Hey all!
recently my computer display has been consistantly crashing. I will be working on something and suddenly my display will stop working and turn immediatly off, but sound works during this fiasco. Help would be appreciated.
Specs
Inspiron 3785
GPU: AMD Radeon Vega 8
CPU: AMD Ryzen 5 2500u
Sounds like the graphics driver is crashing. Can you please post the output of
inxi -v1z
Sure
OUTPUT:
System: Kernel: 5.12.9-1-MANJARO x86_64 bits: 64 Desktop: i3 4.19.1 Distro: Manjaro Linux
CPU: Info: Quad Core AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx [MT MCP] speed: 2383 MHz min/max: 1600/2000 MHz
Graphics: Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series] driver: amdgpu v: kernel
Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
Display: x11 server: X.Org 1.20.11 driver: loaded: amdgpu,ati unloaded: modesetting resolution: 1600x900~60Hz
OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.40.0 5.12.9-1-MANJARO LLVM 12.0.0) v: 4.6 Mesa 21.1.2
Drives: Local Storage: total: 931.51 GiB used: 73.73 GiB (7.9%)
Info: Processes: 332 Uptime: 1d 2h 26m Memory: 13.62 GiB used: 3.45 GiB (25.3%) Shell: fish inxi: 3.3.04
Fabby
8 July 2021 07:11
4
First port of call on an AMD driver problem is trying at least one of the LTS kernels: 5.4 LTS and 5.10 LTS.
Unfortunatly it still crashes
I tried Kernel 5.10
Would wiping my system and reinstalling fix anything?
Fabby
8 July 2021 15:49
8
Probably not.
Next time this happens, please:
Crashed again
OUTPUT:
Kernel: 5.10.42-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=e978d5bb-af99-49bd-9fb9-5e16e96ebdad rw apparmor=1
security=apparmor resume=UUID=c004ee4b-ffd3-4764-94cc-d5c34b95aebf
udev.log_priority=3 sysrq_always_enabled=1
Desktop: i3 4.19.1 info: i3bar vt: 7 dm: LightDM 1.30.0
Type: Laptop System: Dell product: Inspiron 3785 v: 1.4.0 serial: <filter>
Chassis: type: 10 v: 1.4.0 serial: <filter>
Mobo: Dell model: 0VY1RG v: X01 serial: <filter> UEFI: Dell v: 1.4.0
date: 05/29/2019
ID-1: BAT1 charge: 33.7 Wh (100.0%) condition: 33.7/42.0 Wh (80.2%)
volts: 12.7 min: 11.4 model: Simplo 0x32,0x39,0x37,0x55,0x00,0x00,0x0006
type: Li-ion serial: <filter> status: Full
RAM: total: 13.62 GiB used: 2.21 GiB (16.2%)
Array-1: capacity: 128 GiB note: check slots: 2 EC: None
max-module-size: 64 GiB note: est.
Device-1: DIMM A size: 8 GiB speed: spec: 2667 MT/s actual: 2400 MT/s
type: DDR4 detail: synchronous unbuffered (unregistered) bus-width: 64 bits
total: 64 bits manufacturer: 859B0000802C part-no: CT8G4SFS8266.C8FD1
serial: <filter>
Device-2: DIMM B size: 8 GiB speed: spec: 2667 MT/s actual: 2400 MT/s
serial: <filter>
Info: Quad Core model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx
socket: FP5 bits: 64 type: MT MCP arch: Zen family: 17 (23)
model-id: 11 (17) stepping: 0 microcode: 810100B cache: L1: 384 KiB
L2: 2 MiB L3: 4 MiB bogomips: 31954
Speed: 1368 MHz min/max: 1600/2000 MHz base/boost: 2000/2000 boost: enabled
volts: 1.2 V ext-clock: 100 MHz Core speeds (MHz): 1: 1368 2: 1368 3: 1369
4: 1351 5: 1372 6: 1371 7: 1522 8: 1394
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
disabled, RSB filling
vendor: Dell driver: amdgpu v: kernel bus-ID: 03:00.0 chip-ID: 1002:15dd
class-ID: 0300
bus-ID: 1-4:2 chip-ID: 0c45:671e class-ID: 0e02
Display: x11 server: X.Org 1.20.11 compositor: picom v: git-dac85 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.7x9.4")
s-diag: 485mm (19.1")
Monitor-1: eDP res: 1600x900 hz: 60 dpi: 106 size: 382x214mm (15.0x8.4")
diag: 438mm (17.2")
5.10.42-1-MANJARO LLVM 12.0.0)
v: 4.6 Mesa 21.1.2 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 03:00.1 chip-ID: 1002:15de
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.10.42-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.30 running: no
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel port: 2000 bus-ID: 01:00.0 chip-ID: 10ec:8136
class-ID: 0200
IF: enp1s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Dell driver: ath10k_pci v: kernel port: 2000 bus-ID: 02:00.0
chip-ID: 168c:0042 class-ID: 0280
IF: wlp2s0 state: down mac: <filter>
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 3-2.4:5
chip-ID: 0cf3:e009 class-ID: e001
Local Storage: total: 931.51 GiB used: 78.61 GiB (8.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000BX500SSD1
family: Micron Client SSDs size: 931.51 GiB block-size: physical: 512 B
logical: 512 B sata: 3.3 speed: 6.0 Gb/s rotation: SSD serial: <filter>
rev: 030 temp: 24 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 152d 19h cycles: 783
written: 4.95 TiB
Optical-1: /dev/sr0 vendor: PLDS model: DVD+-RW DU-8A5LH rev: 6D1M
dev-links: cdrom
rw: cd-r,cd-rw,dvd-r state: running
ID-1: / raw-size: 916.23 GiB size: 900.78 GiB (98.31%)
used: 78.61 GiB (8.7%) fs: ext4 block-size: 4096 B dev: /dev/sda2
maj-min: 8:2 label: N/A uuid: e978d5bb-af99-49bd-9fb9-5e16e96ebdad
used: 296 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
label: NO_LABEL uuid: 1C05-6E76
ID-1: swap-1 type: partition size: 14.99 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: c004ee4b-ffd3-4764-94cc-d5c34b95aebf
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 1-4:2 info: Microdia Integrated_Webcam_HD type: Video
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Device-1: 3-1:2 info: Logitech G502 SE HERO Gaming Mouse type: Mouse,HID
power: 300mA chip-ID: 046d:c08b class-ID: 0300 serial: <filter>
Hub-4: 3-2:3 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 3-2.1:4 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Device-2: 3-2.4:5 info: Qualcomm Atheros type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 0cf3:e009
class-ID: e001
Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 74.2 C mobo: 0 C gpu: amdgpu temp: 74.0 C
Fan Speeds (RPM): fan-1: 0
Processes: 300 Uptime: 2m wakeups: 1 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 Packages: 1367 pacman: 1340 lib: 332 flatpak: 10
snap: 17 Shell: Bash (su) v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.04
-- Journal begins at Sun 2021-06-06 13:24:49 CDT, ends at Sat 2021-07-10 00:46:30 CDT. --
-- No entries --
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.10.42-1-MANJARO] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Crucial/Micron Client SSDs
Device Model: CT1000BX500SSD1
Serial Number: 2012E295DEAD
LU WWN Device Id: 5 00a075 1e295dead
Firmware Version: M6CR030
User Capacity: 1,000,204,886,016 bytes [1.00 TB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
Form Factor: 2.5 inches
TRIM Command: Available
Device is: In smartctl database [for details use: -P show]
ATA Version is: ACS-3 T13/2161-D revision 4
SATA Version is: SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sat Jul 10 00:46:31 2021 CDT
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 120) seconds.
capabilities: (0x11) SMART execute Offline immediate.
No Auto Offline data collection support.
Suspend Offline collection upon new
command.
No Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
No Selective Self-test supported.
SMART capabilities: (0x0002) Does not save SMART data before
entering power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 10) minutes.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 100 100 000 Pre-fail Always - 0
5 Reallocate_NAND_Blk_Cnt 0x0032 100 100 010 Old_age Always - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 3667
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 783
171 Program_Fail_Count 0x0032 100 100 000 Old_age Always - 0
172 Erase_Fail_Count 0x0032 100 100 000 Old_age Always - 0
173 Ave_Block-Erase_Count 0x0032 099 099 000 Old_age Always - 26
174 Unexpect_Power_Loss_Ct 0x0032 100 100 000 Old_age Always - 709
180 Unused_Reserve_NAND_Blk 0x0033 100 100 000 Pre-fail Always - 9
183 SATA_Interfac_Downshift 0x0032 100 100 000 Old_age Always - 0
184 Error_Correction_Count 0x0032 100 100 000 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
194 Temperature_Celsius 0x0022 076 051 000 Old_age Always - 24 (Min/Max 11/49)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_ECC_Cnt 0x0032 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 100 100 000 Old_age Always - 0
202 Percent_Lifetime_Remain 0x0030 099 099 001 Old_age Offline - 1
206 Write_Error_Rate 0x000e 100 100 000 Old_age Always - 0
210 Success_RAIN_Recov_Cnt 0x0032 100 100 000 Old_age Always - 0
246 Total_LBAs_Written 0x0032 100 100 000 Old_age Always - 10627963360
247 Host_Program_Page_Count 0x0032 100 100 000 Old_age Always - 332123855
248 FTL_Program_Page_Count 0x0032 100 100 000 Old_age Always - 367783136
249 Unkn_CrucialMicron_Attr 0x0032 100 100 000 Old_age Always - 0
250 Read_Error_Retry_Rate 0x0032 100 100 000 Old_age Always - 96218
251 Unkn_CrucialMicron_Attr 0x0032 100 100 000 Old_age Always - 0
252 Unkn_CrucialMicron_Attr 0x0032 100 100 000 Old_age Always - 0
253 Unkn_CrucialMicron_Attr 0x0032 100 100 000 Old_age Always - 12
254 Unkn_CrucialMicron_Attr 0x0032 100 100 000 Old_age Always - 814
223 Unkn_CrucialMicron_Attr 0x0032 100 100 000 Old_age Always - 5
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed without error 00% 2677 -
# 2 Extended offline Completed without error 00% 2677 -
# 3 Extended offline Completed without error 00% 14 -
# 4 Extended offline Self-test routine in progress 90% 14 -
# 5 Short offline Completed without error 00% 14 -
# 6 Short offline Self-test routine in progress 70% 14 -
# 7 Short offline Aborted by host 90% 14 -
# 8 Short offline Aborted by host 90% 14 -
# 9 Short offline Aborted by host 90% 11 -
#10 Short offline Completed without error 00% 11 -
#11 Short offline Self-test routine in progress 40% 11 -
#12 Short offline Aborted by host 90% 11 -
Selective Self-tests/Logging not supported
Any updates from dell requires Windows
I will try 5.4
OUTPUT:
Jul 10 00:42:06 inspiron3785 kernel: amdgpu 0000:03:00.0: amdgpu: RW: 0x1
Jul 10 00:42:06 inspiron3785 kernel: amdgpu 0000:03:00.0: amdgpu: [gfxhub0] retry page fault (src_id:0 ring:0 vmid:5 pasid:32769, for process Xorg pid 822 thread Xorg:cs0 pid 1001)
Jul 10 00:42:06 inspiron3785 kernel: amdgpu 0000:03:00.0: amdgpu: in page starting at address 0x000080010127b000 from client 27
Jul 10 00:42:06 inspiron3785 kernel: amdgpu 0000:03:00.0: amdgpu: VM_L2_PROTECTION_FAULT_STATUS:0x005C0071
Jul 10 00:42:06 inspiron3785 kernel: amdgpu 0000:03:00.0: amdgpu: Faulty UTCL2 client ID: CB (0x0)
Jul 10 00:42:06 inspiron3785 kernel: amdgpu 0000:03:00.0: amdgpu: MORE_FAULTS: 0x1
Jul 10 00:42:06 inspiron3785 kernel: amdgpu 0000:03:00.0: amdgpu: WALKER_ERROR: 0x0
Jul 10 00:42:06 inspiron3785 kernel: amdgpu 0000:03:00.0: amdgpu: PERMISSION_FAULTS: 0x7
Jul 10 00:42:06 inspiron3785 kernel: amdgpu 0000:03:00.0: amdgpu: MAPPING_ERROR: 0x0
Jul 10 00:42:06 inspiron3785 kernel: amdgpu 0000:03:00.0: amdgpu: in page starting at address 0x000080010127d000 from client 27
Jul 10 00:42:10 inspiron3785 kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring gfx timeout, signaled seq=15181772, emitted seq=15181775
Jul 10 00:42:10 inspiron3785 kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process Xorg pid 822 thread Xorg:cs0 pid 1001
Jul 10 00:42:10 inspiron3785 kernel: amdgpu 0000:03:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0000 address=0x116a40000 flags=0x0070]
Jul 10 00:42:10 inspiron3785 kernel: amdgpu 0000:03:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0000 address=0x116a0c340 flags=0x0070]
Jul 10 00:42:10 inspiron3785 kernel: amdgpu 0000:03:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0000 address=0x116a0c380 flags=0x0070]
Jul 10 00:42:10 inspiron3785 kernel: amdgpu 0000:03:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0000 address=0x116a0c3a0 flags=0x0070]
Jul 10 00:42:10 inspiron3785 kernel: amdgpu 0000:03:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0000 address=0x116a0c3c0 flags=0x0070]
Jul 10 00:42:10 inspiron3785 kernel: amdgpu 0000:03:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0000 address=0x116a0c3e0 flags=0x0070]
Jul 10 00:42:10 inspiron3785 kernel: amdgpu 0000:03:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0000 address=0x116a0c400 flags=0x0070]
Jul 10 00:42:10 inspiron3785 kernel: amdgpu 0000:03:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0000 address=0x116a0c420 flags=0x0070]
Jul 10 00:42:10 inspiron3785 kernel: amdgpu 0000:03:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0000 address=0x116a0c440 flags=0x0070]
Jul 10 00:42:10 inspiron3785 kernel: amdgpu 0000:03:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0000 address=0x116a0c460 flags=0x0070]
Jul 10 00:42:12 inspiron3785 kernel: amdgpu 0000:03:00.0: [drm:amdgpu_ring_test_helper [amdgpu]] *ERROR* ring gfx test failed (-110)
Jul 10 00:42:12 inspiron3785 kernel: [drm:amdgpu_device_ip_resume_phase2 [amdgpu]] *ERROR* resume of IP block <gfx_v9_0> failed -110
Jul 10 00:42:22 inspiron3785 kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring gfx timeout, but soft recovered
Jul 10 00:42:32 inspiron3785 kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring gfx timeout, but soft recovered
5.4 caused my internet browser to crash, vivaldi, so I switched back to 5.12 would the experimental 5.13 fix anything?
Try adding iommu=pt to your kernel parameters. According to this , adding iommu=pt to your kernel parameters has solved the issue for others who are using similar hardware on the 5.4 and 5.10 kernels. It is likely that this has not been addressed on the 5.12 and 5.13 kernels, but Iâm not totally sure. On that note, I believe that 5.13 in Manjaro is still not on the stable branch; at least it wasnât a few days ago.
EDIT: What are you doing when this happenes? The log entry
seems to indicate you are resuming from hibernation or suspend?
I do use the suspend feature so that I can save battery life, is this what is causing my gpu to crash?!
It is one possible reason that came up when I was googling around for solutions. Another idea that was floated was adding amdgpu.noretry=0 the the kernel parameters and reboot, which may also help in this instance, but that would depend if your crash is happening at about the time you come out of suspend. As a test, you could try disabling suspend and just shutting down (kind of a pain) to see if the crash continues to happen.
It crashes randomly, when I come out of suspend when I am just messing around or googling.
Then iommu=pt seems to be the one solution that seems to match your issue. I will continue to look around and see if I can find anything else. On the subject of BIOS, I would also see if there is an update. Iâm not sure your Inspiron 3785 works like my XPS where you can drop the .exe you download from Dell onto a thumb drive and update directly from the Support Assist / Boot selection menu.
