Not sure if this is an issue of zsh or zsh-completion or pamac or Manjaro who wraps them, so I’m reporting it here …
Steps to reproduce:
- install some packages from aur with
pamac install
- cut off internet connections
- type
sudo pamac remove
, then press tab
What happens:
- an error message is dumped just after the cursor:
Failed to query https://aur.archlinux.org/rpc/?v=5&type=info&arg[]=(...the aur packages just installed)
Expected behavior:
- nothing happens if no completion is found
