Hello, I updated the packages using the command pacman -Syu
mistake: i didnt check the update logs and cleared my terminal
When booting the system again it says:
error: file /boot/vmlinuz-5.10-x86_64 not found.
error: you need to load the kernel first.
What I tried
I tried booting a different kernel it showed file system errors so i tried to fix it using fsck command like usual after that i tried to reboot in the same kernel but there is a error message that says kernel panic not syncing attempted to kill init!
I booted from a live USB and tried running manjaro-chroot -a
Output:
grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map.
==> Mounting (ManjaroLinux) [/dev/sda5]
--> mount: [/mnt]
--> mount: [/mnt/boot/efi]
--> mount: [/mnt/home]
chroot: failed to run command '/bin/bash': Input/output error
--> umount: [/mnt/home]
--> umount: [/mnt/boot/efi]
--> umount: [/mnt]
Kindly let me know if any more information is needed as this is ny first time creating a topic
That’s not chroot failing, that’s chroot informing you that /bin/bash could not be executed. Weird, true, but not chroot itself failing.
But it sounds like a problem with you hard drive. Boot into a live environment and provide the output of:
please.
Thanks for pointing out about chroot
Following is the output:
Kernel: 5.15.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_KDE_2137 quiet systemd.show_status=1
driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
Console: pty pts/2 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: ASUSTeK product: TUF Gaming FX505DD v: 1.0
serial: <filter>
Mobo: ASUSTeK model: FX505DD v: 1.0 serial: <filter>
UEFI: American Megatrends v: FX505DD.317 date: 03/11/2021
ID-1: BAT0 charge: 32.3 Wh (100.0%) condition: 32.3/48.2 Wh (66.9%)
volts: 12.5 min: 11.9 model: FX50442 type: Li-ion serial: N/A status: full
RAM: total: 5.72 GiB used: 2.12 GiB (37.1%)
Array-1: capacity: 32 GiB slots: 2 EC: None max-module-size: 16 GiB
note: est.
Device-1: DIMM 0 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 8 GiB speed: spec: 2667 MT/s actual: 2400 MT/s volts: curr: 1.2
min: 1.2 max: 1.2 width (bits): data: 64 total: 64 manufacturer: Samsung
part-no: M471A1K43DB1-CTD serial: <filter>
Device-2: DIMM 0 type: no module installed
Info: model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx socket: FP5
bits: 64 type: MT MCP arch: Zen/Zen+ note: check gen: 1 built: 2019
process: GF 12nm family: 0x17 (23) model-id: 0x18 (24) stepping: 1
microcode: 0x8108102
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1400 min/max: 1400/2100 boost: enabled
base/boost: 2100/3700 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.2 V ext-clock: 100 MHz cores: 1: 1400 2: 1400 3: 1400 4: 1400
5: 1400 6: 1400 7: 1400 8: 1400 bogomips: 33548
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
prctl and seccomp
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GP107M [GeForce GTX 1050 3 GB Max-Q] vendor: ASUSTeK
driver: nouveau v: kernel non-free: 515.xx+ status: current (as of 2022-07)
arch: Pascal code: GP10x process: TSMC 16nm built: 2016-21 pcie:
speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s ports:
active: none empty: HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1c91
class-ID: 0300
Device-2: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: eDP-1 empty: none bus-ID: 04:00.0 chip-ID: 1002:15d8
class-ID: 0300
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 3-1:2 chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu
display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: Najing CEC Panda 0x0036 built: 2018
res: 1920x1080 hz: 120 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: AMD Radeon Vega 8 Graphics (raven LLVM 14.0.6 DRM 3.42
5.15.60-1-MANJARO) v: 4.6 Mesa 22.1.6 direct render: Yes
Device-1: NVIDIA GP107GL High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: speed: Unknown lanes: 63 link-max:
gen: 6 speed: 64 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: ASUSTeK
bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.60-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
vendor: AzureWave driver: rtw_8822be v: N/A modules: rtw88_8822be pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0
chip-ID: 10ec:b822 class-ID: 0280
Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-4:3 chip-ID: 13d3:3526 class-ID: e001 serial: <filter>
Local Storage: total: 939.05 GiB used: 0 KiB (0.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B sata: 3.3
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 0J temp: 39 C
scheme: GPT
SMART: yes state: enabled health: PASSED on: 303d 21h cycles: 3125
Old-Age: g-sense error rate: 2929 Pre-Fail: reallocated sector: 100
threshold: 50
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Transcend
model: JetFlash 8GB size: 7.54 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> rev: 8.07 scheme: MBR
Message: No partition data found.
ID-1: /dev/sda1 maj-min: 8:1 size: 260 MiB fs: vfat label: SYSTEM
uuid: B42D-3BFD
ID-2: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: N/A label: N/A uuid: N/A
ID-3: /dev/sda3 maj-min: 8:3 size: 720.41 GiB fs: ntfs label: OS
uuid: EA1A2FDF1A2FA811
ID-4: /dev/sda4 maj-min: 8:4 size: 850 MiB fs: ntfs label: RECOVERY
uuid: 40C898C5C898BB1C
ID-5: /dev/sda5 maj-min: 8:5 size: 43.95 GiB fs: ext4 label: N/A
uuid: 5c0fc376-aa28-42b4-b78a-5305b6c0b33e
ID-6: /dev/sda6 maj-min: 8:6 size: 154.3 GiB fs: ext4 label: N/A
uuid: 829a5f0c-9640-4d92-af1f-86da725343fb
ID-7: /dev/sda7 maj-min: 8:7 size: 11.76 GiB fs: swap label: N/A
uuid: 21e4944b-420b-4c45-b920-57cf6fa26563
ID-8: /dev/sdb1 maj-min: 8:17 size: 3.32 GiB fs: iso9660
ID-9: /dev/sdb2 maj-min: 8:18 size: 4 MiB fs: vfat label: MISO_EFI
uuid: C80E-8B3F
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 1-2:2 info: Transcend Information JetFlash type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA
chip-ID: 8564:1000 class-ID: 0806 serial: <filter>
Device-2: 1-4:3 info: IMC Networks Bluetooth Radio type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 3-1:2 info: IMC Networks USB2.0 HD UVC WebCam type: Video
Hub-4: 4-0:1 info: Super-speed hub ports: 1 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 57.6 C mobo: N/A
Fan Speeds (RPM): cpu: 3600
GPU: device: nouveau temp: N/A device: amdgpu temp: 57.0 C
Processes: 267 Uptime: 3m wakeups: 1 Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.1 clang: 14.0.6 Packages: pacman: 1209
lib: 318 flatpak: 0 Shell: Zsh (sudo) v: 5.9 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.20
faizan1191:
ID-1: /dev/sda
Hmm, the device isn’t mentioned in the chroot output…let’s test it. Run the following:
sudo smartctl --health /dev/sda
And provide that here, please.
smartctl 7.3 2022-02-28 r5338 [x86_64-linux-5.15.60-1-MANJARO] (local build)
Copyright (C) 2002-22, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
OK, looks good so far. So let’s try the chroot again.
To chroot
Ensure you’ve got a relatively new ISO or at least one with a still supported LTS kernel.
Write/copy/dd the ISO to a USB thumb drive.
When done, boot with the above mentioned USB thumb drive into the live environment.
Once booted, open a terminal and enter the following command to enter the chroot encironment:
manjaro-chroot -a
If you have more than one Linux installation, select the correct one to use from the list provided.
When done, you should now be in the chroot environment.
But, be careful , as you’re now in an actual root environment on your computer, so any changes you make will persist after a restart.
When in the chroot environment, let me know by replying with the output of the following, run from within the chroot environment:
mhwd-kernel --listinstalled
and
mhwd-kernel --list
I am live rn from the latest manjaro kde iso
now the chroot output has changed and is very weird:
/usr/share/os-prober/common.sh: line 15: /usr/bin/mktemp: Input/output error
/usr/share/os-prober/common.sh: line 95: /usr/bin/readlink: Input/output error
==> ERROR: No Linux partitions detected!
tried running the command using sudo as well but same output
tried sudo su -
sudo: unable to execute /usr/bin/su: Input/output error
Still looks like some kind of HDD error to me. Let’s start from the beginning:
Restart, completely restart your PC and boot into a live environment. When done, open a terminal and run:
sudo smartctl --test short /dev/sda
…and provide the output here, please.
Command output:
=== START OF OFFLINE IMMEDIATE AND SELF-TEST SECTION ===
Sending command: "Execute SMART Short self-test routine immediately in off-line mode".
Drive command "Execute SMART Short self-test routine immediately in off-line mode" successful.
Testing has begun.
Please wait 2 minutes for test to complete.
Test will complete after Wed Sep 7 14:45:48 2022 UTC
Use smartctl -X to abort test.
Output of the test using:
smartctl -l selftest /dev/sda
Output:
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed without error 00% 7293 -
faizan1191:
Looks good.
Now, please open a terminal again, and try the chroot instructions as provided earlier, and reply if successful as well, please.
Whatever you do:
Do not run a command/commands in the terminal after completing the steps. Not even if it seems like something failed, as above.
The chroot ouput is same as in the 1/10 (start of the thread)
OK, something might be funky. Let’s test if you are, in fact, in a chroot environment. Please run the following:
grep ' / ' /proc/mounts
Output:
overlay / overlay rw,relatime,lowerdir=/run/miso/sfs/livefs:/run/miso/sfs/mhwdfs:/run/miso/sfs/desktopfs:/run/miso/sfs/rootfs,upperdir=/run/miso/overlay_root/upper,workdir=/run/miso/overlay_root/work,index=off,xino=off 0 0
That doesn’t look like a chroot environment to me. I’m officially all out of ideas. I’m going to have to call in reinforcements.
@anon89812132 @linux-aarhus @Fabby if you guys know what’s up, or have any idea at least, can you please, please, please tell us? So @faizan1191 can have a working PC, and I can learn something. If I can do that, I’ll mark today as a good day!
Initial guess is a faulty - likely an incomplete ISO - did you validate the downloaded file for completeness?
Yes i have verified the SHA1 checksum of the iso in use
I think I misunderstood something.
To get my understanding right
You synced your system - and after that sync - when rebooted you are greeted with the no kernel message.
Then you go the live iso way to rescue the system - but when when chrooting you get the quoted messages
The first error message is
This grub-probe error means nothing in relation to the automatic chroot
The second error message
This message indicates a file system error - likely a disk error - but could also be caused if the sync process being interupted by a power outage.
I have no clues to what you can do as that depends on the filesystem and how valuable the data may be on the disk.
If it is a filesystem error cause by a start-to-fail disk and If you have data you would like rescued - then any and all attempts from your side a likely to make the matter worse.
Replace the disk and reinstall your system and take the damaged to a professional data salvage shop. If you are a DIY linux user - you may play with testdisk and photorec and try if you can salvage anything from the damaged disk
Do your self a favor - never work the original.- but clone the damaged disk - then work on the copy.
If you have backup of your personal files or dtherwise don’t care - reinstall the system.
The sync process was not interrupted by a power outage as the device was connected to a stable power source throughout the process
Going ahead with reinstalling the system, thanks for the support @Mirdarthos @linux-aarhus
