Dear all,
Probably due to a wrong choice during installation I lost my Win10 boot capability. Details are here: previously on my laptop
Currently I can only boot to Manjaro, there seems to be no data loss.
My aim is to have a grub screen at startup to choose between Manjaro and Win10 to boot. Currently the laptop boots to Manjaro, I could not get it boot to Win10.
Any help is very much appreciated! Below there is the output of some of the commands usually asked for.
The output of update-grub:
Found linux image: /boot/vmlinuz-6.1-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.1-x86_64.img
Found initrd fallback image: /boot/initramfs-6.1-x86_64-fallback.img
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
done
The output of parted -l:
Model: ATA SAMSUNG MZ7LN512 (scsi)
Disk /dev/sda: 512GB
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 1049kB 577MB 576MB primary ntfs boot
2 577MB 247GB 246GB primary ntfs
3 247GB 407GB 160GB primary ntfs
4 407GB 512GB 105GB extended lba
5 407GB 512GB 105GB logical ntfs
Model: ATA TS240GMTS420S (scsi)
Disk /dev/sdb: 240GB
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 2097kB 317MB 315MB fat32 boot, esp
2 317MB 226GB 226GB ext4 root
3 226GB 240GB 13,7GB linux-swap(v1) swap
The output of efibootmgr:
BootCurrent: 0013
Timeout: 0 seconds
BootOrder: 0013,0009,000C,0007,0008,000A,000B,000D,0012
Boot0000 Setup FvFile(721c8b66-426c-4e86-8e99-3457c46ab0b9)
Boot0001 Boot Menu FvFile(126a762d-5758-4fca-8531-201a7f57f850)
Boot0002 Diagnostic Splash Screen FvFile(a7d8d9a6-6ab0-4aeb-ad9d-163e59a7a380)
Boot0003 Lenovo Diagnostics FvFile(3f7e615b-0d45-4f80-88dc-26b234958560)
Boot0004 Startup Interrupt Menu FvFile(f46ee6f4-4785-43a3-923d-7f786c3c8479)
Boot0005 Rescue and Recovery FvFile(665d3f60-ad3e-4cad-8e26-db46eee9f1b5)
Boot0006 MEBx Hot Key FvFile(ac6fd56a-3d41-4efd-a1b9-870293811a28)
Boot0007* USB CD VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,86701296aa5a7848b66cd49dd3ba6a55)
Boot0008* USB FDD VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,6ff015a28830b543a8b8641009461e49)
Boot0009* ATA HDD0 VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,91af625956449f41a7b91f4f892ab0f600)
Boot000A* ATA HDD1 VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,91af625956449f41a7b91f4f892ab0f601)
Boot000B* ATA HDD2 VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,91af625956449f41a7b91f4f892ab0f602)
Boot000C* USB HDD VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,33e821aaaf33bc4789bd419f88c50803)
Boot000D* PCI LAN VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,78a84aaf2b2afc4ea79cf5cc8f3d3803)
Boot000E* IDER BOOT CDROM PciRoot(0x0)/Pci(0x16,0x2)/Ata(0,1,0)
Boot000F* IDER BOOT Floppy PciRoot(0x0)/Pci(0x16,0x2)/Ata(0,0,0)
Boot0010* ATA HDD VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,91af625956449f41a7b91f4f892ab0f6)
Boot0011* ATAPI CD VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,aea2090adfde214e8b3a5e471856a354)
Boot0012* PCI LAN VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,78a84aaf2b2afc4ea79cf5cc8f3d3803)
Boot0013* Manjaro HD(1,GPT,4d7dcbd6-74f2-0246-8fac-3dc0c3f2452c,0x1000,0x96000)/File(\EFI\Manjaro\grubx64.efi)
