Just recently yubico authenticator has stopped working on manjaro. It works fine on my other two distros so it is nothing to do with the key itself, it is recognised by lsusb and ykman on manjaro and indeed using ykman I can get correct authentication codes but I prefer the gui. Anyone have any idea about this? (clue, it is not a pcscd error) When started from the cli I get the following overly large error message (but it means nothing to me):
yubioath-desktop
qrc:/qml/main.qml:305:5: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 7. Use 'sequences: [ <key> ]' to bind to all of them.
qrc:/qml/main.qml:297:5: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 9. Use 'sequences: [ <key> ]' to bind to all of them.
"PyOtherSide error: Traceback (most recent call last):\n\n File \"qrc:///py/yubikey.py\", line 23, in <module>\n from ykman.device import scan_devices, list_all_devices, connect_to_device, get_name, read_info\n\nImportError: cannot import name 'connect_to_device' from 'ykman.device' (/usr/lib/python3.10/site-packages/ykman/device.py)\n"
Unhandled PyOtherSide error: Cannot import module: yubikey (Traceback (most recent call last):
File "qrc:///py/yubikey.py", line 23, in <module>
"PyOtherSide error: Traceback (most recent call last):\n\n File \"<string>\", line 1, in <module>\n\nNameError: name 'yubikey' is not defined\n"
Unhandled PyOtherSide error: Function not found: 'yubikey.init' (Traceback (most recent call last):
File "<string>", line 1, in <module>
Unhandled PyOtherSide error: Function not found: 'yubikey.controller.check_descriptors' (Traceback (most recent call last):
Unhandled PyOtherSide error: Function not found: 'yubikey.controller.is_win_non_admin' (Traceback (most recent call last):
qml: TypeError: Cannot read property 'success' of undefined undefined
qml: TypeError: Cannot read property 'winNonAdmin' of undefined undefined
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
