I recently got an issue with my Dell XPS 15 9560, where the brightness buttons (located on F11 and F12) and the power button doesn’t work until I either turn off the display or put the laptop to sleep by closing the lid or using the sleep combination FN+Insert.
Here are two journalctl logs from before and after doing the trick/workaround.
I tried reinstalling all packages found on the minimal live iso, but no luck so far.
I also tried upgrading to the 5.13 kernel, in case that would solve it, without success.
I fixed the issue, I cannot say with 100% guarantee that this is the fix, but I was messing around with the xorg config lately.
I regenerated the xorg config with Xorg :2 --configure in a separate TTY screen and used that config under /etc/X11/xorg.conf.
The brightness and power buttons work again.
