I have now also installed yt-dlp in Manjaro (Plasma 6), as I have been using it on my computer with EndeavourOS for some time and would also like to use it with manjaro. However, I always get the same message every time I enter something:
zsh: no matches found: https://www.youtube.com/watch?v=o-X-rAEBSng
Is this possibly due to zsh (only tested with bash so far)?
To help us help you, please see the following and edit your topic title to be clear and concise about the issue and correct your spelling. Please also edit your post to provide more information like the command your ran and complete output.
Use bash or zsh with quotes! (just tested). The problem seems to be some autocompletion or auto search function or config of zsh - it seems confused by the question mark in the url. What exactly is for you to find, i do not use zsh, but this works
With the quotation marks it works at least now, but I still get 2 strange warning messages:
yt-dlp "https://www.youtube.com/watch?v=QOcznP1AU9E" ✔ 12s
[youtube] Extracting URL: https://www.youtube.com/watch?v=QOcznP1AU9E
[youtube] QOcznP1AU9E: Downloading webpage
WARNING: [youtube] Unable to download webpage: <urllib3.connection.HTTPSConnection object at 0x7e3a94e8c620>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution
[youtube] QOcznP1AU9E: Downloading ios player API JSON
[youtube] QOcznP1AU9E: Downloading android player API JSON
[youtube] QOcznP1AU9E: Downloading iframe API JS
[youtube] QOcznP1AU9E: Downloading player 74a3a562
[youtube] QOcznP1AU9E: Downloading web player API JSON
WARNING: [youtube] Skipping player responses from android clients (got player responses for video "aQvGIIdgFDM" instead of "QOcznP1AU9E")
[youtube] QOcznP1AU9E: Downloading m3u8 information
[youtube] QOcznP1AU9E: Downloading initial data API JSON
[info] QOcznP1AU9E: Downloading 1 format(s): 303+251
[download] Destination: KENWOOD speaker system restoration ⧸⧸ The best restoration you've ever seen [QOcznP1AU9E].f303.webm
[download] 100% of 558.37MiB in 00:00:51 at 10.88MiB/s
[download] Destination: KENWOOD speaker system restoration ⧸⧸ The best restoration you've ever seen [QOcznP1AU9E].f251.webm
[download] 100% of 25.29MiB in 00:00:03 at 6.80MiB/s
[Merger] Merging formats into "KENWOOD speaker system restoration ⧸⧸ The best restoration you've everseen [QOcznP1AU9E].webm"
Deleting original file KENWOOD speaker system restoration ⧸⧸ The best restoration you've ever seen [QOcznP1AU9E].f251.webm (pass -k to keep)
Deleting original file KENWOOD speaker system restoration ⧸⧸ The best restoration you've ever seen [QOcznP1AU9E].f303.webm (pass -k to keep)
You didn’t do anything wrong, per say. However, without knowing what command you ran and what the full output was, it’s hard for anyone to know how to help–well, except maybe for @Teo since he seems to be experienced enough with yt-dlp to know what you were talking about.
By the way it’s doesn’t with the apostrophe between the N and the T as in an abbreviation for does not.
Thanks @Teo, what’s with the warning messages? Can I do anything about it?
Here’s another option for your consideration. It lets you copy the URL and then just run a command, no need for quotes or even pasting.
Assuming you save it as ~/.local/bin/ytdlp, copy the URL and run ytdlp, the video will be downloaded to the current dir, unless you uncomment the download_dir lines.
You could bind it to a keyboard shortcut but you should set a download dir first.
#!/usr/bin/bash
# Copy the url, eg with Ctrl + C
url=$(xclip -o -selection clipboard)
# If you'd rather just select the url then uncomment this
# and comment the line above
#url=$(xclip -o -selection primary)
# The regular expression is so we don't try to download
# random stuff in the clipboard, it shouldn't matter
# yt-dlp should complain and exit anyway
# but this way the output is short and clear
# for youtube
regex='^https://www.youtube.com/watch.*'
# for any site, not tested
#regex="^https?://www\..*"
# set a location to download to
# download_dir=~/Videos/yt-dlp
# or with a parameter
# download_dir="$1"
if [[ $url =~ $regex ]]; then
# mkdir "$download_dir" # if it already exists, nothing happens
# cd "$download_dir"
yt-dlp "$url"
else
echo "Invalid URL: $url"
fi
This was simplified from another script I made, I haven’t tested this version.
Thanks for the script and the effort you’ve put in, but it just looks like there are problems with characters in the URLS, which is where the quotes come in:
yt-dlp https://www.youtube.com/watch?v=N_5s8x6OojY
zsh: no matches found: https://www.youtube.com/watch?v=N_5s8x6OojY
The problems come from zsh trying to interpret the characters, the quotes stop this. AFAIK it should work in bash (does normally, but I can’t say for certain that there aren’t any problematic chars), which is what the script runs in but I’ve edited the script just in case.
I’ve used the original script and it definitely works (and includes the quotes I’ve added above).
It was designed so I don’t have to type out the command every time, especially in zsh where quotes are needed.
