Hello human beings!
I just did a fresh install of manjaro unstable with the prop. nvidia driver (i need it for hdmi-2.1).
I noticed that /etc/X11/xorg.conf.d/90-mhwd.conf is slighty different from what nvidia-xconfig creates when i run it manually, even though both say
nvidia-xconfig: X configuration file generated by nvidia-xconfig
nvidia-xconfig: version 555.58.02
The 2 differences that stand out is that the mhwd config does not specify BusID for the nvidia-card (which might be needed in multi-gpu setups) and explicitly enables the Composite extension.
I’m not sure if this is the reason my compositor (xfce) runs 1000x faster now but it does. It used to tear and lag horribly since i added a 8K TV.
I’m just curious how this process works. Is there a command that creates the mhwd config?
Can i edit the 90-mhwd.conf just like i used to edit the /etc/X11/xorg.conf many years ago?
Thank you !!
