Hello!
After having an update crash in the middle and forcing a reboot, my Manjaro installation is refusing to boot. I’m getting the messages seen at the imgur photo manjaro-boot-fails-OV6bqJQ
So far I’ve tried booting into a live USB, doing manjaro-chroot -a and pacman-mirrors -f && pacman -Syyu. pacman reported that everything was up to date, nothing to do.
I can add 3 to the grub boot line, which does get me to a CLI login screen, but not much works from there, including that sudo seems to have no effect and dbus is not running.
Just running ‘update’ again wont necessarily fix anything.
This is the basic guide.
Which I thought provided some more steps than that … but it seems the only addition is ‘update-grub’, which may or may not even be present on newer systems.
It would also make sense to rebuild initramfs, so I will rehash the steps after chroot here;
I forgot to mention that I did try update-grub before as suggested in the post that you linked to.
I ran the steps you suggested and I got a bunch of errors from ldconfig saying “File /usr/lib/ is empty, not checked” but otherwise it finished without a problem.
And now when I try to boot the bootloader can’t decrypt my harddrive, though the live USB still can.
EDIT - Oh, and I did look at the pacman log but the transaction that I thought was running when the computer crashed appears to have completed mostly successfully, though I don’t see a “Transaction completed” line at the end of it.
Now that will still print a bunch of stuff not extremely useful to you.
So I would also ignore the lines that have to do with time/permission/etc mismatches
(most if not all of these will be a non-issue)
grep -v mismatch packagecheck
Which will probably still include not so necessary to this specific situation packages.
We can choose to include them in the following steps, or whittle the list even further by looking for ‘mtree’ lines, which are likely all packages related to your issue.
grep mtree packagecheck
However you do it you will want to formulate a list and reinstall those packages.
I will assume ‘firefox’ for convenience.
I would suggest clearing your cache first.
You could opt to remove the offenders explicitly using either a tool or just rm;
paccache -rvk0 firefox
OR
sudo rm /var/cache/pacman/pkg/firefox*
OR you can just clear the cache as a whole
sudo pacman -Sc
But once the cache of the problem package(s) is removed then reinstall the package(s).
Ok, I ran the pacman -Qkk line and ended up with a big file. grep mtree | wc -l on that file gives me 172. When I try to run pacman -Syu on any of those packages, though, I get a line for each file in the package saying it already exists in the filesystem, then “Errors occurred, no packages were upgraded.”
