I did a system upgrade on manjaro using yay -Syu
. It appears it upgraded gcc to some experimental version.
I tried reinstalling
gcc13
but it didn’t fix the problem:export LDFLAGS="${LDFLAGS/-fuse-ld=mold/-fuse-ld=ld}"
before trying to install.export CC=gcc-13 CXX=g++-13
yay -S base-devel
installs the experimental gcc 14.2.1+r134+gab884fffe3fc-1 again if i try to uninstall it. -
I queried 3 different llms and got no useful answers.
Here are the logs:
yay -S --noconfirm bambustudio-git
AUR Explicit (1): bambustudio-git-01.06.00.65.15.g693af0c9-1
:: PKGBUILD up to date, skipping download: bambustudio-git
1 bambustudio-git (Build Files Exist)
==> Packages to cleanBuild?
==> [N]one [A]ll [Ab]ort [I]nstalled [No]tInstalled or (1 2 3, 1-3, ^4)
==> Diffs to show?
==> Making package: bambustudio-git 01.07.01.62.4.g5ef759ce-1 (Wed 06 Nov 2024 04:07:17 PM)
==> Retrieving sources...
-> Updating BambuStudio git repo...
-> Found BambuStudio.cpp.patch
-> Found CMakeLists.txt.patch
-> Found wxWidgets.cmake.patch
-> Found bambu-studio.sh
==> WARNING: Skipping verification of source file PGP signatures.
==> Validating source files with sha512sums...
BambuStudio ... Skipped
BambuStudio.cpp.patch ... Passed
CMakeLists.txt.patch ... Passed
wxWidgets.cmake.patch ... Passed
bambu-studio.sh ... Passed
:: (1/1) Parsing SRCINFO: bambustudio-git
==> Making package: bambustudio-git 01.07.01.62.4.g5ef759ce-1 (Wed 06 Nov 2024 04:07:19 PM)
==> Extracting sources...
-> Creating working copy of BambuStudio git repo...
Cloning into 'BambuStudio'...
done.
Updating files: 100% (6964/6964), done.
==> Starting prepare()...
patching file BambuStudio/CMakeLists.txt
Hunk #1 succeeded at 745 (offset 54 lines).
==> Starting pkgver()...
==> Updated version: bambustudio-git 01.10.00.81.10.g733531b-1
==> Sources are ready.
==> Making package: bambustudio-git 01.10.00.81.10.g733531b-1 (Wed 06 Nov 2024 04:07:23 PM)
==> WARNING: Using existing $srcdir/ tree
==> Removing existing $pkgdir/ directory...
==> Starting build()...
CMake Warning (dev) at CMakeLists.txt:23 (project):
cmake_minimum_required() should be called prior to this top-level project()
call. Please see the cmake-commands(7) manual for usage documentation of
both commands.
This warning is for project developers. Use -Wno-dev to suppress it.
-- The C compiler identification is GNU 13.3.0
-- The CXX compiler identification is GNU 13.3.0
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - failed
-- Check for working C compiler: /usr/bin/gcc-13
-- Check for working C compiler: /usr/bin/gcc-13 - broken
CMake Error at /usr/share/cmake/Modules/CMakeTestCCompiler.cmake:67 (message):
The C compiler
"/usr/bin/gcc-13"
is not able to compile a simple test program.
It fails with the following output:
Change Dir: '/tmp/makepkg/bambustudio-git/src/BambuStudio/deps/build/CMakeFiles/CMakeScratch/TryCompile-c94XFe'
Run Build Command(s): /usr/bin/cmake -E env VERBOSE=1 /usr/bin/make -f Makefile cmTC_b88fe/fast
/usr/bin/make -f CMakeFiles/cmTC_b88fe.dir/build.make CMakeFiles/cmTC_b88fe.dir/build
make[1]: Entering directory '/tmp/makepkg/bambustudio-git/src/BambuStudio/deps/build/CMakeFiles/CMakeScratch/TryCompile-c94XFe'
Building C object CMakeFiles/cmTC_b88fe.dir/testCCompiler.c.o
/usr/bin/gcc-13 -march=native -O2 -pipe -flto=auto -o CMakeFiles/cmTC_b88fe.dir/testCCompiler.c.o -c /tmp/makepkg/bambustudio-git/src/BambuStudio/deps/build/CMakeFiles/CMakeScratch/TryCompile-c94XFe/testCCompiler.c
Linking C executable cmTC_b88fe
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_b88fe.dir/link.txt --verbose=1
/usr/bin/gcc-13 -march=native -O2 -pipe -flto=auto ... -fuse-ld=mold -flto=auto -rdynamic CMakeFiles/cmTC_b88fe.dir/testCCompiler.c.o -o cmTC_b88fe
mold: fatal: cannot open ...: No such file or directory
collect2: error: ld returned 1 exit status
make[1]: *** [CMakeFiles/cmTC_b88fe.dir/build.make:99: cmTC_b88fe] Error 1
make[1]: Leaving directory '/tmp/makepkg/bambustudio-git/src/BambuStudio/deps/build/CMakeFiles/CMakeScratch/TryCompile-c94XFe'
make: *** [Makefile:127: cmTC_b88fe/fast] Error 2
CMake will not be able to correctly generate this project.
Call Stack (most recent call first):
-- Configuring incomplete, errors occurred!
==> ERROR: A failure occurred in build().
Aborting...
-> error making: bambustudio-git-exit status 4
-> Failed to install the following packages. Manual intervention is required:
bambustudio-git - exit status 4
I assume the issue is the mold command cannot understand “…” (Variadic directory listing?)
