2 screens with different scaling
Hello, I have connected an external monitor to my laptop, but my laptop has a resolution of 2160x1440 and my external monitor has a resolution of 1366x768. Therefore I would like to set a different scaling for the external monitor. Is there a way out there, haven’t found much.
-GeistFan
Hello,
This information should be helpful
https://wiki.archlinux.org/title/HiDPI#Multiple_displays
and if you get stuck, just ask and someone will guide you.
@GeistFan Please no double posts: 2 Bildschirme mit verschiedenen Skallierungen
That only shows the option with global scalling
Is this better for your case ?
https://www.lguruprasad.in/blog/2020/01/13/how-to-get-a-dual-monitor-setup-with-mixed-dpi-working-on-xorg/
Hello,
I have the same problem i used the solution of the link for my setup :
-1920x1080 as primary and second screen 2560x1440
It gives me :
xrandr --fbmm 5440x3060 --output DisplayPort-1 --pos 2880x0 --mode 2560x1440 --scale 1x1 --output DisplayPort-0 --pos 0x0 --mode 1920x1080 --scale 1.5x1.5 --primary
Then i use :
kquitapp5 plasmashell || killall plasmashell && kstart5 plasmashell
But now everything is little size on both screens.
