that is not my problem, all Renasis controllers work fine. You can also see that was likely fixed in kernel 5.8.6 as well as the fact that my dmesg output doesn’t show any errors of that nature…I have some sort of PCIE conflict which probably doesn’t have anything specific to do with the Renasis chips, tho it could…it’s just not the issue of firmware loading that’s well known.
That’s because your motherboard has a PCIE management chipset that repurposes lanes based on what you’re using them for or what’s attached to your motherboard. This is a Mini-PC with an Intel mobile CPU, it does not have that ability. This is a single M.2 Slot and the lanes are never reallocated by the chipset, you can see by the dmesg that all of the controllers attached to the PCIE lanes are registered as well as the 2 NICs.
My problem is likely similar to this one although no solution was posted.
https://www.linux.org/threads/inserting-a-pcie-card-causes-ethernet-to-stop-working.35555/
If you look after the last post in this thread, there are some additional ideas given by “dave”. Maybe one of them will bring you forward.
  • look after the interrupts assigned
  • 2 additions to grub cmdline to try
Otherwise i am out of ideas :man_shrugging:
I tried that stuff before I posted the link. Anyone else have a suggestion? I tried changing a bunch of stuff related to the NICs and the PCIE M.2 slot in the bios but nothing made a change. Both NICs show “connected” in the bios when they are plugged in to their respective networks. I need 2 network ports on this thing so for now I have a USB3 to 1gbe adapter covering the network port that doesn’t work with the PCIE card installed, it’s just kind of silly to do that when I have 2 onboard NICs.
Figured I’d update for the sake of it. The Seeed Odysee has a hardware bug they were apparently unaware of until I raised this issue on their forum. Turns out using a standard PCIe card (as opposed to an NVME drive) pulls down the PCIe reset line and the bug is that for whatever reason this makes one of the NICs inoperable.
