I had a random freeze-up that I’ve encountered intermittently for the past 6 months. This time fortunately I was able to Ctrl-Alt-F2 and extract the Xorg log. Then I ran the following commands: “pkill xfwm4” and “pkill firefox”, then on observing that Firefox’s rendering engine was still running, I also ran “pkill GeckoMain”. Going to Ctrl-Alt-F7 after that gave me a functioning desktop again.
How to prevent these Xorg errors? A search gave me an Arch Linux page but it did not have a solution.
"modeset(0): Failed to set CTM property: -13
“modeset(0): failed to set mode: No such file or directory”
Output of /var/log/Xorg.0.log before and after the freeze-up:
[ 58.739] (II) modeset(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 58.739] (II) modeset(0): Modeline "1600x900"x60.0 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz e)
[ 467.921] (II) event1 - Power Button: device removed
[ 467.940] (II) event0 - Power Button: device removed
[ 467.970] (II) event15 - Microsoft Microsoft® 2.4GHz Transceiver v8.0: device removed
[ 468.010] (II) event16 - Microsoft Microsoft® 2.4GHz Transceiver v8.0 Mouse: device removed
[ 468.063] (II) event19 - Microsoft Microsoft® 2.4GHz Transceiver v8.0 System Control: device removed
[ 468.090] (II) event17 - Microsoft Microsoft® 2.4GHz Transceiver v8.0 Consumer Control: device removed
[ 468.116] (II) event18 - Microsoft Microsoft® 2.4GHz Transceiver v8.0 Consumer Control: device removed
[ 468.143] (II) AIGLX: Suspending AIGLX clients for VT switch
[ 468.244] (EE) modeset(0): Failed to set CTM property: -13
[ 468.244] (EE) modeset(0): failed to set mode: No such file or directory
[ 652.902] (II) AIGLX: Resuming AIGLX clients after VT switch
[ 653.053] (II) modeset(0): EDID vendor "DEL", prod id 53409
[ 653.053] (II) modeset(0): Using hsync ranges from config file
[ 653.053] (II) modeset(0): Using vrefresh ranges from config file
[ 653.053] (II) modeset(0): Printing DDC gathered Modelines:
[ 653.053] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 653.053] (II) modeset(0): Modeline "1920x1080"x0.0 174.50 1920 1968 2000 2080 1080 1083 1088 1119 +hsync -vsync (83.9 kHz e)
System information:
$ inxi --admin --verbosity=7 --filter --width
Kernel: 5.10.83-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=541f3338-1847-42ad-8318-703b5617ec29 rw
resume=UUID=3be5dd92-afea-42be-890a-b9785af9db43 udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Type: Desktop Mobo: Micro-Star model: MPG X570 GAMING EDGE WIFI (MS-7C37)
v: 1.0 serial: <superuser required> UEFI: American Megatrends v: 1.40
date: 09/10/2019
RAM: total: 15.64 GiB used: 1.65 GiB (10.5%)
Info: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701013 cache:
L1: 384 KiB L2: 3 MiB L3: 32 MiB bogomips: 86434
Speed: 3597 MHz min/max: N/A Core speeds (MHz): 1: 3597 2: 3599 3: 3596
4: 3749 5: 3401 6: 3399 7: 3591 8: 3598 9: 3604 10: 3646 11: 3404 12: 3414
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es sha_ni
skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload
vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr
xsaveopt xsaves
always-on, RSB filling
Device-1: NVIDIA GK208B [GeForce GT 710] vendor: Micro-Star MSI
driver: nouveau v: kernel bus-ID: 2d:00.0 chip-ID: 10de:128b class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 compositor: xfwm4 v: 4.16.1 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: HDMI-1 res: 1920x1080 hz: 60 dpi: 82 size: 598x336mm (23.5x13.2")
diag: 686mm (27")
Device-1: NVIDIA GK208 HDMI/DP Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 2d:00.1 chip-ID: 10de:0e0f
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 2f:00.4 chip-ID: 1022:1487
class-ID: 0403
Sound Server-1: ALSA v: k5.10.83-1-MANJARO running: yes
vendor: Micro-Star MSI X570-A PRO driver: r8169 v: kernel port: d000
bus-ID: 27:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp39s0 state: down mac: <filter>
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel bus-ID: 29:00.0 chip-ID: 8086:24fb class-ID: 0280
IF: wlp41s0 state: up mac: <filter>
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-4:3 chip-ID: 8087:0aa7 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 931.51 GiB used: 123.23 GiB (13.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WDS100T2B0B-00YS70 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 00WD
scheme: GPT
ID-1: / raw-size: 922.42 GiB size: 906.94 GiB (98.32%)
used: 123.23 GiB (13.6%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 541f3338-1847-42ad-8318-703b5617ec29
used: 280 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: FCDD-40C8
dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 3be5dd92-afea-42be-890a-b9785af9db43
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 1-1:2 info: Microsoft Nano Transceiver v1.0 for Bluetooth
type: Keyboard,Mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 045e:0745 class-ID: 0300
Device-2: 1-4:3 info: Intel Wireless-AC 3168 Bluetooth type: Bluetooth
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 3-5:2 info: Micro Star MYSTIC LIGHT type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: 1462:7c37 class-ID: 0300 serial: <filter>
Hub-4: 3-6:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-5: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-6: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-7: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 46.5 C mobo: 29.0 C gpu: nouveau temp: 40.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 1677 fan-3: 927 fan-4: 814 fan-5: 0
fan-6: 0 fan-7: 0
Processes: 285 Uptime: 21m wakeups: 0 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1278 lib: 359
Shell: Bash v: 5.1.12 running-in: xfce4-terminal inxi: 3.3.09
Display information:
$ xrandr
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 16384 x 16384
DVI-D-1 disconnected (normal left inverted right x axis y axis)
HDMI-1 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 598mm x 336mm
1920x1080 60.00*+ 74.97 59.96 50.00 59.94 59.93
1920x1080i 60.00 50.00 59.94
1680x1050 59.95 59.88
1400x1050 74.76 59.98
1600x900 59.95 60.00 59.82
1280x1024 75.02 60.02
1400x900 59.96 59.88
1280x960 60.00
1440x810 59.97
1368x768 59.88 59.85
1280x800 59.99 59.97 59.81 59.91
1152x864 75.00
1280x720 60.00 59.99 59.86 60.00 50.00 59.94 59.74
1024x768 75.05 60.04 75.03 70.07 60.00
960x720 75.00 60.00
928x696 75.00 60.05
896x672 75.05 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
832x624 74.55
960x540 59.96 59.99 59.63 59.82
800x600 75.00 70.00 65.00 60.00 72.19 75.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
720x576 50.00
700x525 74.76 59.98
800x450 59.95 59.82
720x480 60.00 59.94
640x512 75.02 60.02
700x450 59.96 59.88
640x480 60.00 75.00 72.81 75.00 60.00 59.94
720x405 59.51 58.99
720x400 70.08
684x384 59.88 59.85
640x400 59.88 59.98
576x432 75.00
640x360 59.86 59.83 59.84 59.32
512x384 75.03 70.07 60.00
512x288 60.00 59.92
416x312 74.66
480x270 59.63 59.82
400x300 72.19 75.12 60.32 56.34
432x243 59.92 59.57
320x240 72.81 75.00 60.05
360x202 59.51 59.13
320x180 59.84 59.32
VGA-1 disconnected (normal left inverted right x axis y axis)
