my fans don’t work anymore.
After an update a week or two ago did turn on but randomly would turn off, the fix would be to restart the computer, but after a few days, and an update, that didn’t work either.
and now that i look at the inxi, it looks like my fans aren’t found?!
inxi:
Host: simon-m-zephyrusg14-ga402rkga402rk Kernel: 5.19.1-3-MANJARO
arch: x86_64 bits: 64 Desktop: KDE Plasma v: 5.24.6 Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: ROG Zephyrus G14 GA402RK_GA402RK
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: GA402RK v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: GA402RK.312 date: 05/23/2022
ID-1: BAT0 charge: 45.5 Wh (64.2%) condition: 70.9/76.0 Wh (93.3%)
volts: 15.9 min: 15.9
Info: 8-core model: AMD Ryzen 9 6900HS with Radeon Graphics bits: 64
type: MT MCP cache: L2: 4 MiB
Speed (MHz): avg: 2223 min/max: 1600/4934 cores: 1: 1600 2: 3300 3: 1600
4: 3300 5: 3300 6: 1375 7: 1600 8: 3300 9: 3300 10: 1600 11: 1600 12: 3300
13: 1600 14: 1600 15: 1600 16: 1600
Device-1: AMD Navi 23 [Radeon RX 6650 XT] driver: amdgpu v: kernel
Device-2: AMD Rembrandt [Radeon 680M] driver: amdgpu v: kernel
Device-3: Quanta USB2.0 HD UVC WebCam type: USB driver: uvcvideo
Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
compositor: kwin_wayland driver: X: loaded: amdgpu
unloaded: modesetting,radeon gpu: amdgpu,amdgpu resolution: 1707x1067
OpenGL: renderer: AMD Radeon RX 6800S (dimgrey_cavefish LLVM 14.0.6 DRM
3.47 5.19.1-3-MANJARO) v: 4.6 Mesa 22.1.6
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel
Device-2: AMD Rembrandt Radeon High Definition Audio
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: snd_pci_acp6x
Device-4: AMD Family 17h/19h HD Audio driver: snd_hda_intel
Sound Server-1: ALSA v: k5.19.1-3-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.56 running: yes
Device-1: MEDIATEK driver: mt7921e
IF: wlp5s0 state: up mac: b4:8c:9d:5c:77:db
Device-1: IMC Networks Wireless_Device type: USB driver: btusb
Local Storage: total: 1.86 TiB used: 969.54 GiB (50.8%)
ID-1: /dev/nvme0n1 vendor: Toshiba model: N/A size: 1.86 TiB
ID-1: / size: 983.2 GiB used: 917.7 GiB (93.3%) fs: ext4
dev: /dev/nvme0n1p5
ID-2: /boot/efi size: 256 MiB used: 67.8 MiB (26.5%) fs: vfat
dev: /dev/nvme0n1p1
System Temperatures: cpu: 57.8 C mobo: N/A
Fan Speeds (RPM): cpu: 0
GPU: device: amdgpu temp: 49.0 C device: amdgpu temp: 52.0 C fan: 0
Processes: 485 Uptime: 1h 53m Memory: 30.6 GiB used: 4.85 GiB (15.9%)
Shell: Bash inxi: 3.3.20```
