Hi,
I got an update from AUR with the command pamac update --aur
and got this message:
Preparing...
Cloning yay-bin build files...
Checking yay-bin dependencies...
Warning: removing pacman breaks dependency 'pacman>=5.2' required by alpm-octopi-utils
Add alpm-octopi-utils to remove
Warning: removing pacman breaks dependency 'pacman<5.3' required by alpm-octopi-utils
Warning: removing pacman breaks dependency 'pacman' required by appstream-glib
Add appstream-glib to remove
Warning: removing pacman breaks dependency 'pacman' required by expac
Add expac to remove
Warning: removing pacman breaks dependency 'pacman>=5.0' required by manjaro-system
Add manjaro-system to remove
Warning: removing pacman breaks dependency 'pacman' required by mhwd
Add mhwd to remove
Warning: removing pacman breaks dependency 'pacman>=5.2' required by octopi
Add octopi to remove
Warning: removing pacman breaks dependency 'pacman<5.3' required by octopi
Warning: removing pacman breaks dependency 'pacman>=5.2' required by pamac-common
Add pamac-common to remove
Warning: removing pacman breaks dependency 'pacman<5.3' required by pamac-common
Warning: removing pacman breaks dependency 'pacman' required by pkgfile
Add pkgfile to remove
Error: Failed to prepare transaction:
could not satisfy dependencies:
- removing octopi breaks dependency 'octopi' required by octopi-notifier-frameworks,
- if possible, remove octopi-notifier-frameworks and retry
- removing pamac-common breaks dependency 'pamac-common=10.0.6-2' required by pamac-cli,
- if possible, remove pamac-cli and retry
Warning: python-pulsectl: local (1:20.5.1-2) is newer than community (21.5.18-1)
Warning: sndio: local (20180120-1) is newer than community (1.7.0-3)
Resolving dependencies...
Checking inter-conflicts...
Not sure how to update correctly. For now, I am just ignoring this with `/etc/pacman.conf but want to update to latest as before. Could someone help me with that?
Thanks for reading,
Stanislav
