My xrandr output
Screen 0: minimum 8 x 8, current 1600 x 900, maximum 32767 x 32767
DP1 disconnected (normal left inverted right x axis y axis)
DP2 disconnected (normal left inverted right x axis y axis)
DP3 connected primary 1600x900+0+0 (normal left inverted right x axis y axis) 440mm x 240mm
1600x900 60.00*+
1280x1024 60.02
1440x900 59.90
1280x800 59.91
1280x720 60.00 50.00 59.94
1024x768 60.00
800x600 60.32
720x576 50.00
720x480 60.00 59.94
640x480 60.00 59.94
720x400 70.08
HDMI1 disconnected (normal left inverted right x axis y axis)
HDMI2 disconnected (normal left inverted right x axis y axis)
VIRTUAL1 disconnected (normal left inverted right x axis y axis
here is my inxi
System: Kernel: 5.13.11-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: KDE Plasma 5.22.4 Distro: Manjaro Linux
base: Arch Linux
Machine: Type: Desktop System: HP product: HP ProDesk 600 G5 PCI MT v: N/A serial: <filter>
Mobo: HP model: 861A v: KBC Version 08.97.00 serial: <filter> UEFI: HP v: R02 Ver. 02.05.01 date: 04/27/2020
CPU: Info: 6-Core model: Intel Core i5-9500 bits: 64 type: MCP arch: Kaby Lake note: check rev: A cache: L2: 9 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 36012
Speed: 800 MHz min/max: 800/4400 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800
Graphics: Device-1: Intel CometLake-S GT2 [UHD Graphics 630] vendor: Hewlett-Packard driver: i915 v: kernel bus-ID: 00:02.0
Display: x11 server: X.Org 1.20.13 driver: loaded: intel unloaded: modesetting resolution: 1600x900~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.1.6 direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
Sound Server-1: ALSA v: k5.13.11-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: yes
Network: Device-1: Intel Ethernet I219-LM vendor: Hewlett-Packard driver: e1000e v: kernel port: efa0 bus-ID: 00:1f.6
Device-2: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter vendor: Hewlett-Packard driver: rtw_8822be v: N/A
port: 3000 bus-ID: 01:00.0
IF: wlp1s0 state: down mac: <filter>
Bluetooth: Device-1: Realtek Realtek Bluetooth 4.2 Adapter type: USB driver: btusb v: 0.8 bus-ID: 1-14:4
Drives: Local Storage: total: 1.03 TiB used: 7.43 GiB (0.7%)
ID-1: /dev/sda vendor: TEUTONS model: SSD 128GB size: 119.24 GiB
ID-2: /dev/sdb vendor: Seagate model: ST1000DM003-1SB102 size: 931.51 GiB
Partition: ID-1: / size: 116.52 GiB used: 7.43 GiB (6.4%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1
Swap: Alert: No swap data was found.
Sensors: System Temperatures: cpu: 37.0 C mobo: N/A
Info: Processes: 224 Uptime: 33m Memory: 14.86 GiB used: 2.73 GiB (18.4%) Init: systemd Compilers: gcc: N/A
