Kernel: 5.8.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=040667ae-b535-489b-abf9-8a9e9a8471a1 rw quiet apparmor=1
security=apparmor resume=UUID=1a54697c-a4de-4b73-a7fd-c4c995279971
udev.log_priority=3
Console: tty 0 wm: gnome-shell DM: GDM 3.38.1 Distro: Manjaro Linux
Type: Laptop System: Dell product: XPS 13 9300 v: N/A serial:
Chassis: type: 10 serial:
Mobo: Dell model: 077Y9N v: A00 serial: UEFI: Dell v: 1.2.0
date: 08/13/2020
ID-1: BAT0 charge: 50.2 Wh condition: 50.2/51.0 Wh (98%) volts: 8.6/7.6
model: LGC-LGC6.5 DELL 2XXFW05 type: Li-poly serial: status: Full
Info: Quad Core model: Intel Core i7-1065G7 bits: 64 type: MT MCP
arch: Ice Lake family: 6 model-id: 7E (126) stepping: 5 microcode: 96
L2 cache: 8192 KiB
bogomips: 23968
Speed: 1453 MHz min/max: 400/3900 MHz base/boost: 1400/1500 volts: 0.7 V
ext-clock: 100 MHz Core speeds (MHz): 1: 1400 2: 1401 3: 1256 4: 1400
5: 1400 6: 1401 7: 1083 8: 1400
Device-1: Intel Iris Plus Graphics G7 vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:8a52
Device-2: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus ID: 3-9:3 chip ID: 0bda:58fe serial:
Display: server: X . org 1.20.9 compositor: gnome-shell driver: i915
note: display driver n/a FAILED: intel unloaded: modesetting
alternate: fbdev,vesa resolution:
OpenGL: renderer: Mesa Intel Iris Plus Graphics (ICL GT2) v: 4.6 Mesa 20.2.1
direct render: Yes
Device-1: Intel Smart Sound Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:34c8
Device-2: Realtek type: USB driver: snd-usb-audio bus ID: 5-2.3.4:6
chip ID: 0bda:402e serial:
Sound Server: ALSA v: k5.8.18-1-MANJARO
Device-1: Intel Killer Wi-Fi 6 AX1650i 160MHz Wireless Network Adapter
vendor: Bigfoot Networks driver: iwlwifi v: kernel port: 4000
bus ID: 00:14.3 chip ID: 8086:34f0
IF: wlp0s20f3 state: up mac:
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus ID: 6-2.4:4 chip ID: 0bda:8153 serial:
IF: enp46s0u2u4 state: up speed: 1000 Mbps duplex: full mac:
Local Storage: total: 476.94 GiB used: 122.62 GiB (25.7%)
ID-1: /dev/nvme0n1 model: KXG60ZNV512G NVMe KIOXIA 512GB size: 476.94 GiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
serial: rev: 10604107 scheme: GPT
ID-1: / raw size: 468.43 GiB size: 460.08 GiB (98.22%)
used: 122.61 GiB (26.6%) fs: ext4 block size: 4096 B dev: /dev/nvme0n1p3
ID-1: swap-1 type: partition size: 8.00 GiB used: 12.5 MiB (0.2%)
priority: -2 dev: /dev/nvme0n1p2
System Temperatures: cpu: 48.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0 fan-2: 0
Processes: 323 Uptime: 49m Memory: 15.23 GiB used: 3.24 GiB (21.3%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1391 lib: 435
flatpak: 0 Shell: Zsh (sudo) v: 5.8 default: Bash v: 5.0.18
running in: gnome-terminal inxi: 3.1.08
