after unstable update 230223. when updating unstable vm zfs modules are not loaded.
(11/19) Install DKMS modules
==> ERROR: Missing 6.2.0-1-MANJARO kernel headers for module zfs/2.1.9.
(12/19) Updating linux initcpios...
Did you install linux62-headers ?
The latest openzfs release does not mention 6.2 :
Thank you Zesko; installing linux-headers was the solution.
However didn’t need to install the headers in former kernels to see zfs pools.
Is this mandatory from 6.2 stable ?
If you want to install any dkms module, you need to install the Kernel header.
See: Dynamic Kernel Module Support - ArchWiki
It is if you plan on updateing the kernel before the developers can upgrade the module.
