Xorg appears to lock game performance to 60FPS and Wayland causes flickering
When I try to run any game on my computer through Steam and Xorg it caps the frame rate at 60 FPS, in my research, I found that apparently this is some kind of limitation of Xorg. However, if I use Wayland the frame rate cap is solved, but some games keep flickering, I was unable to fix it.
>>> inti -Fazy
  Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=cf35bdd2-48e7-4b26-80ac-76b47ae70116 rw quiet splash
    udev.log_priority=3 nvidia-drm.modeset=1
  Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
    wm: kwin_x11 with: krunner vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
  Type: Desktop System: Gigabyte product: B360M-D3H v: N/A
    serial: <superuser required>
  Mobo: Gigabyte model: B360M D3H-CF serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends v: F16 date: 12/21/2023
  Device-1: hidpp_battery_0 model: Logitech G305 Lightspeed Wireless Gaming
    Mouse serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  Device-2: ps-controller-battery-24:a6:fa:a7:0d:c7 model: N/A serial: N/A
    charge: N/A status: charging
  Info: model: Intel Core i7-8700 bits: 64 type: MT MCP arch: Coffee Lake
    gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF8
  Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
    smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB
    desc: 6x256 KiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 800 min/max: 800/4600 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 76831
    vulnerable
  Device-1: NVIDIA TU106 [GeForce RTX 2060 Rev. A] vendor: eVga.com.
    driver: nvidia v: 550.135 alternate: nouveau,nvidia_drm non-free: 550.xx+
    status: current (as of 2024-09; EOL~2026-12-xx) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 16
    ports: active: none off: DP-1,HDMI-A-1 empty: DVI-D-1 bus-ID: 01:00.0
    chip-ID: 10de:1f08 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
    compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 4480x1080 s-dpi: 81 s-size: 1405x343mm (55.31x13.50")
    s-diag: 1446mm (56.94")
  Monitor-1: DP-1 mapped: DP-0 note: disabled pos: primary,left
    res: 1920x1080 hz: 120 dpi: 92 size: 532x304mm (20.94x11.97") modes: N/A
  Monitor-2: HDMI-A-1 mapped: HDMI-0 note: disabled pos: right res: 2560x1080
    hz: 60 dpi: 81 size: 798x334mm (31.42x13.15") modes: N/A
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia
    inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.135
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2
    memory: 5.86 GiB
  API: Vulkan v: 1.4.303 layers: 9 device: 0 type: discrete-gpu
    name: NVIDIA GeForce RTX 2060 driver: N/A device-ID: 10de:1f08
    surfaces: xcb,xlib
  Device-1: Intel Cannon Lake PCH cAVS vendor: Gigabyte driver: snd_hda_intel
    v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
  Device-2: NVIDIA TU106 High Definition Audio vendor: eVga.com.
    bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
  Device-3: Sony DualSense wireless controller (PS5)
    driver: playstation,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 480 Mb/s
    lanes: 1 mode: 2.0 bus-ID: 1-4:2 chip-ID: 054c:0ce6 class-ID: 0300
  Device-4: Kingston HyperX 7.1 Audio
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-7:5 chip-ID: 0951:16a4 class-ID: 0300
    serial: <filter>
  Device-5: C-Media ARCANO AM-BLACK-1
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-8:6 chip-ID: 0d8c:0134 class-ID: 0300
  API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
  Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
  Device-2: Sony DualSense wireless controller (PS5)
  Info: services: NetworkManager
  Local Storage: total: 1.82 TiB used: 158.04 GiB (8.5%)
    model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 211210WD temp: 39.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
    tech: HDD rpm: 7200 serial: <filter> fw-rev: CC43 scheme: GPT
  ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
    used: 152.86 GiB (16.7%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
  System Temperatures: cpu: 41.0 C pch: 55.0 C mobo: 37.0 C gpu: nvidia
    temp: 41 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 40%
  Memory: total: 16 GiB available: 15.53 GiB used: 2.81 GiB (18.1%)
  Processes: 301 Power: uptime: 23m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.15 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Packages: 1489 pm: pacman pkgs: 1479 libs: 394 tools: pamac,yay pm: flatpak
    pkgs: 10 Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.37
    running-in: konsole inxi: 3.3.36
So, I apparently fixed it. I just don’t know exactly how, because I deactivated “Sync to VBlank” and “Allow Flipping” in nvidia-settings and also deactivated the compositor at startup. If someone that is more knowledgeable than I in that matter, please explain better.
20250106_124606
20250106_124708
Put the settings back to where they were, reboot.
When you have dual monitor setup, I think the lowest Hz monitor caps the max Fullscreen FPS on the higher Hz monitor. Disable the second monitor before starting your game and see if it fixes your issue.
Maybe you could also set your game to use Fullscreen Window or Borderless mode instead of real Fullscreen mode.
Maybe just disable Sync to Vblank in Nvidia Settings.
Do one thing at a time to find the culprit.
Yes, you were right. Apparently disabling just Sync to VBlack was enough
