Hello.
I tried to modify the default font of manjaro(KDE) from /etc/fonts/conf.d/46-noto-sans.conf
then I ran fc-cache
command.
and now home and Manjaro icons disappeared and I can only see blank rectangles.
sorry if my English is bad. also I couldn’t provide screenshot since I’m not TL2.
Have you tried reverting your changes?
Yes I did. but it didn’t work on Konsole.
You could try installing a nerd font like Fira Mono and manually changing the font of Konsole profile to that font and see if that works.
it worked, thanks. but I wish I could make it work like before.
it was on Hack
font and it was working before.
I also found hack nerd font which is exact same as the default one. I applied it and it fixed.
system
Closed
7
