Xrandr: Failed to get size of gamma for output default
i cant change resolution to 1360x768 its stuck at 1024x768
my graphics card is NVIDIA Corporation GF116 [GeForce GTS 450 Rev. 2] (rev a1)
when i try to add a 1360x768 resolution with command: xrandr --newmode "1360x768_60.00" 84.75 1360 1432 1568 1776 768 771 781 798 -hsync +vsync
it says: xrandr: Failed to get size of gamma for output default X Error of failed request: BadName (named color or font does not exist) Major opcode of failed request: 140 (RANDR) Minor opcode of failed request: 16 (RRCreateMode) Serial number of failed request: 19
and my monitor is a FLATRON W1941S if that helps
pls help me idk what to do
Hi,
There is another topic very similar to yours and with almost the same content
Good luck!
T+ = See you later
