Hi.
In the last update I the kernel 5.9 was installed and after that (and many other) update(s) I was not able to open any program via gui.
The error:
Cannot open display :0
I need to ctrl+alt+f4 and restart X via command line to make it work:
pkill -x X && startx
I do use a external monitor.
I downgraded to kernel 5.4, issue continues.
I have no clue of whats going on, any help please?
Kernel: 5.4.101-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=ee1db449-6r35-4f3f-8br5-d4ecxc7c0pbf rw quiet udev.log_priority=3
Desktop: KDE Plasma 5.21.2 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 23501M2 v: ThinkPad T430
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 23501M2 serial: <filter> UEFI: LENOVO
v: G1ETC2WW (2.82 ) date: 08/07/2019
ID-1: BAT0 charge: 43.6 Wh condition: 51.2/85.9 Wh (58%) volts: 11.5/10.8
model: SANYO XXXXXX type: Li-ion serial: <filter> status: Discharging
Info: Dual Core model: Intel Core i5-3320M bits: 64 type: MT MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
L2 cache: 3 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 20760
Speed: 1197 MHz min/max: 1200/3300 MHz Core speeds (MHz): 1: 1197 2: 1197
3: 1197 4: 1198
Type: l1tf
Type: srbds status: Vulnerable: No microcode
Device-1: Intel 3rd Gen Core processor Graphics vendor: Lenovo driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:0166 class ID: 0300
Device-2: Chicony thinkpad t430s camera type: USB driver: uvcvideo
bus ID: 1-1.6:4 chip ID: 04f2:b2da class ID: 0e02
Display: server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: intel
unloaded: modesetting alternate: fbdev,vesa display ID: :2 screens: 1
Screen-1: 0 s-res: 3520x1080 s-dpi: 96 s-size: 930x285mm (36.6x11.2")
s-diag: 973mm (38.3")
Monitor-1: LVDS1 res: 1600x900 hz: 60 dpi: 131 size: 310x170mm (12.2x6.7")
diag: 354mm (13.9")
Monitor-2: DP1 res: 1920x1080 hz: 60 dpi: 81 size: 600x340mm (23.6x13.4")
diag: 690mm (27.2")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 20.3.4 compat-v: 3.0 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1e20
class ID: 0403
Device-2: Logitech Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-1.2:3 chip ID: 046d:0a44
class ID: 0300
Sound Server: ALSA v: k5.4.101-1-MANJARO
Device-1: Intel 82500LM Gigabit Network vendor: Lenovo driver: e1000e
v: 3.2.6-k port: 6080 bus ID: 00:19.0 chip ID: 8086:1502 class ID: 0200
IF: enp0s25 state: down mac: <filter>
Device-2: Intel Centrino Advanced-N 8205 [Taylor Peak] driver: iwlwifi
v: kernel port: efa0 bus ID: 03:00.0 chip ID: 8086:0085 class ID: 0280
Local Storage: total: 335.37 GiB used: 109.13 GiB (31.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 120 GB
size: 111.8 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 00RL scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SUV500MS240G
size: 223.57 GiB block size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
rotation: SSD serial: <filter> rev: 56RI scheme: GPT
ID-1: / raw size: 100.12 GiB size: 98.05 GiB (97.93%)
used: 19.46 GiB (19.8%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
ID-2: /boot/efi raw size: 512 MiB size: 511 MiB (99.80%)
used: 332 KiB (0.1%) fs: vfat dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw size: 120 GiB size: 117.62 GiB (98.01%)
used: 109.67 GiB (93.2%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17
ID-1: swap-1 type: partition size: 3 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda5 maj-min: 8:5
System Temperatures: cpu: 52.0 C mobo: 0.0 C
Fan Speeds (RPM): cpu: 3635
Processes: 242 Uptime: 24m wakeups: 1 Memory: 11.53 GiB
used: 3.54 GiB (30.7%) Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages:
pacman: 1200 lib: 354 Shell: Zsh v: 5.8 running in: konsole inxi: 3.3.01
