Hey there,
I’m using manjaro i3 21.0.4 and my second monitor is not being detected as connected by xrandr (when infact it is). I know for a fact that there are no issues with my monitors or cables because I just tested them with windows 10 and elementary os 6 odin and both monitors are detected and work flawlessly.
I can’t seem to figure out why it works on another linux distro and not on manjaro. They’re both relatively new versions so I’m stumped.
I’m using an iGPU (with no discrete GPU), intel i5-11500 specifically. This CPU uses intel UHD graphics 750.
I seem to have the exact same issue as this user but no one has responded to their post yet:
https://www.reddit.com/r/ManjaroLinux/comments/s9j77q/dual_monitors_not_working_onboard_graphics_no_gpu/
(i can’t post links)
notes:
- i’ve looked at a bunch of articles online but can’t find a solution that works for me. most are in reference to systems that use nvidia for graphics.
- i also dont have a
xorg.confin/etc/X11/for some reason
xrandr -q
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 16384 x 16384
HDMI-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 480mm x 270mm
1920x1080 60.00*+ 50.00 59.94
1920x1080i 60.00 50.00 59.94
1680x1050 59.88
1400x1050 59.95
1600x900 60.00
1280x1024 75.02 60.02
1440x900 59.90
1280x800 59.91
1152x864 75.00
1280x720 60.00 50.00 59.94
1024x768 75.03 60.00
800x600 75.00 60.32
720x576 50.00
720x480 60.00 59.94
640x480 75.00 60.00 59.94
720x400 70.08
HDMI-2 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
HDMI-3 disconnected (normal left inverted right x axis y axis)
inxi -Fayz
Kernel: 5.11.22-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64
root=UUID=2623d0c2-c56e-4f28-b7e5-1686604c8f69 rw quiet apparmor=1
Desktop: i3 4.20.1 info: polybar dm: LightDM 1.30.0 Distro: Manjaro Linux
base: Arch Linux
Type: Desktop System: ASUS product: N/A v: N/A serial: N/A
Mobo: ASUSTeK model: PRIME B560M-A v: Rev 1.xx serial: <filter>
UEFI: American Megatrends v: 0820 date: 04/27/2021
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K330
serial: <filter> charge: 10% (should be ignored) rechargeable: yes
status: Discharging
Info: model: 11th Gen Intel Core i5-11500 socket: LGA1200 bits: 64
type: MT MCP arch: Rocket Lake family: 6 model-id: 0xA7 (167) stepping: 1
microcode: 0x40
L1: 480 KiB desc: d-6x48 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 800 high: 801 min/max: 800/4600 base/boost: 2673/4600
scaling: driver: intel_pstate governor: powersave volts: 0.8 V
ext-clock: 100 MHz cores: 1: 800 2: 800 3: 800 4: 801 5: 800 6: 800 7: 800
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 65112
Device-1: Intel RocketLake-S GT1 [UHD Graphics 750] vendor: ASUSTeK
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:4c8a class-ID: 0300
Device-2: Microdia USB 2.0 Camera type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-10.2:9 chip-ID: 0c45:636b class-ID: 0102 serial: <filter>
Display: server: X.Org 1.21.1.3 driver: loaded: modesetting
alternate: fbdev,vesa display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: HDMI-1 res: 1920x1080 hz: 60 dpi: 102
size: 480x270mm (18.9x10.6") diag: 551mm (21.7")
OpenGL: renderer: Mesa Intel Graphics (RKL GT1) v: 4.6 Mesa 21.3.4
direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_sof_pci bus-ID: 00:1f.3 chip-ID: 8086:43c8
class-ID: 0403
Sound Server-1: ALSA v: k5.11.22-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.43 running: no
Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15fa class-ID: 0200
IF-ID-1: virbr0 state: down mac: <filter>
Local Storage: total: 2.04 TiB used: 874.86 GiB (41.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
family: BarraCuda 3.5 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: HDD rpm: 7200
serial: <filter> rev: 0001 temp: 33 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 65d 22h cycles: 308
read: 3.38 TiB written: 3.81 TiB Pre-Fail: attribute: Spin_Retry_Count
value: 100 worst: 100 threshold: 97
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37240G
family: Driven SSDs size: 223.57 GiB block-size: physical: 512 B
logical: 512 B sata: 3.2 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: J4.3 temp: 27 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 65d 18h cycles: 310
read: 1077 GiB written: 2824 GiB
ID-1: / raw-size: 64.59 GiB size: 63.02 GiB (97.58%) used: 44.36 GiB (70.4%)
fs: ext4 block-size: 4096 B dev: /dev/sdb5 maj-min: 8:21
used: 25.3 MiB (26.3%) fs: vfat block-size: 512 B dev: /dev/sdb1
maj-min: 8:17
System Temperatures: cpu: 27.8 C mobo: N/A
Processes: 349 Uptime: 1d 8h 50m wakeups: 89 Memory: 14.48 GiB
used: 9.24 GiB (63.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1408 lib: 412 Shell: Bash (sudo)
v: 5.1.16 running-in: sakura inxi: 3.3.12
