"You need to load the kernel first" after system update
I did a system update today (around 500 files) and let it do it’s thing. Once it finished it asked me to restart the system. I did that and I am now stuck with this message
I tried using the options here
The first two options give the same error screen. The third choice spins my PC fans to max speed and stalls on a screen that says “@^” …if I remember correctly. The fourth option stalls on the manjaro loading screen.
I’ve looked up some fixes but I’m too scared to mess things up further. I have the latest iso on a usb stick flashed with balenaetcher. The “system recovery” on the manjaro welcome screen does nothing for any option. I don’t know what else to do.
Mod Edit:- Screenshots removed. In future please do not post screenshots or photos in place of text content.
I read that the forum supports drag and dropping pictures. My apologies.
First screenshot
error: file ‘/boot/vmlinuz-6.10-x86_64’ not found.
error: you need to load the kernel first.
Press any key to continue…
Second screenshot is the advanced options for manjaro linux.
Option #1 Manjaro (Kernel: Linux 6.10.11-2-MANJARO x64)
Option #2 Manjaro (Kernel: Linux 6.10.11-2-MANJARO x64) - fallback initramfs)
Option #3 Manjaro Linux (Kernel 4.19.322-1-MANJARO x64)
Option #4 Manjaro Linux (Kernel 4.19.322-1-MANJARO x64) - fallback initramfs
To reiterate, option one and two give the same error message as the normal boot option. Option three puts my PCs fans at max speed with a @^ message. Option number four stalls on the default manjaro loading screen.
kernel 6.10 is end of life, and the 4.19 is too old, so maybe not compatible with your machine hardware… you need to boot into manjaro live usb, chroot, and install a kernel:
boot into manjaro live usb, make sure you are connected to internet, open terminal and chroot:
manjaro-chroot -a
(this command doesnt work with btrfs/ encryption)
rerun update:
pacman-mirrors -f 5 && pacman -Syyu
if there are errors post the output here, if there are no errors and you are up to date, remove the 6.10:
pacman -R linux610
install another:
pacman -S linux66
if no errors, reboot…
First of all, thank you!
manjaro-chroot -a gives this
manjaro-chroot -a  :heavy_check_mark:
grub-probe: error: cannot find a GRUB drive for /dev/sda1. Check your device.map.
==> Mounting (ManjaroLinux) [/dev/nvme2n1p2]
→ mount: [/mnt]
→ mount: [/mnt/boot/efi]
[manjaro /]#
I’m going to take a guess that is the btrfs/ encryption you mentioned. Is there a way around this?
you dont have btrfs/encryption, you are chrooted, so proceed with the commands…
btw, do you have nvidia?
All amd.
Okay, well pacman -R linux610 gives this
error: target not found: linux610
first the update command, everything ok? are you up to date? if yes, post output from:
mhwd-kernel -li
Everything is up to date.
[manjaro /]# mhwd-kernel -li
Currently running: 6.10.13-3-MANJARO (linux610)
  • linux419
  • linux611
  • linux66
so you have installed normal kernels, but it wants to load the 6.10, and also in your grub menu, only the 4.19 and the 6.10 are listed…
run this:
mkinitcpio -P && update-grub
and post output from it here, formatted of course:
your text
[manjaro /]#  mkinitcpio -P && update-grub
==> Building image from preset: /etc/mkinitcpio.d/linux419.preset: 'default'
==> Using default configuration file: '/etc/mkinitcpio.conf'
  -> -k /boot/vmlinuz-4.19-x86_64 -g /boot/initramfs-4.19-x86_64.img
==> Starting build: '4.19.324-1-MANJARO'
  -> Running build hook: [base]
  -> Running build hook: [udev]
  -> Running build hook: [kms]
  -> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
  -> Running build hook: [plymouth]
  -> Running build hook: [fsck]
==> Creating gzip-compressed initcpio image: '/boot/initramfs-4.19-x86_64.img'
  -> Early uncompressed CPIO image generation successful
==> Initcpio image generation successful
==> Building image from preset: /etc/mkinitcpio.d/linux419.preset: 'fallback'
  -> -k /boot/vmlinuz-4.19-x86_64 -g /boot/initramfs-4.19-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: 'ast'
==> WARNING: Possibly missing firmware for module: 'qed'
==> WARNING: Possibly missing firmware for module: 'qla2xxx'
==> WARNING: Possibly missing firmware for module: 'aic94xx'
==> WARNING: Possibly missing firmware for module: 'bfa'
==> WARNING: Possibly missing firmware for module: 'qla1280'
==> WARNING: Possibly missing firmware for module: 'wd719x'
==> Creating gzip-compressed initcpio image: '/boot/initramfs-4.19-x86_64-fallback.img'
==> Building image from preset: /etc/mkinitcpio.d/linux611.preset: 'default'
  -> -k /boot/vmlinuz-6.11-x86_64 -g /boot/initramfs-6.11-x86_64.img
==> Starting build: '6.11.10-2-MANJARO'
==> WARNING: Possibly missing firmware for module: 'xhci_pci'
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.11-x86_64.img'
==> Building image from preset: /etc/mkinitcpio.d/linux611.preset: 'fallback'
  -> -k /boot/vmlinuz-6.11-x86_64 -g /boot/initramfs-6.11-x86_64-fallback.img -S autodetect
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.11-x86_64-fallback.img'
==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'default'
  -> -k /boot/vmlinuz-6.6-x86_64 -g /boot/initramfs-6.6-x86_64.img
==> Starting build: '6.6.63-1-MANJARO'
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.6-x86_64.img'
==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'fallback'
  -> -k /boot/vmlinuz-6.6-x86_64 -g /boot/initramfs-6.6-x86_64-fallback.img -S autodetect
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.6-x86_64-fallback.img'
/etc/default/grub: line 50: unexpected EOF while looking for matching `"'
[manjaro /]#
mkinitcpio look ok, but something wrong with grub:
post output from:
cat /etc/default/grub
[manjaro /]# cat /etc/default/grub
# GRUB boot loader configuration
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="GRUB_CMDLINE_LINUX_DEFAULT=“quiet splash acpi=force apm=power_off”
GRUB_CMDLINE_LINUX=""
#GRUB_ENABLE_CRYPTODISK=y
# Set to 'countdown' or 'menu' to change timeout behavior,
# press ESC key to display menu.
GRUB_TIMEOUT_STYLE=hidden
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors.  Used by normal and wallpaper
# modes only.  Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to make GRUB remember the last selection. This requires
# setting 'GRUB_DEFAULT=saved' above.
GRUB_SAVEDEFAULT=true
# Uncomment to disable submenus in boot menu
#GRUB_DISABLE_SUBMENU=y
GRUB_DISABLE_OS_PROBER=false
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically. We use 'fsck' by default, which
# needs 'rw' as boot parameter, to avoid delay in boot-time. 'fsck' needs to be
# removed from 'mkinitcpio.conf' to make 'systemd-fsck' work.
# See also Arch-Wiki: https://wiki.archlinux.org/index.php/Fsck#Boot_time_checking
#GRUB_ROOT_FS_RO=true
[manjaro /]#
this line is wrong:
it should look like this:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi=force apm=power_off"
so edit it:
nano /etc/default/grub
edit the line as outlined above, save the file, rerun:
update-grub
and post output from the update command
[manjaro /]# update-grub
Found linux image: /boot/vmlinuz-6.11-x86_64
Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-6.11-x86_64.img
Found initrd fallback image: /boot/initramfs-6.11-x86_64-fallback.img
Found linux image: /boot/vmlinuz-6.6-x86_64
Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-6.6-x86_64.img
Found initrd fallback image: /boot/initramfs-6.6-x86_64-fallback.img
Found linux image: /boot/vmlinuz-4.19-x86_64
Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-4.19-x86_64.img
Found initrd fallback image: /boot/initramfs-4.19-x86_64-fallback.img
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
/usr/bin/grub-probe: warning: unknown device type nvme2n1.
Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
done
[manjaro /]#
now it looks ok… you can remove the old 4.19:
pacman -R linux419
reboot and see if it helped…
and out of curiosity, why do you have those kernel parameters?:
That fixed it. I’m on my actual manjaro install now. 419 is gone. The reason was because my PC would not shut completely down and hang on a black screen. I later learned that that was because of a KDE setting that needed changed.
Thank you once again.
ok, so if those parameters are not needed, you can remove them, and dont make again a mistake when removing them, and dont forget to update grub afterwards:
sudo update-grub
