1/2 boots are stuck at bootsplash
Hello, I recently downloaded KDE Plasma Manjaro as dual boot on my laptop. My main OS is Windows 11.
I have had some problems with the system right from the installation, but I fixed some of them by downloading appropriate drivers for Nvidia GPU.
Due to the limited space on my C: drive, I had to create partitions like this:
  • Root (/) is on C: drive
  • Boot sector is on C: drive (400 MiB)
  • Home is on D: drive
My laptop specifications are the following:
  • Laptop Dell G5 15 5587
  • CPU: i7-8750h
  • GPU: Nvidia GTX 1060 Max-Q
  • 16 GB DDR4 RAM
My problem is that sometimes, maybe like every second boot, gets stuck at bootsplash screen and I need to press power button for some time to turn off the laptop. The next boot usually works normally, and this cycle goes on and on.
I read somewhere I should provide as much detail as possible, so I tried to get info from the boot by using the following command:
journalctl --boot=-2 --priority=3 --no-pager
Which returned:
dub 25 11:42:58 vojta-kde kernel:
dub 25 11:42:59 vojta-kde kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
dub 25 11:43:10 vojta-kde bluetoothd[619]: src/plugin.c:plugin_init() Failed to init vcp plugin
dub 25 11:43:10 vojta-kde bluetoothd[619]: src/plugin.c:plugin_init() Failed to init mcp plugin
dub 25 11:43:10 vojta-kde bluetoothd[619]: src/plugin.c:plugin_init() Failed to init bap plugin
dub 25 11:43:10 vojta-kde bluetoothd[619]: Failed to set mode: Failed (0x03)
dub 25 11:43:43 vojta-kde kernel: ACPI Error: Aborting method \_SB.PCI0.PGON due to previous error (AE_AML_LOOP_TIMEOUT) (20220331/psparse-529)
dub 25 11:43:43 vojta-kde kernel: ACPI Error: Aborting method \_SB.PCI0.PEG0.PG00._ON due to previous error (AE_AML_LOOP_TIMEOUT) (20220331/psparse-529)
dub 25 11:43:45 vojta-kde kernel: nvidia 0000:01:00.0: Unable to change power state from D3cold to D0, device inaccessible
dub 25 11:43:45 vojta-kde kernel: snd_hda_intel 0000:01:00.1: Unable to change power state from D3cold to D0, device inaccessible
dub 25 11:43:45 vojta-kde kernel: snd_hda_codec_hdmi hdaudioC1D0: Unable to sync register 0x7f0800. -5
If anyone could point out any possible fix, I would be grateful.
Thanks.
ADDING SYSTEM INFO as requested:
  Kernel: 6.1.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=2d24b7cd-bfab-4f54-84fa-c2dc43942ef3 rw splash
    udev.log_priority=3
    bootsplash.bootfile=/bootsplash-themes/manjaro-glitch/bootsplash
  Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.8 wm: kwin_x11 dm: SDDM
  Type: Laptop System: Dell product: G5 5587 v: N/A serial: <filter> Chassis:
    type: 10 serial: <filter>
  Mobo: Dell model: 0TM9WY v: A03 serial: <filter> UEFI: Dell v: 1.20.0
    date: 03/18/2022
  ID-1: BAT0 charge: 52.1 Wh (100.0%) condition: 52.1/56.0 Wh (93.1%)
    volts: 17.3 min: 15.2 model: Samsung SDI DELL W7NKD88 type: Li-ion
    serial: <filter> status: full
  RAM: total: 15.31 GiB used: 4.9 GiB (32.0%)
  Array-1: capacity: 32 GiB slots: 2 EC: None max-module-size: 16 GiB
    note: est.
  Device-1: DIMM A type: DDR4 detail: synchronous size: 8 GiB
    speed: 2667 MT/s volts: curr: 1.2 min: 1.2 max: 1.2 width (bits): data: 64
    total: 64 manufacturer: 80AD000080AD part-no: HMA81GS6CJR8N-VK
    serial: <filter>
  Device-2: DIMM B type: DDR4 detail: synchronous size: 8 GiB
    serial: <filter>
  Info: model: Intel Core i7-8750H socket: BGA1440 (U3E1) note: check bits: 64
    type: MT MCP arch: Coffee Lake gen: core 8 level: v3 note: check built: 2018
    process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 0xA (10)
    microcode: 0xF0
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
    L3: 9 MiB desc: 1x9 MiB
  Speed (MHz): avg: 1852 high: 2200 min/max: 800/4100 base/boost: 1800/4100
    scaling: driver: intel_pstate governor: powersave volts: 0.8 V
    ext-clock: 100 MHz cores: 1: 2200 2: 2200 3: 2200 4: 2200 5: 800 6: 2200
    7: 825 8: 2200 9: 2200 10: 2200 11: 2200 12: 802 bogomips: 52815
    intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
    movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
    pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
    rep_good sdbg sep sgx sgx_lc smap smep ss ssbd sse sse2 sse4_1 sse4_2
    ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
    vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
    xtpr
    vulnerable
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
    RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Dell driver: i915
    v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
    active: eDP-1 empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3
    bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
  Device-2: NVIDIA GP106M [GeForce GTX 1060 Mobile] vendor: Dell
    driver: nvidia v: 530.41.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
    status: current (as of 2023-03) arch: Pascal code: GP10x process: TSMC 16nm
    built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
    speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1c20 class-ID: 0300
  Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
    bus-ID: 1-5:2 chip-ID: 0c45:6718 class-ID: 0e02
  Device-4: Microdia Dual Mode Camera (8006 VGA) type: USB
    driver: hid-generic,usbhid bus-ID: 3-1.1:3 chip-ID: 0c45:8006 class-ID: 0301
  Device-5: Generic HD camera type: USB driver: usb-storage bus-ID: 3-1.2.4:7
    chip-ID: 6820:0048 class-ID: 0806 serial: <filter>
  Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
    loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
    dri: iris gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.88x11.22")
    s-diag: 1052mm (41.43")
  Monitor-1: HDMI-1-0 pos: primary,right res: 1920x1080 dpi: 93
    size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
  Monitor-2: eDP-1 pos: left res: 1920x1080 hz: 60 dpi: 142
    size: 344x194mm (13.54x7.64") diag: 395mm (15.55") modes: N/A
  API: OpenGL v: 4.6 Mesa 23.0.2 renderer: Mesa Intel UHD Graphics 630 (CFL
    GT2) direct-render: Yes
  Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
    bus-ID: 1-2:6 v: kernel chip-ID: 0951:16a4
    alternate: snd_soc_skl,snd_sof_pci_intel_cnl class-ID: 0300 bus-ID: 00:1f.3
    chip-ID: 8086:a348 serial: <filter> class-ID: 0403
  Device-2: NVIDIA GP106 High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
    speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:10f1 class-ID: 0403
  Device-3: Kingston HyperX 7.1 Audio type: USB
    driver: hid-generic,snd-usb-audio,usbhid
  Device-4: JMTek LLC. USB PnP Audio Device type: USB
    driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1.2.3:6 chip-ID: 0c76:153f
    class-ID: 0300
  API: ALSA v: k6.1.25-1-MANJARO status: kernel-api with: aoss
    type: oss-emulator tools: alsamixer,amixer
  Server-2: PipeWire v: 0.3.70 status: n/a (root, process) with: wireplumber
    status: active tools: pw-cli,wpctl
  Server-3: PulseAudio v: 16.1 status: active (root, process)
    tools: pacat,pactl,pamixer
  Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
  Device-2: Qualcomm Atheros Killer E2400 Gigabit Ethernet vendor: Dell
    driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000
    bus-ID: 3b:00.0 chip-ID: 1969:e0a1 class-ID: 0200
  IF: enp59s0 state: down mac: <filter>
  Device-3: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
    bus-ID: 4-1.3:3 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
  IF: enp58s0u1u3 state: down mac: <filter>
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
    driver: btusb v: 0.8 bus-ID: 1-14:4 chip-ID: 8087:0aaa class-ID: e001
  Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
    v: 3.0 port: 5060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
  Local Storage: total: 1.14 TiB used: 34.39 GiB (2.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
    family: Mobile HDD size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: HDD rpm: 5400
    serial: <filter> rev: SDM3 temp: 33 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 1y 74d 15h cycles: 2808
    read: 43.42 TiB written: 22.61 TiB Pre-Fail: attribute: Spin_Retry_Count
    value: 100 worst: 100 threshold: 97
  ID-2: /dev/sdb maj-min: 8:16 vendor: SK Hynix model: SC311 SATA 256GB
    family: SATA SSDs size: 238.47 GiB block-size: physical: 4096 B
    logical: 512 B sata: 3.2 speed: 6.0 Gb/s type: SSD serial: <filter>
    rev: 0P10 temp: 41 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 1y 65d 23h cycles: 2841
  ID-1: / raw-size: 31.96 GiB size: 31.28 GiB (97.89%) used: 21.08 GiB (67.4%)
    fs: ext4 block-size: 4096 B dev: /dev/sdb6 maj-min: 8:22 label: N/A
    uuid: 2d24b7cd-bfab-4f54-84fa-c2dc43942ef3
  ID-2: /boot/efi raw-size: 400 MiB size: 399.2 MiB (99.80%)
    used: 316 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sdb5 maj-min: 8:21
    label: N/A uuid: 86B5-E414
  ID-3: /home raw-size: 101.31 GiB size: 99.16 GiB (97.88%)
    used: 13.31 GiB (13.4%) fs: ext4 block-size: 4096 B dev: /dev/sda3
    maj-min: 8:3 label: N/A uuid: 6a5d309e-fb90-493f-bf61-a88b5f139928
  ID-1: /dev/sda1 maj-min: 8:1 size: 128 MiB fs: N/A label: N/A uuid: N/A
  ID-2: /dev/sda2 maj-min: 8:2 size: 830.08 GiB fs: ntfs label: DATA
    uuid: 827E71D57E71C289
  ID-3: /dev/sdb1 maj-min: 8:17 size: 650 MiB fs: vfat label: ESP
    uuid: 94E8-36E4
  ID-4: /dev/sdb2 maj-min: 8:18 size: 128 MiB fs: N/A label: N/A uuid: N/A
  ID-5: /dev/sdb3 maj-min: 8:19 size: 204.4 GiB fs: ntfs label: OS
    uuid: E454E15454E129CE
  ID-6: /dev/sdb4 maj-min: 8:20 size: 990 MiB fs: ntfs label: N/A
    uuid: 5616358A16356C5D
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
  Device-1: 1-2:6 info: Kingston HyperX 7.1 Audio type: Audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
    speed: 12 Mb/s power: 100mA chip-ID: 0951:16a4 class-ID: 0300
    serial: <filter>
  Device-2: 1-3:7 info: A4Tech USB DEVICE type: Keyboard,Mouse,HID
    driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 100mA
    chip-ID: 09da:533a class-ID: 0300
  Device-3: 1-5:2 info: Microdia Integrated_Webcam_HD type: Video
  Device-4: 1-9:8 info: Shenzhen Goodix Fingerprint Reader
    type: Abstract (modem),CDC-Data driver: cdc_acm interfaces: 2 rev: 2.0
    speed: 12 Mb/s power: 100mA chip-ID: 27c6:5381 class-ID: 0a00
    serial: <filter>
  Device-5: 1-14:4 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
    type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
    power: 100mA chip-ID: 8087:0aaa class-ID: e001
  Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-4: 3-1:2 info: VIA Labs USB2.0 Hub ports: 5 rev: 2.1 speed: 480 Mb/s
    chip-ID: 2109:2817 class-ID: 0900
  Device-1: 3-1.1:3 info: Microdia Dual Mode Camera (8006 VGA)
    type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    speed: 12 Mb/s power: 100mA chip-ID: 0c45:8006 class-ID: 0301
  Hub-5: 3-1.2:4 info: Terminus USB 2.0 Hub ports: 4 rev: 2.0 speed: 480 Mb/s
    power: 100mA chip-ID: 1a40:0801 class-ID: 0900
  Device-1: 3-1.2.3:6 info: JMTek LLC. USB PnP Audio Device type: Audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
    speed: 12 Mb/s power: 100mA chip-ID: 0c76:153f class-ID: 0300
  Device-2: 3-1.2.4:7 info: Generic HD camera type: Mass Storage
    driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 50mA
  Device-3: 3-1.5:5 info: VIA Labs PD3.0 USB-C Device type: Billboard
    driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA
    chip-ID: 2109:8888 class-ID: 1100 serial: <filter>
  Hub-6: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
  Hub-7: 4-1:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.1 speed: 5 Gb/s
    chip-ID: 2109:0817 class-ID: 0900
  Device-1: 4-1.3:3 info: Realtek RTL8153 Gigabit Ethernet Adapter
    type: Network driver: r8152 interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 288mA
  System Temperatures: cpu: 57.0 C pch: 65.0 C mobo: N/A
  Processes: 277 Uptime: 5h 33m wakeups: 10921 Init: systemd v: 252
  default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
  Packages: 1476 pm: dpkg pkgs: 0 pm: pacman pkgs: 1469 libs: 451
  tools: pamac,paru,yay pm: flatpak pkgs: 7 Shell: Zsh (sudo) v: 5.9
  default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.26
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information.
[HowTo] Provide System Information
  1. Please press the three dots … below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
(Wisdom lies in reading :wink: )
Things you could try:
  • Boot with another kernel
  • :mag: possible boot-parameters for your hardware (in arch wiki)
journal messages show nVidia device is inaccessible because of D3cold power state (hybrid hibernation)
Hybrid hibernation is used by Windows to give the illusion of appearing to restart system almost as fast as Linux, but devices are only placed in hybrid hibernation state and not fully powered down
Linux OS has to be rebooted to power down hibernated devices so they can be initialised when system is restarted
This issue can be avoided by using Power Off option to properly shutdown Windows OS rather than selecting Restart option
Optimal solution is to disable hybrid hibernation in Windows OS by turning off Fast Startup option
How to Disable Fast Startup in Windows 11/10 (And Why You Should)
Thanks, I’ll have a look at that
