I haven’t been able to get “WebCollage” (a screensaver in the XScreenSaver collection) to work on any Manjaro computer; they all give the error in my title. Is there some prerequisite? (With some of the other screensavers, there is. Eg, “Sonar” needs “sudo chmod u+s sonar” and MapScroller needs 5 CPAN modules installed.)
Not sure if you already are, but it could be worth running xscreensaver in a terminal rather than launching it as normal. That might give some useful diagnostics.
And with a lot of its modules being written in Perl, you should be able to examine the source to work out what’s going wrong (I had a situation a while ago when Manjaro upgraded to a newer version of Perl than the developer had and broke it; I was able to dig into the code and tell him what the necessary fix was).
Experimenting in a VM I got a few clues when I ran the demo from a terminal:
xscreensaver-demo
First it complained about a wordlist not being available - installed “words
Next was:
webcollage: 11:00:50: init: xwininfo not found on $PATH.
so I installed xorg-xwininfo
and then, after some time, random pictures slowly started to appear, gradually filling the screen.
kinda cool …
HTH
