Hello everyone,
I recently got a 2021 Zenbook UX425EA and, unfortunately, it seems both the built-in speakers and microphone aren’t being recognized and thus are unable to play/record any sound.
They are working in Windows though (dual boot), so it seems to be a Manjaro only issue.
I’ve tried swapping between kernels 5.14, 5.10 and 5.4 to no avail.
Here is the output of inxi -Fxz:
System: Kernel: 5.14.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: KDE Plasma 5.22.5 Distro: Manjaro Linux base: Arch Linux
Machine: Type: Laptop System: ASUSTeK product: ZenBook UX425EA_UX425EA v: 1.0
serial: <filter>
Mobo: ASUSTeK model: UX425EA v: 1.0 serial: <filter>
UEFI: American Megatrends LLC. v: UX425EA.307 date: 05/25/2021
Battery: ID-1: BAT0 charge: 64.3 Wh (92.0%) condition: 69.9/67.1 Wh (104.2%) volts: 15.9
min: 15.9 model: ASUSTeK UX425 status: Charging
CPU: Info: Quad Core model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
arch: Tiger Lake rev: 1 cache: L2: 12 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 44864
Speed: 987 MHz min/max: 400/4700 MHz Core speeds (MHz): 1: 987 2: 981 3: 1027
4: 1104 5: 1230 6: 1067 7: 1204 8: 860
Graphics: Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: ASUSTeK driver: i915
v: kernel bus-ID: 0000:00:02.0
Device-2: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 3-6:2
Display: x11 server: X.Org 1.20.13 driver: loaded: modesetting resolution:
1: 1920x1080~60Hz 2: 1920x1080~75Hz
OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 21.2.3
direct render: Yes
Audio: Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: ASUSTeK
driver: sof-audio-pci-intel-tgl bus-ID: 0000:00:1f.3
Sound Server-1: ALSA v: k5.14.10-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Network: Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 0000:00:14.3
Bluetooth: Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-10:3
RAID: Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 bus-ID: 0000:00:0e.0
Drives: Local Storage: total: 953.87 GiB used: 85.82 GiB (9.0%)
ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKNW010T8 size: 953.87 GiB
temp: 37.9 C
Partition: ID-1: / size: 836 GiB used: 85.66 GiB (10.2%) fs: ext4 dev: /dev/nvme0n1p8
ID-2: /boot/efi size: 300.1 MiB used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p6
Swap: ID-1: swap-1 type: partition size: 4 GiB used: 171.5 MiB (4.2%)
dev: /dev/nvme0n1p7
Sensors: System Temperatures: cpu: 45.0 C mobo: N/A
Info: Processes: 317 Uptime: 2d 2h 6m Memory: 15.33 GiB used: 9.01 GiB (58.7%)
Init: systemd Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1298 Shell: Zsh
v: 5.8 inxi: 3.3.08
I greatly appreciate any help!
