Yubikey not recognized in Yubico Authenticator App
So I have a Yubikey 5 NFC Firmware Version 5.43 and Im trying to use the Yubico Authenticator port for Manjaro and for some reason? When I plug my Yubikey in it doesnt recognize it in the Yubico Authenticator App. However it does reconize it in the Yubikey Manager and the Yubikey Personalization Tool. How do I figure out whats wrong and fix it? Ive found a few solutions online but Im not really comfortable just running random commands from reddit. Can someone help me troubleshoot/point me in the right direction on the ArchWiki?
Thanks
wiki: YubiKey - ArchWiki
I dont know about the yubi or its apps (personalisation tool + manager + auth) but wonder if they all use the same modes to connect over usb?
https://wiki.archlinux.org/title/YubiKey#USB_connection_modes
edit:
there is also a bit at the bottom of the wiki about troubleshooting connection to auth app and it mentions having CCID driver installed (it’s in the official rep)
I reinstalled CCID and Im still getting no response. What should I try next?
does command ykman mode show Current connection mode is: OTP+FIDO+CCID
it returns
WARNING: The use of this command is deprecated and will be removed!
Replace with: ykman config mode
Usage: ykman config mode [OPTIONS] MODE
Try 'ykman config mode -h' for help.
Error: Missing argument 'MODE'
ive also tried this below:
[johns@johnd ~]$ ykman mode
Error: Missing argument 'MODE'.
[johns@johnd ~]$ ykman config mode
[johns@johnd ~]$ ^C
[johns@johnd ~]$ ykman config mode -h
  Manage connection modes (USB Interfaces).
  This command is generaly used with YubiKeys prior to the 5 series. Use
  "ykman config usb" for more granular control on YubiKey 5 and later.
  Get the current connection mode of the YubiKey, or set it to MODE.
  MODE can be a string, such as "OTP+FIDO+CCID", or a shortened form: "o+f+c".
  It can also be a mode number.
  Examples:
    Set the OTP and FIDO mode:
    $ ykman config mode OTP+FIDO
    Set the CCID only mode and use touch to eject the smart card:
    $ ykman config mode CCID --touch-eject
Options:
  --touch-eject                When set, the button toggles the state of the
                               smartcard between ejected and inserted (CCID
                               mode only).
  --autoeject-timeout SECONDS  When set, the smartcard will automatically
                               eject after the given time. Implies --touch-
                               eject (CCID mode only).
  --chalresp-timeout SECONDS   Sets the timeout when waiting for touch for
                               challenge response.
  -f, --force                  Confirm the action without prompting.
  -h, --help                   Show this message and exit.
[johns@johnd ~]$ ykman config mode [OPTIONS] MODE
Error: Invalid mode string: [OPTIONS]
[johns@johnd ~]$ ykman config MODE
Usage: ykman config [OPTIONS] COMMAND [ARGS]...
Try 'ykman config -h' for help.
Error: No such command 'MODE'.
[johns@johnd ~]$
still cant get the connection modes or whatever
sorry for basically asking to be hand held I just dont want to mess the key up
Looks like the wiki is out of date.
lsusb should list usb devices with yubico info
Looks better to have a read of the yubi page
https://docs.yubico.com/software/yubikey/tools/ykman/intro.html
Looks like it’s more yubi man based than the wiki is anyway.
have you been through that?
Did you start and enable the pcscd ?
sudo systemctl enable pcscd --now
I got a new laptop yesterday - - battled a bit to get yubikey going again - same issues as you, till i started the pcscd services
yeah that worked thanks
