Hi,
I’m writing “sudo pacman -U zoom…tar.xz” on terminal.
And terminal say:
sudo: /usr/lib/libc.so.6: version `GLIBC_2.32’ not found (required by /usr/lib/sudo/libsudo_util.so.0)
I think this glibc of last version but i dont know upgrade. Thank you.
Thank you. But i trying install pamac with this code sudo pacman -Syyu base-devel git
but terminal say sudo: /usr/lib/libc.so.6: version `GLIBC_2.32' not found (required by /usr/lib/sudo/libsudo_util.so.0) again. i dont understand.
(i wanna install zoom for online subject on tomorrow. and i should very very fast. this is my first linux adventure thx)
Not working.
What do you think about? I always keep getting this:
I think trouble this. I dont know. I dont using lastest Manjaro version now. I have already .iso file. And i use it. My laptop specs: i5-2430m, 4GB RAM, 500GB HDD, HP Pavilion G6.
inxi -Fazy
Error 10: Unsupported value: 0 for option: y
Check -h for correct parameters.
Manjaro is a rolling release distro and you should update on a regular intervall after reading #announcements. Otherwise, you risks issues as sometimes the update procedure is changed and this forms issues for older systems which have not been prepared for the changes. Maybe some more experienced forum members have an idea how to solve your specific issue. If your install is fresh, I would rather reinstall if you are in a hurry and use the newest 20.1.1 xfce ISO you can get here:
