For reasons detailed in my previous post (which these forums do not allow me to link to), I have no choice but to use the current 5.6-RT kernel (5.6.19_rt12-3).
I use ZFS for my main storage hard-drive, and it works on most other kernels I’ve tried, but it doesn’t work on 5.6-RT.
There are a few different ways to install ZFS, but all of them fail.
Method 1: linux56-rt-zfs package.
modprobe zfs
modprobe: ERROR: could not insert 'zfs': Exec format error
Method 2: zfs-dkms package, with automatic dkms install.
Preparing...
Resolving dependencies...
Checking inter-conflicts...
Checking keyring...
Checking integrity...
Loading package files...
Checking file conflicts...
Checking available disc space...
Installing zfs-dkms (0.8.4-1)...
Configuring zfs-dkms...
Creating symlink /var/lib/dkms/zfs/0.8.4/source ->
/usr/src/zfs-0.8.4
DKMS: add completed.
==> To build and install your modules run: dkms install zfs/0.8.4
==> To do this automatically at startup run: systemctl enable dkms.service
Arming ConditionNeedsUpdate...
Install DKMS modules
==> dkms install --no-depmod -m zfs -v 0.8.4 -k 5.6.19-3-rt12-MANJARO
Error! Bad return status for module build on kernel: 5.6.19-3-rt12-MANJARO (x86_64)
Error while configuring
Consult /var/lib/dkms/zfs/0.8.4/build/make.log for more information.
==> Warning, `dkms install --no-depmod -m zfs -v 0.8.4 -k 5.6.19-3-rt12-MANJARO' returned 10
==> depmod 5.6.19-3-rt12-MANJARO
Method 3: zfs-dkms-git package, with automatic dkms install.
==> dkms install --no-depmod -m zfs -v git -k 5.6.19-3-rt12-MANJARO
configure: error:
*** None of the expected "rwsem_spinlock_is_raw" interfaces were detected.
*** This may be because your kernel version is newer than what is
*** supported, or you are using a patched custom kernel with
*** incompatible modifications.
*** ZFS Version: zfs-2.0.0-rc1
*** Compatible Kernels: 3.10 - 5.8
Consult /var/lib/dkms/zfs/git/build/make.log for more information.
/var/lib/dkms/zfs/git/build/make.log contains the following:
DKMS make.log for zfs-git for kernel 5.6.19-3-rt12-MANJARO (x86_64)
Sun 6 Sep 16:07:35 BST 2020
make: *** No targets specified and no makefile found. Stop.
Method 4: zfs-linux-rt and zfs-linux-rt-headers
could not satisfy dependencies:
- unable to satisfy dependency 'linux-rt-headers=5.6.17.9-1' required by zfs-linux-rt-headers
- unable to satisfy dependency 'linux-rt=5.6.17.9-1' required by zfs-linux-rt
It seems from this that the zfs-linux-rt package is built for a slightly older 5.6-RT kernel (5.6.17 vs 5.6.19). The package page also reports this (unable to link it on these forums).
Is there any chance simply changing the build instructions to allow for .19 would be safe?
Am I just stuck waiting until this package updates to support my kernel?
I’m getting the impression that there is just no version of ZFS for 5.6.19_rt12-3.
If this is the case, is there any workaround? A different way to load a zfs pool perhaps?
As I mentioned, this kernel is my only choice, due to a different problem.
