hound
21 March 2021 07:56
1
Hello.
I’ve noticed when Xorg process starts to load cpu ~5% (KSysGuard info) UI starts freeze: slow mouse cursor, slow scroll in browser.
Usually it happens while I share my screen with Discord, Zoom.
My HW:
Kernel: 5.11.6-1-MANJARO x86_64 bits: 64 Desktop: KDE Plasma 5.21.3
Distro: Manjaro Linux
Type: Desktop Mobo: Micro-Star model: B450 TOMAHAWK MAX (MS-7C02) v: 1.0
serial: <filter> UEFI: American Megatrends v: 3.70 date: 06/09/2020
Info: 8-Core model: AMD Ryzen 7 PRO 3700 bits: 64 type: MT MCP cache:
L2: 4 MiB
Speed: 3011 MHz min/max: 2200/3600 MHz Core speeds (MHz): 1: 3011 2: 2115
3: 1932 4: 2134 5: 2200 6: 2199 7: 2196 8: 2141 9: 2197 10: 2200 11: 2200
12: 2200 13: 2188 14: 4335 15: 3162 16: 2177
Device-1: NVIDIA GK208B [GeForce GT 710 1GB] driver: nvidia v: 460.56
Display: x11 server: X.Org 1.20.10 driver: loaded: nvidia resolution:
1: 1920x1080~60Hz 2: 2560x1440
OpenGL: renderer: GeForce GT 710/PCIe/SSE2 v: 4.6.0 NVIDIA 460.56
Device-1: NVIDIA GK208 HDMI/DP Audio driver: snd_hda_intel
Device-2: AMD Starship/Matisse HD Audio driver: snd_hda_intel
Sound Server-1: ALSA v: k5.11.6-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 14.2 running: yes
Device-1: Realtek RTL8812AE 802.11ac PCIe Wireless Network Adapter
driver: rtl8821ae
IF: wlo1 state: down mac: <filter>
driver: r8169
IF: enp34s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: br-4ef831da16ae state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
Local Storage: total: 2.05 TiB used: 516.81 GiB (24.6%)
ID-1: /dev/nvme0n1 vendor: HP model: SSD EX920 256GB size: 238.47 GiB
ID-2: /dev/sda vendor: Seagate model: ST2000DM008-2FR102 size: 1.82 TiB
ID-1: / size: 76.4 GiB used: 15.91 GiB (20.8%) fs: ext4 dev: /dev/nvme0n1p6
uuid: a05b0788-cb1c-4062-982c-0a21af4d6f41
ID-2: /boot/efi size: 511 MiB used: 332 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p8 uuid: DF6D-CB57
ID-3: /home size: 56.16 GiB used: 3.66 GiB (6.5%) fs: ext4
dev: /dev/nvme0n1p7 uuid: 2d0172f1-7bf2-4036-b001-a7f58277dd99
ID-1: swap-1 type: partition size: 39.06 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p5 uuid: bbd1991e-a421-4e41-871d-491f57630a2e
System Temperatures: cpu: 52.4 C mobo: 31.0 C gpu: nvidia temp: 44 C
Fan Speeds (RPM): fan-1: 0 fan-2: 869 fan-3: 0 fan-4: 0 fan-5: 920 fan-6: 0
gpu: nvidia fan: 40%
Processes: 397 Uptime: 9h 21m Memory: 31.37 GiB used: 8.23 GiB (26.2%)
Shell: Bash inxi: 3.3.03
I have two monitors: FullHD and 2K.
I’ve tried to do these actions on my laptop (i5 + GeForce 1050 4GB). There Xorg tends to load ~7% and no freezes happen.
Also I turned off compositor and use OpenGL backend. Tried to use XRender but I got the same behaviour.
This PC on Windows 10 works without any freezes.
What can I do to resolve these freezes?
There’s the cause. And I see that you’re using the proprietary Nvidia driver, which is more than likely the source of the problem. Unfortunately, when it comes to that driver, you are at the mercy of Nvidia, given that the driver code is closed-source.
hound
21 March 2021 08:29
4
Try to use 5.10 got the same
hound
21 March 2021 08:31
5
I use proprietary driver on laptop too and there is no issues.
I thought that my video card is too weak, but on Windows it works fine.
hound
21 March 2021 08:34
6
In Nvidia tools I noticed that system uses about 800mb of video ram (my card has only 1gb).
something heavy for 800mb
only on 1920x1080 screen with 970 nvidia card
nvidia-smi
Sun Mar 21 09:39:41 2021
| NVIDIA-SMI 460.56 Driver Version: 460.56 CUDA Version: 11.2 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 GeForce GTX 970 Off | 00000000:07:00.0 On | N/A |
| 0% 50C P0 46W / 201W | 180MiB / 4034MiB | 0% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| 0 N/A N/A 550 G /usr/lib/Xorg 147MiB |
| 0 N/A N/A 804 G xfwm4 2MiB |
| 0 N/A N/A 2008 G /usr/lib/firefox/firefox 2MiB |
| 0 N/A N/A 2123 G /usr/lib/firefox/firefox 2MiB |
| 0 N/A N/A 2219 G /usr/lib/firefox/firefox 2MiB |
| 0 N/A N/A 2247 G /usr/lib/firefox/firefox 2MiB |
| 0 N/A N/A 2302 G /usr/lib/firefox/firefox 2MiB |
| 0 N/A N/A 3453 G /usr/lib/firefox/firefox 2MiB |
| 0 N/A N/A 4452 G /usr/lib/firefox/firefox 2MiB |
| 0 N/A N/A 4526 G /usr/lib/firefox/firefox 2MiB |
hound
21 March 2021 08:49
8
Strange…this can be cause of my issue?
If your graphics adapter isn’t powerful enough, then yes.
hound
21 March 2021 09:01
10
But on Windows all works fine…
That’s confused me
The Nvidia driver you use in Windows is not the same as the one you use in GNU/Linux. It’s a different operating system, and the way the driver interfaces with the underlying kernel is different too.
hound
21 March 2021 09:21
12
I see…
More powerful video card can help?
Possibly. Or a better driver. But I’m afraid this is outside of my sphere of knowledge. All I can tell you is that I’ll never buy a computer with Nvidia again if I can help it. AMD and Intel both offer open-source, GPL-licensed drivers for their GPUs, while with Nvidia, you must either use the crippled reverse-engineered nouveau
driver or a proprietary, closed-source driver of which nobody knows what it does.
hound
21 March 2021 09:43
14
Oh…why it’s complicated on Linux
hound
21 March 2021 09:56
15
But anyway I’d want to be sure that these issues happened due to video card and only due to video card
hound
21 March 2021 17:41
16
Strange. I got smth like this. Why there are no processes?
Sun Mar 21 20:40:54 2021
| | | MIG M. |
| 0 GeForce GT 710 Off | 00000000:26:00.0 N/A | N/A |
| 38% 42C P8 N/A / N/A | 749MiB / 973MiB | N/A Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
pobrn
21 March 2021 21:55
17
The nvidia-smi
documentation writes :
Reporting for Graphics processes is limited to the supported products starting with Kepler architecture.
so this could be the reason why processes are not shown.
Fabby
24 March 2021 00:13
18
I’ve had this before with Xorg and it’s a bug in an application you’re using.
So basically what is happening is that xorg is using 100% of 1 core on your 8-core machine.
File a bug with the application developer (I’ve had it with VLC and qBittorrent and their bugs have been fixed in the mean time and you seem to have this with Discord and Zoom, which I don’t use.)
hound
24 March 2021 08:35
19
But on another PC there is no such bug.
I have two laptops:
Ryzen 5 + Vega 8 - works fine
i5 + GTX1050 - also works fine (this laptop use GeForce instead intel by default)
hound
24 March 2021 09:33
20
And also I noticed that browser (Chrome) works more smoothly in laptop with Ryzen5 + Vega8.
Smoothly in some heavy web apps (maps, lucidchart etc)
