Skiexx
16 November 2022 14:17
1
Не работает yay.
При попытке выполнения команды
yay -S yandex-music-player
выкидывает ошибку
:: Проверка конфликтов...
:: Проверка внутренних конфликтов...
[Repo:1] electron17-17.4.11-3
[Repo Make:5] nodejs-19.0.1-1 nodejs-nopt-7.0.0-1 semver-7.3.8-1 node-gyp-9.3.0-1 npm-8.19.2-1
[Aur:1] yandex-music-player-1.4.2-1
:: Удалить зависимости для сборки после установки? [y/N] y
:: (0/1) Скачан PKGBUILD: yandex-music-player
ошибка: не найдена цель: nodejs
ошибка: не найдена цель: nodejs-nopt
ошибка: не найдена цель: semver
ошибка: не найдена цель: node-gyp
ошибка: не найдена цель: npm
-> ошибка получения yandex-music-player: Клонирование в «yandex-music-player»...
fatal: unable to connect to aur.archlinux.org:
aur.archlinux.org[0: 95.216.144.15]: errno=Нет маршрута до узла
aur.archlinux.org[1: 2a01:4f9:c010:50::1]: errno=Сеть недоступна
context: exit status 128
Hi @Skiexx , and welcome!
Please note:
I do not speak Russian, and used Google translate to understand your message.
Although, this
…clearly shows I needn’t have bothered.
The problem isn’t yay, per sé. Yay is only displaying a symptom of the problem, which is that it is unable to access aur.archlinux.org . So my next question is, can you access the aur.archlinux.org website in your browser? And to please provide the output of:
LC_ALL=C ping -c 4 manjaro.org
Hope this makes sense to you in Russian. Google Translated version here .
Skiexx
22 November 2022 11:00
3
I can access to aur.archlinux.org
output below
$ LC_ALL=C ping -c 4 manjaro.org
PING manjaro.org (116.203.91.91) 56(84) bytes of data.
64 bytes from mail.manjaro.org (116.203.91.91): icmp_seq=1 ttl=41 time=91.1 ms
64 bytes from mail.manjaro.org (116.203.91.91): icmp_seq=2 ttl=41 time=90.7 ms
64 bytes from mail.manjaro.org (116.203.91.91): icmp_seq=3 ttl=41 time=90.7 ms
64 bytes from mail.manjaro.org (116.203.91.91): icmp_seq=4 ttl=41 time=90.7 ms
--- manjaro.org ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3004ms
rtt min/avg/max/mdev = 90.689/90.806/91.104/0.172 ms
Skiexx
22 November 2022 15:00
4
Проблема была решена простой переустановкой системы.
Теперь все работает
Причина почему отвалилась неизвестна.
Now all work correctly
system
Closed
25 November 2022 05:01
5
