Hey, so I’ve been looking at so many different forums, and it looks the like problem I am running into is something about my hardware. I want to enable track pad while typing, and I’ve been trying xinput, but it will not list my track pad in its list. libinput will show my track pad and the properties, but I cannot edit using libinput, this only verifies that my track pad does exist on my system, just that xinput is not seeing it. When I enter the command xinput-list or just xinput it displays this in the terminal:
WARNING: running xinput against an Xwayland server. See the xinput man page for details.
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ xwayland-pointer:15 id=6 [slave pointer (2)]
⎜ ↳ xwayland-relative-pointer:15 id=7 [slave pointer (2)]
⎜ ↳ xwayland-pointer-gestures:15 id=8 [slave pointer (2)]
⎜ ↳ xwayland-touch:15 id=10 [slave pointer (2)]
⎜ ↳ xwayland-tablet stylus:15 id=11 [slave pointer (2)]
⎜ ↳ xwayland-tablet eraser:15 id=12 [slave pointer (2)]
⎜ ↳ xwayland-tablet cursor:15 id=13 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ xwayland-keyboard:15 id=9 [slave keyboard (3)]
Every forum I have come across shows actual devices, not whatever this is. Sorry if this is a problem that is already solved or something dumb, but I’ve been trying to solve this for for over 2 hours now.
cscs
18 April 2024 04:38
2
When sharing output please share the text itself.
Not images of the text.
For how to format things and other tips see this guide
Difficulty: ★☆☆☆☆
Strong of its many members, the Manjaro support forum can provide you help whenever you have an issue with your Manjaro installation. But in order to work efficiently, we shall also ask you to follow three major points.
Provide context
Simply signaling an issue is rarely enough to understand how it occurred. It is thus important to provide details on how it happened:
Detail prior actions leading to the issue.
List solutions and guides you already tried, with links when…
It usually makes sense to also include some system information, ie;
inxi -Farz
As to your (original) issue;
Thats simple enough. An example:
/etc/X11/xorg.conf.d/30-touchpad.conf
Section "InputClass"
Identifier "touchpad"
Driver "libinput"
MatchIsTouchpad "on"
Option "Tapping" "on"
Option "DisableWhileTyping" "0"
EndSection
https://wiki.archlinux.org/title/Libinput#Enable_the_touchpad_while_typing
Sorry for not elaborating on this issue as well. It seems that the config file for xinput is also not functioning normally. Simply by going to /etc/X11/xorg.conf.d displays only 00-keyboard.conf while viewing it using vim. The issue may be linked to the emptiness of the file. I have tried repairing xorg before, but I am met with the same issue.
That explains something…
Wayland on Xfce is experimental at best …
https://wiki.xfce.org/releng/wayland_roadmap
The Xfce GitLab is tracking the milestone changes for Xfce 4.20. The Xfce 4.20 schedule remains “TODO” at this point.
– https://www.phoronix.com/news/Xfce-4.20-Wayland-Roadmap
cscs
18 April 2024 07:48
5
Well … then you dont have any such configuration file.
You should create one with contents like shown above/in the link.
Also thank you for adding text output.
I agree that if you are using wayland this could contribute to odd showings of xinput as well as should probably be avoided on xfce for now.
Have you tried starting an Xorg session ?
So Wayland will not work, because they haven’t worked on this yet? Even if I manually add files, it will still run using Wayland. Do I have to remove it? It installed with xorg, so there should be a lot of dependencies associated with it. Where could I look to find out how to workaround Wayland?
Perhaps you could describe what the actual problem is - the goal you want to achieve.
Your chosen path towards it might not be the best or even outright wrong.
Xfce4 normally does not start in “wayland mode” - you had to have done something to get to the current situation.
Of which we don’t know much at all
inxi -Fzay
gives system information.
I’m just going to paste the entire result for this command for pure analysis, and I can edit this to only show possible conflictions for forum organization later.
Running inxi -Fzay results with this:
Kernel: 6.6.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=972909c8-17e3-4891-8f97-302e491541e2 rw quiet splash apparmor=1
security=apparmor resume=UUID=76c81cd0-3dc6-47f2-99ba-f1e7b8b8fcfd
udev.log_priority=3
Desktop: GNOME v: 45.4 tk: GTK v: 3.24.41 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 45.0.1 Distro: Manjaro
base: Arch Linux
Type: Convertible System: HP product: HP EliteBook x360 1030 G2 v: N/A
serial: <superuser required> Chassis: type: 31 serial: <superuser required>
Mobo: HP model: 827D v: KBC Version 44.61 serial: <superuser required>
part-nu: 2KX98US#ABA uuid: <superuser required> UEFI: HP v: P80 Ver. 01.14
date: 01/22/2018
ID-1: BAT0 charge: 37.4 Wh (80.6%) condition: 46.4/46.4 Wh (100.0%)
volts: 12.0 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: discharging
Info: model: Intel Core i7-7600U bits: 64 type: MT MCP arch: Amber/Kaby Lake
note: check gen: core 7 level: v3 note: check built: 2017 process: Intel 14nm
family: 6 model-id: 0x8E (142) stepping: 9 microcode: 0xF4
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 900 min/max: 400/3900 scaling: driver: intel_pstate
governor: powersave cores: 1: 900 2: 900 3: 900 4: 900 bogomips: 23209
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 620 vendor: Hewlett-Packard driver: i915
v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:5916 class-ID: 0300
Device-2: Chicony HP HD Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:4 chip-ID: 04f2:b58f
class-ID: 0e02
Device-3: Chicony HP IR Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:5 chip-ID: 04f2:b58e
Display: wayland server: X.org v: 1.21.1.12 with: Xwayland v: 23.2.6
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: AU Optronics 0x422d built: 2016 res: 1920x1080
dpi: 166 gamma: 1.2 size: 293x165mm (11.54x6.5") diag: 336mm (13.2")
ratio: 16:9 modes: 1920x1080
device: 1 drv: swrast surfaceless: drv: iris wayland: drv: iris x11:
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.2-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 620 (KBL GT2)
device-ID: 8086:5916 memory: 15.14 GiB unified: yes display-ID: :0.0
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:9d71
class-ID: 0403
API: ALSA v: k6.6.25-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 3a:00.0 chip-ID: 8086:24fd class-ID: 0280
IF: wlp58s0 state: up mac: <filter>
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:6 chip-ID: 8087:0a2b
class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 6 state: up address: <filter> bt-v: 4.2
lmp-v: 8 status: discoverable: no pairing: no class-ID: 6c0000
Local Storage: total: 476.94 GiB used: 47.52 GiB (10.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLW512HMJP-000H1
lanes: 4 tech: SSD serial: <filter> fw-rev: CXY73H1Q temp: 28.9 C
scheme: GPT
ID-1: / raw-size: 459.59 GiB size: 451.3 GiB (98.20%) used: 47.52 GiB (10.5%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: partition size: 17.06 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 48.0 C pch: 37.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 16 GiB available: 15.5 GiB used: 3.38 GiB (21.8%)
Processes: 227 Power: uptime: 23h 55m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 5 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 6.19 GiB services: gsd-power,
tool: systemctl
Packages: pm: pacman pkgs: 1354 libs: 382 tools: gnome-software,pamac,yay
pm: flatpak pkgs: 0 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.34
Now we know why you are in a wayland session.
You are using Gnome - and could switch between wayland and xorg before login.
But you tagged your post as Xfce4 (unless I was imagining things …).
xorg is just not the default - but you can switch to it somewhere on the login screen
