Hi, so I have a problem with xorg failing at "“no screens found”.
If I do a startx
or lightdm
from tty xorg runs and I get into my WM just fine. However, get a dbus error if I run lightdm from the tty. On the other hand, I bypass lightdm and I don’t get the dbus error if i start xserver from the tty.
output of /var/log/Xorg.0.log
[ 7.706]
X.Org X Server 1.20.10
[ 7.706] Build Operating System: Linux Manjaro Linux
[ 7.706] Current Operating System: Linux desk 5.10.23-1-MANJARO #1 SMP PREEMPT Thu Mar 11 18:47:18 UTC 2021 x86_64
[ 7.706] Kernel command line: BOOT_IMAGE=/vmlinuz-5.10-x86_64 root=UUID=1578da60-6045-4342-8e0c-7644878ee482 rw iommu=pt amd_iommu=on cryptdevice=UUID=be971bfe-ee44-4d08-80a7-69b696e0cf12:luks-be971bfe-ee44-4d08-80a7-69b696e0cf12 root=/dev/mapper/luks-be971bfe-ee44-4d08-80a7-69b696e0cf12 resume=/dev/mapper/luks-be971bfe-ee44-4d08-80a7-69b696e0cf12 udev.log_priority=3
[ 7.706] Build Date: 16 December 2020 10:33:32PM
[ 7.706]
[ 7.706] Current version of pixman: 0.40.0
[ 7.706] Before reporting problems, check http://wiki.x.org
[ 7.706] Markers: (--) probed, (**) from config file, (==) default setting,
[ 7.706] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Apr 7 02:30:14 2021
[ 7.706] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 7.706] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 7.706] (==) No Layout section. Using the first Screen section.
[ 7.706] (==) No screen section available. Using defaults.
[ 7.706] (**) |-->Screen "Default Screen Section" (0)
[ 7.706] (**) | |-->Monitor "<default monitor>"
[ 7.706] (==) No device specified for screen "Default Screen Section".
Using the first device section listed.
[ 7.706] (**) | |-->Device "AMD"
[ 7.706] (==) No monitor specified for screen "Default Screen Section".
[ 7.706] (==) Automatically adding devices
[ 7.707] (==) Automatically enabling devices
[ 7.707] (==) Automatically adding GPU devices
[ 7.707] (==) Automatically binding GPU devices
[ 7.707] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 7.707] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 7.707] Entry deleted from font path.
[ 7.707] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 7.707] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 7.707] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF,
/usr/share/fonts/OTF
[ 7.707] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 7.707] (II) The server relies on udev to provide the list of input devices.
[ 7.707] (II) Module ABI versions:
[ 7.707] X.Org ANSI C Emulation: 0.4
[ 7.707] X.Org Video Driver: 24.1
[ 7.707] X.Org XInput driver : 24.1
[ 7.707] X.Org Server Extension : 10.0
[ 7.707] (++) using VT number 7
[ 7.707] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 7.718] (--) PCI: (8@0:0:0) 10de:1e81:10de:13a0 rev 161, Mem @ 0xd8000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x00003000/128, BIOS @ 0x????????/524288
[ 7.718] (--) PCI:*(69@0:0:0) 1002:66af:1002:081e rev 193, Mem @ 0x80000000/268435456, 0x90000000/2097152, 0x9fb00000/524288, I/O @ 0x00004000/256, BIOS @ 0x????????/131072
[ 7.718] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 7.718] (II) LoadModule: "glx"
[ 7.718] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 7.720] (II) Module glx: vendor="X.Org Foundation"
[ 7.720] compiled for 1.20.10, module version = 1.0.0
[ 7.720] ABI class: X.Org Server Extension, version 10.0
[ 7.720] (II) LoadModule: "amdgpu"
[ 7.720] (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
[ 7.721] (II) Module amdgpu: vendor="X.Org Foundation"
[ 7.721] compiled for 1.20.8, module version = 19.1.0
[ 7.721] Module class: X.Org Video Driver
[ 7.721] ABI class: X.Org Video Driver, version 24.1
[ 7.721] (II) AMDGPU: Driver for AMD Radeon:
All GPUs supported by the amdgpu kernel driver
[ 7.782] (II) AMDGPU(0): [KMS] drm report modesetting isn't supported.
[ 7.782] (EE) Screen 0 deleted because of no matching config section.
[ 7.782] (II) UnloadModule: "amdgpu"
[ 7.782] (EE) Device(s) detected, but none match those in the config file.
[ 7.782] (EE)
Fatal server error:
[ 7.782] (EE) no screens found(EE)
[ 7.782] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 7.782] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 7.782] (EE)
[ 7.832] (EE) Server terminated with error (1). Closing log file.
output of mhwd -li --pci
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
output of inxi -G
after doing a startx
Graphics: Device-1: NVIDIA TU104 [GeForce RTX 2080 SUPER] driver: vfio-pci v: 0.2
Device-2: Advanced Micro Devices [AMD/ATI] Vega 20 [Radeon VII] driver: amdgpu v: kernel
Display: server: X.Org 1.20.10 driver: loaded: amdgpu resolution: 1: 2560x1080~60Hz 2: 2560x1440~60Hz
OpenGL: renderer: AMD Radeon VII (VEGA20 DRM 3.40.0 5.10.23-1-MANJARO LLVM 11.1.0) v: 4.6 Mesa 20.3.4
Disclaimer I deserve this because I did mess with the Xorg files and deleted the “90-mhwd.conf” before this issue started. This was to get both my AMD gpu and NVIDIA gpu to show up with hardware ids for GPU passthrough. I’m now just hoping I can just fix my xorg and not reinstall the OS.
