I’ve been having a problem using the Zoom Video Conferencing software that is available via the software install package within Manjaro. When being assigned to a breakout room i will be dumped out of the program and have to re-log back into the conference. this has been on going for several weeks. I have tried removing/purging zoom and reinstalling several times but had the same problem.
Finally I went to the Zoom web site and downloaded directly from there the Arch/64bit tar and installed by double clicking on the tar file, it installed and works with no problems
Hopefully this helps someone in installing and using the Zoom software
Dave C
