Zramctl command under kernel 6.18.26 shows incorrect values
I switched to the kernel 6.18.26 and zramctl does not show the correct information. Regardless of whether swap in zram is used, zramctl always displays the same values:
zramctl
NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
/dev/zram0 lz4             3G    4K   64B   20K       2 [SWAP]
However, in the older kernel 6.12.85 everything is correct and when swap in zram is already used, you can see the correct values, e.g. :
zramctl
/dev/zram0 lz4             3G 82,9M 36,8M 38,7M       2 [SWAP]
Is this a 6.18.xx kernel issue or an issue of some other package in Manjaro?
